hot rods stroker crank question - Honda TRX Forums: Honda TRX 450R Forum
 1Likes
  • 1 Post By want2bfast
post #1 of 13 (permalink) Old 01-02-2010, 03:01 PM Thread Starter
redrider74's Avatar
well the crank on my 05 finally went so I think I'm gonna go with a hot rods +3mm stroker crank. I've heard a lot about them on here and I think it's a good idea. But I have a couple questions...
about how much hp will this add with a HCS3, an exhaust, and an intake as supporting mods?
does the crank come with the 2 crank bearings?
can you run this crank with the stock crank bearings?
which bearings are better quality?
if i'm running a stock piston is it necessary to have it balanced?
and what aftermarket pistons would be safe to run not having the crank balanced?
any help with these questions would be much appreciated!
2005 Black Kicker
Alba Exhaust
HCS2
Venom HVP Head
JE 12:1
Potred ESR Intake
Elka/Laeger Long Travel
Lonestar Rear End
Other Goodies...
redrider74 is offline
post #2 of 13 (permalink) Old 01-02-2010, 03:09 PM
OCP
Oregon Coast Powersports
OCP's Avatar
Send a message via Yahoo to OCP
yes you can use oem bearings and i believe they are superior, but the crank doesn't come with them. it is not 100% necessary to balance the crank, but thats never a bad idea. the tolerances of the cranks make it impossible to guess which pistons will be "balanced" . some are better than others. i would guess 5-6 over stock with the mods you have listed, but then again all exhausts and intakes arent the same.
OCP is offline
post #3 of 13 (permalink) Old 01-02-2010, 03:15 PM
Desert Racer
D Bergstrom's Avatar
That one I have no idea, maybe someone else can chme in.
No.
Yes, I have run mine with OEM bearings and seals since day one.
I would run OEM, I have heard of some failures with the Hot Rods.
No, see my responce below.
To be honest, you can run it with any aftermarket piston and not balance it. I have had my Hot Rods stoker crank installed in one of my 450r's for over two years and have not had any problems with it. I took it out of the box and installed it. I ran it for the first year with a stock bore Wiseco 11.5:1 piston, then since then I have been running it with a Cylinder Works big bore kit. I am sure some people will tell you you must ballance it, but from my experiance, I have not found it to be nessasary. (I bet my stoker crank as at least 150 hours on it.) If you have the extra money and time, by all means get it ballanced, but I do not think it is a "must do".
Doug
2004 TRX450R, 2008 TRX700XX
(BITD #639 Quad Ironman Expert)
2015 sponsors: Teixeiratech.com, Motowoz.com, Snailmotorsports.com, My bank account.
2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #4 of 13 (permalink) Old 01-02-2010, 03:23 PM
hondaman01's Avatar
i agree with doug, balancing isnt a must but if you got the money and time to wait for it then i would, mine is balanced and its really smooth its smoother than stock
i had 2 friends with stroker cranks that wasnt balanced (but these where in 06+ bikes) and 1 had a stock piston and the other had a venom 14:1 stockbore and they both vibrated noticeably more than stock
but again mine is a 04 so i dunno if the year models would change anything because they are 2 different cranks
hondaman01 is offline
post #5 of 13 (permalink) Old 01-02-2010, 03:37 PM
Cane Rider!
Thrown Stones's Avatar
All great replies. The new HR crank comes with the thrust side collar, used with the
purchase of your choice (OEM Bearings). And a thrust side crank seal. This seal has
a larger I.D. Needed for the added diameter, on the crank end.
Thrown Stones is offline
post #6 of 13 (permalink) Old 01-02-2010, 03:43 PM Thread Starter
redrider74's Avatar
thanks for all the fast and detailed responses guys! much appreciated
2005 Black Kicker
Alba Exhaust
HCS2
Venom HVP Head
JE 12:1
Potred ESR Intake
Lonestar Rear End
Other Goodies...
post #7 of 13 (permalink) Old 01-02-2010, 03:46 PM Thread Starter
redrider74's Avatar
thanks for all the fast and detailed responses guys! much appreciated[/b]
one more quick question guys... is there a way to measure your stock timing chain to see if its stretched?
