What size jets? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 12 (permalink) Old 10-04-2010, 06:34 PM Thread Starter
What size jets?
I have an '06 450ER. K&N air-filter, White Bros. slip on exhaust. About to get stage two cam and exhaust tape. I am not running an air-box lid, just outwears. I currently have a 180 main and stock pilot jet. I just put in the 180 from the stock 120 and it really woke up the quad. It still seems to be running to lean though. I think I need a bigger jet now. What happens when I get the cam and exhaust tape? Any suggestions on what size jets I should be running?
roughnecky2000 is offline
post #2 of 12 (permalink) Old 10-04-2010, 06:58 PM
450R XC Rider
450rquadrider's Avatar
Location: Ashland, Virginia(Currently in Blacksburg, VA Go HOKIES!!)
A 180 is WAYYY to fat. Even with a cam (which doesnt really effect jetting much at all) you should be around a 162-165 main and a 45 pilot. If it is stumbling a little on top, its because you are too rich, not lean.
07 450er- HMF, Powermadd, ASV, ITP, Holz, Uni, Pro Armor, Pro Taper, Streamline, Tusk, Teixeira Tech, Laker Customs, Oury, GT Thunder
450rquadrider is offline
post #3 of 12 (permalink) Old 10-04-2010, 07:11 PM
j450rx's Avatar
^^ x2!!
07er se 520
100mm athena bigbore cylinder
+4 fallicon knife edge stroker crank
14.25 to 1 venom piston
QUIKSHRK ported head w/+1 ferreras x4
kibble white dual rate springs
custom web cam
44 sredrum fcr
direct drive lockout
dasa classic pipe
fuel customs intake
green wire mod
+6 arched ladder bar quikshrk swinger
fox float evols and podium
lonestar longtravel dc4's
lonestar billet hubs with wave rotors
lonestar rear linkage
66hp 41tq
j450rx is offline
post #4 of 12 (permalink) Old 10-04-2010, 07:39 PM Thread Starter
I have good power all the way around for what the bike has. I do not have lagging problems at any range. I have NO soot in muffler. It sounds way to crisp, and there is nothing on the plug. What is the stock pilot size? Maybe that is where my problem is.
post #5 of 12 (permalink) Old 10-04-2010, 08:18 PM
450R XC Rider
Stock is a 42. You should probably try a 45 and lean down the main. That is really rich and is probably costing you power.
post #6 of 12 (permalink) Old 10-04-2010, 09:03 PM
trxfoefitty's Avatar
you should have a 165 main. or close to that
07 450er
trxfoefitty is offline
post #7 of 12 (permalink) Old 10-05-2010, 11:06 AM
TRX450R14's Avatar
Listen to what these guys are telling you...a 162 or 165 is the proper range for your main jet....unless there is a variable that would require a drastic change fron Hondas recommendations....ie...altitude/temperature.
Team X Racing....we don't just race....we ride.
There's no room for "one trick ponies" in our stable.
Walk softly and carry a big stick.
True power IS in the head....it's called a brain.
2011 1/8th mile ATV Drag video...
The fastest,most reliable trail quads on the east coast.
TRX450R14 is offline
post #8 of 12 (permalink) Old 10-05-2010, 03:53 PM
Fairly fast foreigner!
OTMTRX's Avatar
X2 on all of the above...
'06 TRX450ER, '03 XR400r, '04 CRF450r, '05 CRF250r, '06 CBR1000RR (StreetFighter), 07 GSX-R750, '71 CB500, '75 CL360 (Honda Scrambler), '81 Virago XV750 (the 110 Bike).
06 Black TRX450ER (Conv to kicker) "Medium" Big bore! Quikshrk (OCP), Demon, REAZ bits.
OTMTRX is offline
post #9 of 12 (permalink) Old 10-05-2010, 06:56 PM Thread Starter
Thanks folks. Gonna go with a 165 and 45. Hope it helps.
post #10 of 12 (permalink) Old 10-05-2010, 07:04 PM
450R XC Rider
Let us know how it turns out.
post #11 of 12 (permalink) Old 10-07-2010, 07:45 PM Thread Starter
Runs like a champ. Sounds MUCH better, especially at higher RPM'S. Still bogs down a little if I dump the throttle off the line though.
post #12 of 12 (permalink) Old 10-07-2010, 08:19 PM
450R XC Rider
Have you tried changing the leak jet to a 55? I think stock size is 75. The leak jet affects how much fuel is sent back into the float bowl by the accelerator pump. A smaller jet allows less fuel back into the float bowl which equals more fuel into the engine.
