smoking and using oil - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 6 (permalink) Old 09-20-2009, 11:02 AM Thread Starter
jesseray6537's Avatar
Send a message via Yahoo to jesseray6537
my buddy has a 05 with 13.1 weisco, stg2 hc, full exhaust, new head....
this thing smokes really bad when he lets of the gas and its using a lot of oil
any ideas what may be causeing this?
WHITE 2007 TRX450ER:
PORT AND POLISHED
STAGE 2 HOT CAM
ATHENA PISTON STOCK COMP.
FULL LRD PRO4R EXHAUST
LRD PERFORMANCE JET KIT
BIG GUN REV BOX
PRO DESIGNED INTAKE KIT WITHOUT LID
PARKING BRAKE BLOCK OFF
AIR MIXTURE SCREW
15T FRONT
36T REAR
jesseray6537 is offline
post #2 of 6 (permalink) Old 09-20-2009, 12:10 PM
bama450r's Avatar
What do you mean by new head? Were the valves and seals replaced?
bama450r is offline
post #3 of 6 (permalink) Old 09-20-2009, 01:14 PM Thread Starter
his old one had a small crack in it so he had to get a new one, but it was smoking and using way to much oil before that
PORT AND POLISHED
STAGE 2 HOT CAM
BIG GUN REV BOX
AIR MIXTURE SCREW
15T FRONT
36T REAR
post #4 of 6 (permalink) Old 09-20-2009, 05:15 PM
Typically when a lot of oil is consumed it means the rings have a bad seal, letting oil in the combustion chamber, hence the smoke. Check the piston rings!
05 trx450r
Full Sparks exhaust
CW 480cc cylinder
Venom 12.4:1 97mm piston / Balanced Honda revised crank
Stage 2 hotcam
CRF450 clutch / CR500 springs / Trinity cover
UNI filter
Cut airbox lid w/ outerwears
R&D Fuel screw (2 turns out)
Jetting : 185 Main, 50 pilot, HRC needle third clip
Fox FLOAT Evol shocks / Lonestar DC4 arms
Pro-taper bars / Fly grips / Powermadd guards
Moose bumper
Maxxis Razr tires
D3n1s is offline
post #5 of 6 (permalink) Old 09-20-2009, 05:31 PM
I wish I was QUIK. . . .
hoser's Avatar
As stated, it's probably the rings. I have seen rings pinched while installing the piston into the cylinder and that will cause severe smoking.
Does the head have new valve seals? That could also be an issue, but usually valves seals will not cause that much smoke.
2005 450R
Black everything, Faster
2005 450R
Black everything, Slower
2004 450R
Under the knife. . . . . .
hoser is offline
post #6 of 6 (permalink) Old 09-20-2009, 06:22 PM
D3kTrix's Avatar
Send a message via AIM to D3kTrix
Another vote for bad rings.
05 450r
Motowoz LT F&R / SMC +3 / Elka Pro Dual Link / RPM / Flexx / Rath / Douglas
DRG Head / Ferrea +1x4 / CP 12:1 / 05 HRC Cam / HR +3 Balanced / DRG 43.5 FCR / Sparks Exhaust&Filter
KBmotorsports
D3kTrix is offline