2005 Black Kicker
Alba Exhaust
HCS2
Venom HVP Head
JE 12:1
Potred ESR Intake
Lonestar Rear End
Other Goodies...
post #8 of 13 (permalink) Old 01-02-2010, 03:55 PM
Super Moderator
want2bfast's Avatar
Send a message via Yahoo to want2bfast
For 40 bucks put a new one in...
xowner likes this.
want2bfast is offline
post #9 of 13 (permalink) Old 01-02-2010, 05:23 PM
OCP
OCP's Avatar
ya its pretty cheap and definitely a good idea to replace the timing chain. for future reference you could use a caliper to measure a series of links of a new chain. then, the next time you are in there you could remeasure and see how much stretch there is.
OCP is offline
post #10 of 13 (permalink) Old 01-03-2010, 07:34 AM
450RRR's Avatar
for the most part, the 'stretch' of the timing chain is not nearly as predominate as this particular chain is more prone to KINK rather than stretch. If you can hold the chain in your hand and roll it around w/o noticing any KINKS in it, your probably good to do.... but then again.... $35 for a new one? is a no brainer.... but I have often reused my timing chain until which time it develops the typical 'kink' and then it's time for a new one....
the HR stroker crank, WAS, a hit or miss deal.....some guys put them in and they were as smooth as butter, others not so lucky and the crank caused some terrible vibrations..... bottom line was 'some were good, some were bad'.... so most chose to have them balanced before installation JUST to be SURE......
as for the piston.... any piston will work and does not need to be balanced to a thumper crank..... there are many posts on this issue....
jmho....g
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #11 of 13 (permalink) Old 01-03-2010, 11:18 AM
thunder71173's Avatar
Send a message via Yahoo to thunder71173
if it has any kinks in it replace it. I dont care for the hot rods stroker cranks I just had a buddy break another one in half. They have a problem with them an wont admit it. Save yourself the heartache and put an oem or a falicon in if your going to do it. btw thier bearing are junk as well.
http://www.maultechatv.com/sponsoredriders...Clark/index.php
61 hp 38 tq
2009 Sponsors
MAULTECH ATV
JC RACING ENGINES
HINSON Clutch Components
ASV INVENTIONS
FASST COMPANY
AMSOIL
GAERNE BOOTS
RK RACING CHAINS
SPY OPTIC
THQ ATV vs MX<span style="font-family:Comic Sans MS">Reflex
661
TAG METALS
TWIN AIR
ODI GRIPS
thunder71173 is offline
post #12 of 13 (permalink) Old 01-06-2010, 09:40 AM
TRX450R14's Avatar
if it has any kinks in it replace it. I dont care for the hot rods stroker cranks I just had a buddy break another one in half. They have a problem with them an wont admit it. Save yourself the heartache and put an oem or a falicon in if your going to do it. btw thier bearing are junk as well.[/b]
A single cylinder crankshaft tha has broken in half would certainly dictate a severe problem of some sort....and since you stated "another one"....which suggests it has happened twice,I would be extremely concerned with a heck of a lot more than the notion that the crank itself was to blame.
feel free to go through the stickied HR +3 thread....you will notice that the majority of us who run them are more than happy with the power/durability experienced with them.
Team X Racing....we don't just race....we ride.
There's no room for "one trick ponies" in our stable.
Walk softly and carry a big stick.
True power IS in the head....it's called a brain.
2011 1/8th mile ATV Drag video...
The fastest,most reliable trail quads on the east coast.
TRX450R14 is offline
post #13 of 13 (permalink) Old 01-06-2010, 12:36 PM
Cane Rider!
