2005 Trx450r mods and jetting questions - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 18 (permalink) Old 05-08-2010, 09:35 PM Thread Starter
hondaman263's Avatar
I have a 05 450 with a hot cams stage two camshaft, k&N air filter, DMC full exhaust, and no airbox lid.. What jet brand should i use (Dynojet, Kehin, ect.)? and what size should i start at? Any help would be greatly appreciated.
I have been confused on jetting because many people say that the different brands have different size inlets even if they have the same jet number.
Thanks..
2005 Trx450r
12:1 comp
Uni filter - lid on with 4 vents
Sparks exhaust
Stage 1 HC
2007 crf450r
hondaman263 is offline
post #2 of 18 (permalink) Old 05-08-2010, 09:59 PM
185 keihin
bk111 is offline
post #3 of 18 (permalink) Old 05-08-2010, 10:25 PM
Just get with woodward and tell him you need the hrc jet kit with 50 pilot unless you already have new pilot and hrc main needle then yeah 185k
05 450R
Terry Design Concepts Full exhaust
Jetted
EHS Airbox Lid
Stage 2
Working on shock rebuild
Hiper Tech 3s
Razr on back Razr2 on front
337/450r is offline
post #4 of 18 (permalink) Old 05-08-2010, 11:56 PM Thread Starter
do i need to put the needle on a new clip or adjust the air/fuel screw?
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #5 of 18 (permalink) Old 05-09-2010, 01:56 AM
JuiceByTheFoot's Avatar
Send a message via Yahoo to JuiceByTheFoot
Best thing for you if you can afford it would be the full HRC kit. It comes with a GREAT camshaft and the airbox lid and a set of Keihin jets and a needle. If you cant afford the full kit with the cam, just get the HRC jet kit. Chuck the 185 main, 48 pilot, set the needle in the middle, turn the screw 2.5 out, and it should get you VERY close.
I run dynojet kit because I bought and installed it before I knew better. It took some work and trial and error but I got mine DIALED PERFECT on the jetting. However if I had to do it again, HRC jets all the way.
The Myth, The Legend, The Man-Child..There can be ONLY one, JUICE....
04-05 Service Maunal, click here!!!
Mrs. Juice
Mixxer
Venom Performance
HogNutz Racing
LR Motorsports
Daryl Rath / Rath Racing
330lbs of full figured sex appeal....[/COLOR]
JuiceByTheFoot is offline
post #6 of 18 (permalink) Old 05-09-2010, 04:08 PM
450RRR's Avatar
Hey Juice...
just out of curiosity... and for all those Dynajet people on the Org...
what jetting did you end up with?
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #7 of 18 (permalink) Old 05-10-2010, 04:09 AM
2005 450r.
12.25 Venom, HC2, Rossier pipe, no airbox and QuadWorks K&N knockoff w/ outerwear.
Dynojet plug in air bleed
Stock pilot.....i dunno what size it is to be perfectly honest...
Dynojet needle, one clip richer (down) from middle
I bounced between a 185 and 170 main. IT ran good with the 180/185 but hit a false rev limiter up top....too rich. I backed off until that went away and ended up at 175. Its just a shade rich at my elev but I go to sea level ro race frequently and it works great. I could prolly go to a 165/170 and be great. Dynojets instructions put me waaaay to rich. So rich it wouldnt rev past about 4000rpm before it choked and farted on itself. In fact im going up to St Anthony later this week for a weekend for dune thrashing at 5200ft. Ill take my kit and see if the 160/165 runs good.
Also, am I right in hearing that these 450's run a bit faster with the a/f on the slightly leaner side? Anyway here is a chart I found for converting jet sizes...
Width------Keihin # -- DynoJets # -- Mikuni #
0,0540---- 140--------- 130--------- 121,9
0,0550---- 142,5------- 132--------- 123,8
0,0560---- 145--------- 134--------- 125,6
0,0570---- 147,5------- 136--------- 127,5
0,0580---- 150--------- 138--------- 129,4
0,0590---- 152,5------- 140--------- 131,3
0,0600---- 155--------- 142--------- 133,1
0,0610---- 157,5------- 144--------- 135,0
0,0620---- 160--------- 146--------- 136,9
0,0630---- 162,5------- 148--------- 138,8
0,0640---- 165--------- 150--------- 140,6
0,0650---- 167,5------- 152--------- 142,5
0,0660---- 170--------- 154--------- 144,4
0,0670---- 172,5------- 156--------- 146,3
0,0680---- 175--------- 158--------- 148,1
0,0690---- 177,5------- 160--------- 150,0
0,0700---- 180--------- 162--------- 151,9
0,0710---- 182,5------- 164--------- 153,8
0,0720---- 185--------- 166--------- 155,6
0,0730---- 187,5------- 168--------- 157,5
0,0740---- 190--------- 170--------- 159,4
0,0750---- 192,5------- 172--------- 161,3
0,0760---- 195--------- 174--------- 163,1
0,0770---- 197,5------- 176--------- 165,0
0,0780---- 200--------- 178--------- 166,9
0,0790---- 202,5------- 180--------- 168,8
0,0800---- 205--------- 182--------- 170,6
0,0810---- 207,5------- 184--------- 172,5
0,0820---- 210--------- 186--------- 174,4
0,0830---- 212,5------- 188--------- 176,3
0,0840---- 215--------- 190--------- 178,1
0,0850---- 217,5------- 192--------- 180,0
0,0860---- 220--------- 194--------- 181,9
Mrs. Juice
Mixxer
Venom Performance
HogNutz Racing
LR Motorsports
post #8 of 18 (permalink) Old 05-13-2010, 02:57 PM Thread Starter
As of now, my carb is 100% stock, my elevation is roughly 1200ft. so does the 185main, 50 pilot, fuel screw 2.5 out and needle on middle still sound good?
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #9 of 18 (permalink) Old 05-13-2010, 03:18 PM
pittsm's Avatar
sounds good, but i'd just put a hrc jet kit in it.
_______________________________
2005 Honda 450R Black (SOLD)
Slightly Modified
2003 Honda CBR F4I
Also Slightly Modified
pittsm is offline
post #10 of 18 (permalink) Old 05-14-2010, 03:09 PM Thread Starter
im confused, i thought the HRC jet kit came with that?
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #11 of 18 (permalink) Old 05-14-2010, 11:31 PM Thread Starter
thaks for the help
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #12 of 18 (permalink) Old 05-17-2010, 08:12 AM
pittsm's Avatar
im confused, i thought the HRC jet kit came with that?[/b]
it does but you get the needle. which makes quite a bit of difference.
Slightly Modified
2003 Honda CBR F4I
pittsm is offline
post #13 of 18 (permalink) Old 05-17-2010, 03:57 PM Thread Starter
sorry for all of the questions, but is there any power gains on buying the hrc jet kit?
I'm real tight for money..
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #14 of 18 (permalink) Old 05-22-2010, 09:28 PM Thread Starter
talked to my local honda shop and ended up getting the HRC Jet kit. It came with the 185 main and the new needle. the guy i talked to said that o did not need a new pilot jet, but i thought i needed a 50 pilot or somthing bigger. What do you think, i haven't rode it yet, i will tomarrow though(hopefully)
2005 Trx450r
12:1 comp
Sparks exhaust
Stage 1 HC
2007 crf450r
post #15 of 18 (permalink) Old 05-24-2010, 08:56 AM
pittsm's Avatar
yea you may need to bump it up to a 50
Slightly Modified
2003 Honda CBR F4I
pittsm is offline
