Jetting after Full Exhaust and Air box mod?? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 11 (permalink) Old 10-12-2009, 09:53 PM Thread Starter
Ok here's the deal, I want to save time with the jetting and hopefully start with a jet close enough I wont have to take the carb on and off 5 times. I was wondering if anyone has done similar mods and what your take on the jetting is.. I have a Full Akrapovic Racing & Evolution Exhaust System, and instead of removing the lip completely I cut and inserted (6) 1'' foam inlets for more breathing for my 2007, and the stock main jet was at -120- and the Pilot was at -42- I bumped the main up three sizes to a -128- and the pilot one size to a -45-, is that going to be enough? I heard of another trx rider on his 06 by just removing the air box and a full exhaust he was at 180+ on the main. I'm asking this because I want to limit the amount of times I pull the carb if someone can just get me close.
2007Desert450R is offline
post #2 of 11 (permalink) Old 10-12-2009, 10:22 PM
ironarmscott's Avatar
Send a message via MSN to ironarmscott
162 main and 45 pilot air screw 2 to 2 1/4 turns
06
ROSSIER SYSTEM
LID OFF WITH UNI AND OUTERWEAR
162 main 48 pilot 55 leak 2.5 turns out
PRO ARMOR NERFS HEAL GUARD AND FAT PEG
QUAD TECH SEAT
JE 13.5 PISTON
FOX FLOATS FRONT FOX PODIUM X REAR
FOUR PLAY ARMS 2.5 MGC
FOUR PLAY SOFT BARS
JB SWING ARM
PRECISION STEERING STAB.
LONE STAR AXLE AND NUT
LONE STAR CARRIER DUAL BEARING
KICKER CONVERSION
R&D AIR SCREW
QUAD TECH HOOD
stock front sprocket/rear one tooth bigger
GREEN WIRE MOD
ASV CLUTCH LEVER
ALL LIGHTS AND ELECTRIC FAN GONE
ironarmscott is offline
post #3 of 11 (permalink) Old 10-12-2009, 10:26 PM
plus needle clip 3 down should be good
06
ROSSIER SYSTEM
QUAD TECH SEAT
JE 13.5 PISTON
FOUR PLAY SOFT BARS
JB SWING ARM
KICKER CONVERSION
R&D AIR SCREW
QUAD TECH HOOD
GREEN WIRE MOD
ASV CLUTCH LEVER
post #4 of 11 (permalink) Old 10-12-2009, 10:35 PM
450r Dunner
jimmy450r's Avatar
^^^ that should get you close (depending on how much more air your going to get through the lid)
you have a picture of the 1" holes and foam ? im curious how it turned out
06 trx450r
2013 crf450r
2009 crf150r
08 trx400ex
08 trx250ex
2011 rzr S LE
jimmy450r is offline
post #5 of 11 (permalink) Old 10-13-2009, 01:51 PM
Cane Rider!
Thrown Stones's Avatar
you have a picture of the 1" holes and foam ? im curious how it turned out[/b]
Maybe these? I have about 10 installed. Don't know for sure if they help or not.
Thrown Stones is offline
post #6 of 11 (permalink) Old 10-14-2009, 09:01 PM Thread Starter
I live in arizona as far as jetting and mixture goes, so am I hearing right that i'm going to have to jump from a 120 stock main jet to a 162??? from only a full exhaust and air box mod? and i"ll post some pics later tonight when I install the filters on the box. There (6) 1'' foam cut outs that snap in (obviously require dirlling), you can get them off the PU catalog and most parts dealers might carry them. The thing is there is only so much that can be accomplished I honestly think six of those will be the same as 3 because the inlet in the carb can only take so much volume anyways that it has to become excessive as some point. Its only going to suck in so much air at a time anyways.
Also my R didnt come with an adjustable needle. which pissed me off a little.. does anyone know if the CRF450R's needle is compatible with the TRX450R's. there almost identical carbs same size also. flat slide roller.
post #7 of 11 (permalink) Old 10-14-2009, 09:21 PM
450r Dunner
jimmy450r's Avatar
alot of people running NO air box lid and K&N filters for the MAX amount of air possible
cutting 6 of the little filters into the top of a lid will probably still be the choke point in the flow
162 may be a little big but I have no idea how much flow your going to get from your lid
(it would be about right for no lid)
06 trx450r
2013 crf450r
2009 crf150r
08 trx400ex
08 trx250ex
2011 rzr S LE
post #8 of 11 (permalink) Old 10-15-2009, 12:27 AM
i had a 155 w/ no lid and a k&n and it wasn't enough, switched to 185 and it feels outstanding.
'04 TRX450r
mnik935 is offline
post #9 of 11 (permalink) Old 10-15-2009, 07:49 AM
450r Dunner
jimmy450r's Avatar
i had a 155 w/ no lid and a k&n and it wasn't enough, switched to 185 and it feels outstanding.[/b]
what year?
06 trx450r
2013 crf450r
2009 crf150r
08 trx400ex
08 trx250ex
2011 rzr S LE
post #10 of 11 (permalink) Old 10-15-2009, 10:34 AM
I live at 5500ft and my 05 450r runs a 168 main 48 pilot 2 1/4 turns out on mixture
05 450r
Quadnut20 is offline
post #11 of 11 (permalink) Old 10-15-2009, 12:02 PM
450RRR's Avatar
most of us dont run those mini filter plugs used back in the day.......
they were once quite popular on the older two strokes....and we would oil them up as well to help stop some of the dirt from entering the air box....but usually 'most' of us would use about twenty of them dang things.....it never seemed like six were enough.....
so...with that being said...I dont believe your gonna quite get the flow your looking for with just six.... hence the reason why most choose to either just remove the lid....or use some type of air box eliminator kit.....
so any jetting recommendations would just be guessing on my part....
however.....plan on anything between 130 and 160.....
or...add another dozen or so of those mini-filters and go with 162 main and maybe 45 slow jet.... but if it were me...and I wanted to eliminate the guess work.... just buy an HRC jet kit.... remove the lid for NOW..... and have fun... then mod your lid as you see fit but adding as many of those filters as you need until she runs correctly (not rich) after installing the HRC kit....
plus...the HRC kit will give you a nice adjustable needle as well...... .and no, the 06/newer machines do not come with adjustable needles....
if going this route....dont use a #45 slow jet (pilot)...the NGPR needle will be sufficient for increasing the fuel at low/mid rpms....
jmho.....g
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
