which clutch kit - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 22 (permalink) Old 03-24-2010, 04:49 PM Thread Starter
which clutch kit have u guys had the most success with? i need a new clutch and was wondering what company has the least sliping, longest lasting clutch?
redfour504life is offline
post #2 of 22 (permalink) Old 03-24-2010, 05:01 PM
450RRR's Avatar
I just use the CHEAP 'tusk' kits.... about $45 and they last ME a LONG time....
jmho.....g
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #3 of 22 (permalink) Old 03-24-2010, 05:11 PM
Colt801's Avatar
^^^ x2 tusk is cheap and preforms well, if you want the best of the best Hinson and Rekluse.
Colt801 is offline
post #4 of 22 (permalink) Old 03-24-2010, 05:25 PM
kfxguy's Avatar
the absolute best clutch you can get is the barnett carbon fiber...not the kevlar...the carbon fiber. The next best thing is a stock honda clutch with stiffer springs. i think tusk sell those seperately. Just so you know, the Z400, Kfx400, Dvx400 AND 450r all share the same clutch fibers. The steels are splined different. the 450r fibers are an upgrade for z400 owners. The stock 450r fibers are actually some really good fibers. My tusk clutch lasted quite a while until i sank my bike a couple times and then transplanted the tusk used clutch to my newly built 470 big bore stroker. They didnt last long after that. So for $45 bucks, you cant beat that kit.
KFX525 (basically a ltz400...and yes it still has reverse!)
64.33hp 41.57tq
+10mm stroker, 96mm ice cube, cp piston
13 paddle extremes, Hsr 48mm carb, big custom webs, ported and welded head, titanium valves, titanium wrist pin. Plus 8 swinger, drag axle, drag stem, carbon fiber bars, A few more things. 275lbs wet. Yep it's still heavy, but it's a duner!
kfxguy is offline
post #5 of 22 (permalink) Old 03-24-2010, 09:25 PM
good to hear about the tusk kit. I will be needing a new kit soon, but thought it would be a waste of money since it was so cheap compared to other steel and fiber kits out there. Does the tusk kit come with the extra fiber so that i can remove the judder spring?
2006 TRX 450ER
steveo413 is offline
post #6 of 22 (permalink) Old 03-24-2010, 10:22 PM
sb/ss pump gas kickin ass
bigcountrydude's Avatar
the absolute best clutch you can get is the barnett carbon fiber...not the kevlar...the carbon fiber. The next best thing is a stock honda clutch with stiffer springs. i think tusk sell those seperately. Just so you know, the Z400, Kfx400, Dvx400 AND 450r all share the same clutch fibers. The steels are splined different. the 450r fibers are an upgrade for z400 owners. The stock 450r fibers are actually some really good fibers. My tusk clutch lasted quite a while until i sank my bike a couple times and then transplanted the tusk used clutch to my newly built 470 big bore stroker. They didnt last long after that. So for $45 bucks, you cant beat that kit.[/b]
X2. got barnett cluth plates and springs w/ stock basket. works good.
#224
Chrome valve stem caps.
#RememberTheBuster
bigcountrydude is offline
post #7 of 22 (permalink) Old 03-25-2010, 08:10 AM
pittsm's Avatar
jmho.....g[/b]
x3
_______________________________
2005 Honda 450R Black (SOLD)
Slightly Modified
2003 Honda CBR F4I
Also Slightly Modified
pittsm is offline
post #8 of 22 (permalink) Old 03-25-2010, 10:10 AM
TRX450R14's Avatar
I an running the "Dirt Digger" (Barnett) .....I can't remember if it is the Kevlar or CF but it has held up great so far.... the OEMs are good quality too....I just wanted to try the Barnett kit out because it comes with 20% stiffer springs...and it works great. ...stiffer springs are a plus no matter which kit you go with.
Team X Racing....we don't just race....we ride.
There's no room for "one trick ponies" in our stable.
Walk softly and carry a big stick.
True power IS in the head....it's called a brain.
2011 1/8th mile ATV Drag video...
The fastest,most reliable trail quads on the east coast.
