Ring placement? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 8 (permalink) Old 04-15-2010, 12:06 AM Thread Starter
It's about time to put my top end back together, and I've always been kinda curious about piston ring placement. I know that it's smart to keep the top two compression rings on the cool side (intake side) of the head, but exactly how far apart should the ends be. 90 degrees or is there someone out there who has a different idea?- and what about the oil rails? I'm dealing with a set of low tension rings. How do you place them?
Stock
doogy71 is offline
post #2 of 8 (permalink) Old 04-15-2010, 01:13 AM
pgreenlaw's Avatar
Send a message via Yahoo to pgreenlaw
Stock suspension, stock swinger :(
Cheap, Fast, Reliable. You can only choose 2. Which do you choose?
pgreenlaw is offline
post #3 of 8 (permalink) Old 04-15-2010, 01:34 AM
I always put the top 2 rings in with the gaps 180° apart
Both gaps are lined up with the NON thrust side of the cylinder.
Oil ring gaps are 120° apart (but really don't matter)
damcgo is offline
post #4 of 8 (permalink) Old 04-15-2010, 02:41 AM Thread Starter
Oil ring gaps are 120° apart (but really don't matter)[/b]
So are you saying that you line up the top 2 with the wrist pin ends?
Stock
doogy71 is offline
post #5 of 8 (permalink) Old 04-15-2010, 02:44 AM Thread Starter
Thanks for the diagram Pgreenlaw!!!
Stock
doogy71 is offline
post #6 of 8 (permalink) Old 04-15-2010, 10:58 AM
450RRR's Avatar
it doesnt really matter all that much...
90*, 180* etc..... just dont line them up together....
remember...on a 4-stroke... these rings MOVE round/round...so where you place them at first...is not where they remain.... but placing them at least 90* away from each other will help reduce them from lining up during the break in procedure....
jmho....g
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #7 of 8 (permalink) Old 04-15-2010, 12:25 PM
Cane Rider!
Thrown Stones's Avatar
jmho....g[/b]
Spot on Greg!
Thrown Stones is offline
post #8 of 8 (permalink) Old 04-16-2010, 12:28 AM Thread Starter
Thanks for the advice guys!!!! I never really thought about the rings moving or changing positions during use, but I guess I never really bothered to notice where they actually were positioned during disassembly.
Stock
doogy71 is offline
