how to set timming - Honda TRX Forums: Honda TRX 450R Forum
Old 08-07-2009, 11:09 PM   #1 (permalink)
Default
i have a 2005 trx450.i just replaced the head.the timming mark on the right side is corect and the cam marks are correct.what should the flywheel be at t or f?
CARLSON is offline   Reply With Quote
Old 08-07-2009, 11:14 PM   #2 (permalink)
jfreed20's Avatar
Send a message via Yahoo to jfreed20
Default
Not sure what mark u use on the flywheel side.U can pop the spark plug out and use somthing to put on top of the
piston to see when its all the way up.Then set ur marks i use a bottle rocket and stick the wood end down the hole.
07 450ER HRC KIT
RE 42.5mm FCR
NO-TOIL AIR FILTER
WHITE BROS E2 (I KNOW NEED DASA)
R&D remote fuel screw
MYCRON 4 TACH
OUTERWEARS
RE GEN 1 HEAD
WEB 242/812
jfreed20 is offline   Reply With Quote
Old 08-07-2009, 11:14 PM   #3 (permalink)
Hinkle Motorsports
HinkleMotorsports's Avatar
Send a message via AIM to HinkleMotorsports
Default
i have a 2005 trx450.i just replaced the head.the timming mark on the right side is corect and the cam marks are correct.what should the flywheel be at t or f?[/b]
set it at "T"
My Youtube Videos (click on youtube)
2009 MX Sponsors:
AtvFourPlay
Fox Racing Shox
Hiper Technology
Cycle Motion
Weekend Warrior Motorsports
Meyer Coatings
ATVBRAKESNMORE
HinkleMotorsports is offline   Reply With Quote
Old 08-07-2009, 11:15 PM   #4 (permalink)
Super Moderator
want2bfast's Avatar
Send a message via Yahoo to want2bfast
Default
dont worry about the flywheel. just set it from the right side.
want2bfast is offline   Reply With Quote
Old 08-07-2009, 11:26 PM   #5 (permalink)
Hinkle Motorsports
Default
piston to see when its all the way up.Then set ur marks i use a bottle rocket and stick the wood end down the hole.[/b]
altho that will work to a certain extent, The TDC (T) mark is very close to the FIRE (F) mark... so its a possibility to have it a tooth off... how ever I would try to stay away from shoving anything down in your spark plug hole, I pull the flywheel peep hole cover off, the crank bolt cover off, and adjust the timing accordingly with the cam
2009 MX Sponsors:
AtvFourPlay
Fox Racing Shox
Hiper Technology
Cycle Motion
Meyer Coatings
ATVBRAKESNMORE
Old 08-07-2009, 11:32 PM   #6 (permalink)
Default
your saying to use both the t mark and the mark on the right side.it seems if you were to use just the mark on the right side you can have the timming 180 out?
Old 08-07-2009, 11:44 PM   #7 (permalink)
Hinkle Motorsports
Default
cam lobes back... if the cam lobes are facing the front of the bike..... then you are 180 out
2009 MX Sponsors:
AtvFourPlay
Fox Racing Shox
Hiper Technology
Cycle Motion
Meyer Coatings
ATVBRAKESNMORE
Old 08-08-2009, 12:43 AM   #8 (permalink)
Default
No such thing as 180 out on a one cylinder four stroke wasted spark engine !!
I never use the right side to time a 450r ! I always use the flywheel "T" mark ! Easy as pie and never an issue.
McCune is offline   Reply With Quote
Old 08-08-2009, 12:47 AM   #9 (permalink)
Hinkle Motorsports
Default
I never use the right side to time a 450r ! I always use the flywheel "T" mark ! Easy as pie and never an issue.[/b]
you CAN have your cam 180 out.... which is what im talking about..... notice i said cam lobes
2009 MX Sponsors:
AtvFourPlay
Fox Racing Shox
Hiper Technology
Cycle Motion
Meyer Coatings
ATVBRAKESNMORE
Old 08-08-2009, 07:48 PM   #10 (permalink)
DS450 Rider
motox_rider695's Avatar
Send a message via AIM to motox_rider695 Send a message via Yahoo to motox_rider695
Default
X2, you can most deffinitly have your cam 180 out.... i found this out the hard way. Couldn't find a reason why my quad wouldn't start, took 2 hours to finally figure out the cam was off 180, after i felt like a dumbass, but now she runs n cant complain
motox_rider695 is offline   Reply With Quote
Old 08-08-2009, 09:31 PM   #11 (permalink)
450RRR's Avatar
Default
NEGATIVE...
you cannot have this machine 180* off on the valve timing...
reason? the spark fires at both the POWER STROKE.....and the EXHAUST STROKE...
hence the term "wasted spark engine"....
the spark fires each and every time the piston reaches TDC..... therefore it can NOT be 180* off....or 360* off depending on how you look at it....
HOWEVER....on a side note... it is nearly impossible to align the timing marks and complete this process when the lobes are facing forward/down on the bumpstick.... reason being.... you are now pressing on the valve springs... which makes it EXTREMELY difficult to rotate the engine to get at a TRUE TDC....
like Mccune said....the easiest / best method is to use the flywheel 'T' mark.... (the 'F' mark is the timing advance mark)..... however, the flywheel 'can' become misaligned due to a half moon key issue...... so I tend to use the crank gear TDC mark....
to each their own.....
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline   Reply With Quote
Old 08-08-2009, 09:39 PM   #12 (permalink)
Default
LMAO X100 !!
Old 08-09-2009, 12:13 PM   #13 (permalink)
DS450 Rider
Default
NEGATIVE...
to each their own.....[/b]
wow, now i even feel more like a dumbass
Old 08-09-2009, 09:02 PM   #14 (permalink)
450RRR's Avatar
Default
nah....
you were probably just a tooth off if your lobes were facing fwd/down... cuzz of the extreme pressure the valve springs puts on the engine...it is VERY difficult to time correctly this way....
once you put the piston at TDC...and the cam lobes are facing back/up.....you are no longer under any spring pressure and much much easier to time correctly...
jmho...Greg
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
Old 01-22-2012, 09:13 PM   #15 (permalink)
r4nsack's Avatar
Default
what exactly do you "adjust" if everything doesnt line up? All ive seen people talk about is lining up notches but not what to do if they dont line up lol. And what about using a timing light..
r4nsack is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
