06 trx 450r stock jetting - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 11 (permalink) Old 01-19-2010, 11:14 PM Thread Starter
I had the baffle out and no airbox lid with the k&n filter but now i put the baffle and arrestor back in and the air lid back on to make it quiet again which is why i need the stock jetting for it. I think all i did was change the main jet and it is running fine now until you hit WOT, then it runs crappy, im guessing its running rich.
dreth is offline
post #2 of 11 (permalink) Old 01-19-2010, 11:30 PM
cheapfast450r's Avatar
06 had a 121 main
drag bike 06 450ER
Powered by
Racers Edge, AZ
SS/SB
4.42 in 300'
trail bike 07 450ER
SS/SB
powered by
spare parts
cheapfast450r is offline
post #3 of 11 (permalink) Old 01-19-2010, 11:48 PM
06 had a 121 main[/b]
120
vaughn fitzpatrick is offline
post #4 of 11 (permalink) Old 01-20-2010, 01:21 AM
tks., i've allway's been off one click....
drag bike 06 450ER
Powered by
Racers Edge, AZ
SS/SB
4.42 in 300'
trail bike 07 450ER
SS/SB
powered by
spare parts
post #5 of 11 (permalink) Old 01-20-2010, 08:03 AM Thread Starter
I will check the main that is in it today and get it right.
dreth is offline
post #6 of 11 (permalink) Old 01-20-2010, 08:44 AM
andrew.k's Avatar
Send a message via AIM to andrew.k Send a message via Yahoo to andrew.k
mine was like a 118 and its an 06
now its a 162 i think that came with the hrc kit
2006 HRC 450ER-sold
2005 ELKA HOUSER GIBSON TRX450R
andrew.k is offline
post #7 of 11 (permalink) Old 01-20-2010, 10:12 AM
now its a 162 i think that came with the hrc kit[/b]
Its a 120
post #8 of 11 (permalink) Old 01-20-2010, 12:19 PM
450RRR's Avatar
stock 06/07... 120 main, 42 slow (pilot) jet, about 2 3/8 turns out on pilot screw, 70 leak jet, NHHU (non adjustable) needle
stock 04/05....118 main, 48 slow jet, unknown (adjustable on mid clip) needle, and non removable leak jet...
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #9 of 11 (permalink) Old 01-20-2010, 08:12 PM Thread Starter
It had a 185 main in it so i only dropped it down to 165 and it runs great. Maybe the green wire mod and k&n air filter are whats making it want more fuel.
dreth is offline
post #10 of 11 (permalink) Old 01-21-2010, 08:37 AM
450RRR's Avatar
I personally dont think so........ but then again... not sure why it needed a 185 either.... unless someone mistakenly jetted it like an 04/05 machine...
hey, if you like how she runs... who cares what is stamped on the jet.... thats my theory, BUT, a 165 is a bit much IMHO, when using the stock air box and LID ON.....
jmho.....g
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
450RRR is offline
post #11 of 11 (permalink) Old 01-21-2010, 06:22 PM Thread Starter
jmho.....g[/b]
I agree with you on both. Id rather it run rich because its my practice bike and the longer it runs the better it is for me.
dreth is offline