TRX450R14 is offline
post #9 of 22 (permalink) Old 03-25-2010, 10:17 AM
cisco450er's Avatar
good to hear about the tusk kit. I will be needing a new kit soon, but thought it would be a waste of money since it was so cheap compared to other steel and fiber kits out there. Does the tusk kit come with the extra fiber so that i can remove the judder spring?[/b]
I don't believe they come with an extra fiber. I have a Driveline clutch kit, a little heavier duty than Tusk and still kinda on the cheap side, and it also did not come with the extra fiber.
2007 450ER Black MINE! :
HRC Complete Kit, ASV Levers, K&N Filter w/ Outerwear, Blingstar Iron Cross Front Bumper, Pro Taper 1 1/8 Contour Bars, Rock Nerfs, Trail Tech Lights and Mount, Driveline Clutch
2000 KTM 300EXC: This sumbitch will be the end of me!
cisco450er is offline
post #10 of 22 (permalink) Old 03-25-2010, 12:00 PM
So are there any kits that do come with the extra fiber? Or is there a way to get tusk or driveline to send an extra one? The other option i guess would be to buy an OEM kit and then order another #7 fiber.
2006 TRX 450ER
post #11 of 22 (permalink) Old 03-25-2010, 12:49 PM
450RRR's Avatar
I assume your talking about the Judder spring mod?
if so...just re-use one of your older fibers when replacing.... it shouldnt cause any type of problem if not worn down to the hub....
jmho......g
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
450RRR is offline
post #12 of 22 (permalink) Old 03-25-2010, 01:33 PM Thread Starter
well its good to hear many of u have had good luck with the cheap tusk kits but all i know is that my OEM lasted me 5 years with the clutch i learnt on and tought several others on too. so i might just go with the OEM.
post #13 of 22 (permalink) Old 03-25-2010, 01:48 PM Thread Starter
if i were to go with OEM what item(s) would i need on the list of any oneline OEM parts catalog? i couldnt find any one or two(either both plates as a pakage or fibers and steels) listed anywhere. and what site(like ronnies or service honda) would be the cheapest, parts plus shipping?
post #14 of 22 (permalink) Old 03-25-2010, 02:18 PM
Solid Gold DASA500R!
badinblack's Avatar
its all about trial and error when it comes to these clutch kits. i tried a tusk a couple years ago that lasted me only 3 trips went to oem which lasted me a year or so. then i tried tusk again, and again it smoked in two trips. now i will only use crf oem clutch kits for my drag bike.
i do believe on a mild build the tusk kits would work great!
Ordinary people, simply doing their jobs, and without any particular hostility on their part, can become agents in a terribly destructive process. Moreover, even when the destructive effects of their work become patently clear, and they are asked to carry out actions incompatible with fundamental standards of morality, relatively few people have the resources needed to resists. -Milgram
R.I.P. Jesse aka Jay Dash you were a great friend for sure! and always will be
badinblack is offline
post #15 of 22 (permalink) Old 03-25-2010, 02:30 PM
Send a message via AIM to darmo21
I have a Trinity Heavy Duty clutch kit ( plates, fibers, springs ) I have been running this set up since april or may of 2009 I think and it has been great so far. No slipping and puts all them power down~! Only time will tell however! It was kinda pricey though.......
I run this kit with a Hinson inner hub and basket. Stock pressure plate.
2003 Raptor 686cc Black & Red : JE 11:1, Ported & Polished Head, GYTR Inner Hub, D.I.D. Chain
2001 CR 125 : FMF Gold Series, V Force 3 Reed Valve
All Black 2006 TRX 450er
Dasa Classic
Hot Cam II
K & N Air Filter, No Air box Lid
HRC Jet Kit
Green Wire Mod
Hinson Clutch Basket
Hinson Inner Hub
Trinity Racing HD Clutch Kit
Lonestar Dual Row Axle Carrier
All 6 Wheels ITP C Series Sport Polished
Rear Tires ITP XCR, Rear Paddles ITP SandStarr, Front Tires ITP GNCC
Pro - Taper Bars
DG Grab Bar
darmo21 is offline
