Decompressor Question - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 29 (permalink) Old 07-30-2010, 08:35 PM Thread Starter
cbgauthier's Avatar
Hey guys i had a question about the decompressor. I have been noticeing a noise from my 2005 450r and i havent had it too long so i figured the valves were out of adjustment. So i took it to get the valves adjusted and told them about the noise i have been hearing when they tore into it they told me that there was something wrong with the decompressor so they took it out. They told me that the only way to fix it is buy a new cam. Has anyone else had this happen and if so what did you do to fix it cuz this think will break your leg trying to kick it over now with no decompresor. Any help would be appreciated.
cbgauthier is offline
post #2 of 29 (permalink) Old 07-31-2010, 09:00 AM
450RRR's Avatar
the only control the camshaft has over the decompressor is the PIN location....or 'timing' for the decomp to operate...... although this can be designed wrong from the factory (long story)... chances of a cam that was working Ok going 'bad' over time is on the RIDICULOUS side of the scale..... ask the dealer to describe exactly WHAT is wrong with the cam and/or decomp mech...... it's worth a few laughs at least... lol
jmho....g
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #3 of 29 (permalink) Old 07-31-2010, 10:06 AM
Fairly fast foreigner!
OTMTRX's Avatar
Like ^^ he said..let us know what they say.....this should be good!
'06 TRX450ER, '03 XR400r, '04 CRF450r, '05 CRF250r, '06 CBR1000RR (StreetFighter), 07 GSX-R750, '71 CB500, '75 CL360 (Honda Scrambler), '81 Virago XV750 (the 110 Bike).
06 Black TRX450ER (Conv to kicker) "Medium" Big bore! Quikshrk (OCP), Demon, REAZ bits.
OTMTRX is offline
post #4 of 29 (permalink) Old 07-31-2010, 03:49 PM Thread Starter
cbgauthier's Avatar
He told me that the pin was siezed up and it wasnt working right so he took it out. I dont know how that would happen but it is a s.o.b. to kick start now so i need to get a new decompressor and fix it.
post #5 of 29 (permalink) Old 07-31-2010, 04:18 PM
Admin
Get the part back and look at it yourself. There really is no pin on it that can seize up. There is a spring and a weight system to it and a bolt that holds the assembly in, but not pin that would lock up keeping it from operating properly. If you get it back take a pic of it and post it.
The Problem With Socialism Is You Eventually Run Out Of Other People's Money. - Margaret Thatcher
depotman is offline
post #6 of 29 (permalink) Old 07-31-2010, 04:20 PM
What Ever In Season
BackSpace's Avatar
Only Possible problem I See Would Lie In The DECOMPRESSION ASSY Some Where Seprate From The Cam
BackSpace is offline
post #7 of 29 (permalink) Old 07-31-2010, 10:37 PM Thread Starter
cbgauthier's Avatar
He said something in it was siezed up possibly in the decompressor assembly i dont know for sure just what he explained to me over the phone i will try to get it from him and take a picture of it but it is killing my foot trying to start this thing with out it. These motors have a ton of compression i weigh 200 and all my weight will barely turn it over fast enough to start it.
post #8 of 29 (permalink) Old 08-01-2010, 01:10 AM
What Ever In Season
BackSpace's Avatar
Yep Its' possible it's Going To Kick Back Soon Kill Your Foot Kick Starter Lever Break Some Cases
post #9 of 29 (permalink) Old 08-01-2010, 07:24 PM Thread Starter
cbgauthier's Avatar
so can you still use the decompressor with a aftermarket cam like a hotcam? I would possibly buy a new cam if i can put the decompressor back in it.
post #10 of 29 (permalink) Old 08-01-2010, 11:50 PM
What Ever In Season
BackSpace's Avatar
YepEr
post #11 of 29 (permalink) Old 08-02-2010, 09:12 AM
450RRR's Avatar
that is not the issue.... you posted that the dealer said the ONLY way to solve this issue is with a new CAM.... then the dealer tells you the DECOMP MECH is seized up.... not likely, but possible... so HOW does a defective Decomp Mechanism require a new CAM? that is my question for the dealer.....
better yet.... get the decomp back from the dealer and lets FIX IT.... and dont waste your money on a new cam when this particular dealer sounds like their mech's are about as bright as a broken bulb with no power going to it....
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
450RRR is offline
post #12 of 29 (permalink) Old 08-02-2010, 11:07 AM
Admin
^^ Agreed with Greg. There isn't really a whole lot to seize up on the decomp. I'll try and remember to take a pic of my decomp tonight to post up.
Really the only moving part on it is the weighted arm which opens up at a certain RPM, and the spring which helps bring it back to its rested position at really low RPMs.
Buying a new cam should have nothing to do with the decomp, as it is removable so all parts can be replaced, and a decomp should be cheaper then a new cam I would think. So if anything you could buy a new decomp, or the part that is bad.
depotman is offline
post #13 of 29 (permalink) Old 08-02-2010, 03:34 PM Thread Starter
cbgauthier's Avatar
Ok so i went and got the decomp back form him and nothing is broke on it or seized up. The problem lies in the weight that is in the cam that comes out to engage the decompressor. It is stuck about half way out so when it was running the weight was slaping the decompressor arm and partially engaging it all the time it was running which is where my ticking noise was coming from and was causing it to not idle cuz the decomp was constantly working. He says the only fix is a new cam cuz it will have the weight already in it. So does that sound right to everyone or not?
post #14 of 29 (permalink) Old 08-02-2010, 04:50 PM
What Ever In Season
BackSpace's Avatar
If You But A Complete Decomp Assy Not A Valve Cam That Does Not Come With A DeComp Assy They Are Separate parts
My Question What Is Keeping The Thing From Working See Whats Binding
Unless They Have Done Away With It All Parts Are Available Separately If On 04-05 Assy Well The DeComp Weight Goes Trough The Decomp Assy And Does Not Realy Have Anything To Do With The Valve Cam. The Decomp Assy Is Separate Of Cam And It's Own Mechanism That Is Timed With And Driven By The Cam But Are Separate After That They Changed To A Rod That Goes Through The Cam That Moves A Pin And Those pins Break And Could Get Debris Scaring The inside of Cam Not Allowing The Actuator Rod To Work. Now Could You Have A Newer Style One Take A Picture Lets See What it looks like Or Show us One
post #15 of 29 (permalink) Old 08-02-2010, 05:29 PM
What Ever In Season
BackSpace's Avatar
Another Thought What Ever Is Causing The Binding Could It Be Fixed By What Ever means Ploshing Removing A Burr Etc But if Something is Bent Replace it
