adjusting idle - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 14 (permalink) Old 04-09-2010, 02:12 PM Thread Starter
trx450r_pro's Avatar
how do i adjust the idle? my trx450er doesn't like to start up right away but, if i ride alot that day and its nice and warm starts right up. hope it's just the idle. where is the idle?
2007 450er
Gt thunder Front Revalves for 175 Lb Rider
Ella stage 5 rear shock
Ella rear linkage
Houser swing arm
Stage 2 Hot cam
Kick start conversion by TSI
CFM Aluminum air box
HRC Jet Kit
Uni Air Filter
Full Rossier Exhaust
Green Wire mod
G force +2 Rear axel
ASR +2 Front a arms with 05 Spindle and Hub conversion.
AC Pro Peg Nerfs.
Maxis Razrs
Hipper rear bead lock wheels
2002 Honda 400 foreman
2005 Honda 650 rincon
trx450r_pro is offline
post #2 of 14 (permalink) Old 04-09-2010, 02:41 PM
Fairly fast foreigner!
OTMTRX's Avatar
RHS under tank....black knob.
'06 TRX450ER, '03 XR400r, '04 CRF450r, '05 CRF250r, '06 CBR1000RR (StreetFighter), 07 GSX-R750, '71 CB500, '75 CL360 (Honda Scrambler), '81 Virago XV750 (the 110 Bike).
06 Black TRX450ER (Conv to kicker) "Medium" Big bore! Quikshrk (OCP), Demon, REAZ bits.
OTMTRX is offline
post #3 of 14 (permalink) Old 04-09-2010, 04:10 PM
zibilich's Avatar
mine has the same problem, ive messed with the idle screw and it didnt really help it much...
lemme know what happens when you adjust it...
2007 TRX450ER-Dasa-Pro Armor-Pro Taper-HRC-CST Ambush-CP 13.1-HRE Porting-Tusk-Hinson
zibilich is offline
post #4 of 14 (permalink) Old 04-09-2010, 07:23 PM
Just curious did zibilich or trx450 change your pilot if and when you added a exhaust , I tryed not changing pilot and I had starting issues , one guy on here told me to put choke on , pump throttle twice and kick , and it started on first kick . After that I changed pilot , adjusted and it starts usually 1st kick or 2nd at the most from a cold start
05 450R
Terry Design Concepts Full exhaust
Jetted
EHS Airbox Lid
Stage 2
Working on shock rebuild
Hiper Tech 3s
Razr on back Razr2 on front
337/450r is offline
post #5 of 14 (permalink) Old 04-20-2010, 04:17 PM
zibilich's Avatar
Just curious did zibilich or trx450 change your pilot if and when you added a exhaust , I tryed not changing pilot and I had starting issues , one guy on here told me to put choke on , pump throttle twice and kick , and it started on first kick . After that I changed pilot , adjusted and it starts usually 1st kick or 2nd at the most from a cold start[/b]
i personaly havnt touched anything on the bike but the idle switch, but no telling what the previous owner did, or what the person who cleaned my carb did..
and i dont wanna dive into the carb changing needles and changing fuel screw not know what or how to do it..
zibilich is offline
post #6 of 14 (permalink) Old 04-20-2010, 04:21 PM
pittsm's Avatar
here's what i do from a cold start, push kicker down slow 2-3 times to prime everything. then choke full on, one good hard kick, starts everytime. NO THROTTLE. then after it starts start adjusting down choke until it will idle on its own with no choke, (takes about 30 seconds).
_______________________________
2005 Honda 450R Black (SOLD)
Slightly Modified
2003 Honda CBR F4I
Also Slightly Modified
pittsm is offline
post #7 of 14 (permalink) Old 04-20-2010, 06:13 PM
zibilich's Avatar
I have a 2007er.. so there is no kicker.. =/
zibilich is offline
post #8 of 14 (permalink) Old 04-20-2010, 10:28 PM
Idle screw is near black knob, near ur choke. Or if not, u could tamper with the throttle on ur bars. My idle screw used to work all the time. Now it just turns and turn and turns but has no effect on the throttle anymore. Any clue as to wat mighta happened?
trxwoobie is offline
post #9 of 14 (permalink) Old 04-21-2010, 08:51 AM
pittsm's Avatar
I have a 2007er.. so there is no kicker.. =/[/b]
sorry, missed that part.
Slightly Modified
2003 Honda CBR F4I
pittsm is offline
post #10 of 14 (permalink) Old 04-27-2010, 09:12 AM Thread Starter
Idle screw is near black knob, near ur choke. Or if not, u could tamper with the throttle on ur bars. My idle screw used to work all the time. Now it just turns and turn and turns but has no effect on the throttle anymore. Any clue as to wat mighta happened?[/b]
i have no idea what happened its slowly been getting worse. could it be because i run regular gas? im thinking i have to ajust my pilot
2007 450er
Ella rear linkage
Houser swing arm
Stage 2 Hot cam
HRC Jet Kit
Uni Air Filter
Green Wire mod
AC Pro Peg Nerfs.
Maxis Razrs
post #11 of 14 (permalink) Old 04-27-2010, 09:42 PM
rockstar450r's Avatar
I had a problem with my 05 not wanting to start especially when it was cold out. And it even idled high. My problem was that I needed the valves to be re-shimed. Just a thought if you wanted to check that out.
NEVER RIDE FASTER THAN YOUR GAURDIAN ANGEL CAN FLY
05TRX450R
Full 06 Two Brothers Titanium Racing Exhaust
HRC Kit
185 main
Open Air Box
K&N Filter
Tusk Performance Clutch
Tusk Heavy Duty Springs
Quad Force Brake Block Off
rockstar450r is offline
post #12 of 14 (permalink) Old 04-27-2010, 11:11 PM
450RRR's Avatar
sorry....but I cant resist anymore...
Dude... like so many of your posts..... I cant figure out what the HAIL your talking about.....
the black knob that adjusts your idle speed is under the RIGHT side of your fuel tank, mounted to the black plastic tank protector.... no where NEAR your choke... which should be a yellow knob on a shaft which protrudes from the LEFT side of your FCR carb.....
why 'your' idle screw no longer has any effect on the throttle is anyone's guess... cuzz we dont know what your talking about when you say "idle screw"??????
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #13 of 14 (permalink) Old 05-10-2010, 02:50 AM
sandaddik2's Avatar
well i know that the idle screw on mine is pretty much next to the choke but mine is an 05 and not an fcr so maybe a different carb? because i believe they changed carbs in 06+
sandaddik2 is offline
post #14 of 14 (permalink) Old 05-11-2010, 09:41 PM
450R XC Rider
450rquadrider's Avatar
Location: Ashland, Virginia(Currently in Blacksburg, VA Go HOKIES!!)
What pilot are you running and when you say "regular gas" do you mean 87 octane? That is too low. I hope you mean the "regualr" 93 octane from your local gas station.
07 450er- HMF, Powermadd, ASV, ITP, Holz, Uni, Pro Armor, Pro Taper, Streamline, Tusk, Teixeira Tech, Laker Customs, Oury, GT Thunder
450rquadrider is offline
