Which is better 04/05 carb 0r 06+ carb? - Honda TRX Forums: Honda TRX 450R Forum
Old 06-11-2010, 01:48 PM   #1 (permalink)
Default
What size is the 04/05 carb and what size is the 06+ carb? Which one is better?
mykids is offline   Reply With Quote
Old 06-11-2010, 03:04 PM   #2 (permalink)
Super Moderator
Baileygunns's Avatar
Default
Bore the 06+ carb and it has better acceleration.
Baileygunns is offline   Reply With Quote
Old 06-11-2010, 03:35 PM   #3 (permalink)
dyechainsaw's Avatar
Default
04/05 42mm
06+ 40mm
2004 #10 Flattrack Trx450r - Racers Edge 62/38 SS/SB
2012 AMA District 14 "A" class State Champion
2012 WLR 0-450 studded Series Champ
dyechainsaw is offline   Reply With Quote
Old 06-11-2010, 04:37 PM   #4 (permalink)
Default
Thanks for the help baileygunns and dyechainsaw.
Old 07-31-2011, 10:34 PM   #5 (permalink)
Default
I have a question about 05/06 carbs as well.
I have an mx 05 trx450r w/ 13.5.1 sparks piston, sparks exhaust, stage 2 hot cam, and I swapped out the 05 for the 06 carb that was on the first bike(06 that was having problems)
My questions is if I swapped back to an 05 carb, how much if any difference would there be in performance?
The only reason I'm thinking of doing this is I have two bad wrists(broke them when I was younger) and get terrible arm pump within 3-5 min of riding. I let a friend of mine borrow my 06 carb to go to a national race as his started sticking the day before he left... and he says it was all he could do to hold on after a few laps and he never gets arm pump.
This is what I think maybe a last resort as I've tried everything I can think of from working out my hands and wrist to spending stupid amounts of money trying to get my ike better setup... any help would be great. Thanks.
711racer is offline   Reply With Quote
Old 08-01-2011, 01:08 PM   #6 (permalink)
StonedInNy's Avatar
Default
performance wise the the FCR carbs (06+) have a better throttle response than the keihn (04/05) carb . As far as your wrist issue there is a link in this section on how to make the fcr carb easier on the thumb bye modding the spring. A good antivibe stem and som flex bars will help you alot too.
Was in Engine tech faq section
FCR Throttle Spring Mod
04 trx 471r
My Youtube vids checkem out.
http://www.youtube.com/user/jdellav73?feature=mhee
StonedInNy is offline   Reply With Quote
Old 08-03-2011, 03:29 PM   #7 (permalink)
Kyrider's Avatar
Default
i put a fcr on my 04 and the throttle response was better but it killed my power so i switched back to my stock 04 carb
04 450R RACERS EDGE POWERED 64/36 SB/SS
Kyrider is offline   Reply With Quote
Old 08-03-2011, 03:43 PM   #8 (permalink)
Alex90's Avatar
Default
alot of the GNCC guys swap to the older 04/05 carb.. i assume for the low end power gains? dont quote me
Alex90 is offline   Reply With Quote
Old 08-03-2011, 09:44 PM   #9 (permalink)
tm85478's Avatar
Default
Kyrider - How much power did you lose? Do you think boring the stock 04 carb show an improvement?
05 TRX 450R
12.25 Venom piston
HRC kit
White Brothers Aluminum Pro Pipe
13/38 Gearing
tm85478 is offline   Reply With Quote
Old 08-03-2011, 10:44 PM   #10 (permalink)
Kyrider's Avatar
Default
my et times in drag went from a 3.8 to a 4.2-4.3 when i switched to the fcr carb, i think if you bored the fcr out it would be wayyy better than the stock carb
Old 08-03-2011, 10:49 PM   #11 (permalink)
bannedatatvnews.net
airmobile101's Avatar
Default
I feel the FCR is better. People say they are harder to work on, or they need constant tuning. I disagree with any of that. But..... it all depends on your build and what you race.
airmobile101 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
