Green Wire Mod - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 28 (permalink) Old 01-29-2009, 12:14 AM Thread Starter
BARTONG's Avatar
So after reading about the green wire mod (especially a lot today) i decided to do it on my bike, i know, without a cam its pointless, but I'm getting the HRC kit soon so i decided to do it in some free time i had. I did a little modification and came up with my own version of this mod.So here it is!
1. open up your hood, front left side plastic (you can do it on the right side as well but i did on the left so that there was no chance of the wires getting burned by the pipe), back plastic
2. cut the green wire on the most left plug and place 2 connectors on it (you can also solder the wires directly to it), make sure the wires you use are long enough to reach to the little compartment under the seat
3.run the wires by the upper frame rail (so that they wont get damaged by your knees) all the way to the back
4. make a hole in the back plastic where you want the switch to be and place it there
5. connect the wires to it so that when its ON, the green wire mod is turned OFF, when the switch is OFF, the green wire mod is put into effect
6. split both of the wires and place some type of connectors on them so that you can quickly unattach them when removing the back plastic
7. go out and ride and enjoy your uncorked R!!!
know your limits... ...then pushe 'em
BARTONG is offline
post #2 of 28 (permalink) Old 01-29-2009, 12:22 AM
wayne brady 1956's Avatar
Send a message via AIM to wayne brady 1956
when you are just crusin and flip the switch can you tell anything happend?
07 er
VENOM ported head
cp 13:5:1 piston
bored to 480R
hcII
hmf exhuast/hrc header
jetted with lid off
green wire mod
pro armor nerfs
FOX evol X long travel fronts
gibson long travel arms
rpm +4 axle
TCS re-valved dual rate rear shock
IMS ROLL intimidator mx bumper
Rox speed fx bar risers and dash panel
wayne brady 1956 is offline
post #3 of 28 (permalink) Old 01-29-2009, 12:23 AM
h0nda450mainiac's Avatar
Garage
lol i've wanted to do the switch to see if it's a noticeable difference
06 ER
22x11x8 9 paddle
Green wire mod.
AC nerfs.
ESR exhaust, with mid-top end header.
HCII
K&N intake
LRD needle, 4th clip
CR 500 Springs
g force extended hubs
SLC +2.5 swinger
OEM, crf 450r clutch
h0nda450mainiac is offline
post #4 of 28 (permalink) Old 01-29-2009, 12:29 AM Thread Starter
BARTONG's Avatar
well, i didn't ride it today yet cuz it was like 11pm when i've done this but as soon as i compare the 2 settings ill post it up
BARTONG is offline
post #5 of 28 (permalink) Old 01-29-2009, 02:06 AM
Flippincgfighter's Avatar
IMO i think there could be a better place for the switch.
Maybe under the seat or somewhere that a object or something is not going to slap that switch.
Even under the hood. It would reduce the amount of wiring, and make a much cleaner look.
Great Idea BTW
Not sure what the effects on the CDI or bike it would have while switching the Rev limit while riding.
Dynatec or Vortec has it on their YFZ CDI. Two seperate curves wired into one handlebar mounted switch. The theory is, to use the bottom end curve for launching and switch to top end curve when after you launch. This can be done while the bike is going and under a load.
I would imagine since the green wire mod only changes the rev limit, not the curve, it would be just fine to switch while riding.
-Kip
05 Drag Bike
Flippincgfighter is offline
post #6 of 28 (permalink) Old 01-29-2009, 02:13 AM
hondanut's Avatar
I have a toggle on mine, right on the shroud under the left side of the bars. Oh **** ya you can tell a difference!!! I was switching it back and forth down the road, its awesome. even when the bike is just idling you can hear the pitch change when you flip the switch.. I don't care if you have a stock cam, green wire mod is a must on 06+.... Make sure you don't forget thatthe ON label on the switch means the green wire is like stock, I made the mistake of hauling ass thinking it was on stock setting and flipping it... Tires locked up, hit the rev limiter harder than ever before, and all kinds of scary other stuff lol
---06'---
A rider that gets the job done.
I decided that the internet is a scary place, I will leave you all to your imagination what's done to my bike. Who wants to race, or give me a dyno sesh? ;].
hondanut is offline
post #7 of 28 (permalink) Old 01-29-2009, 02:15 AM
hondanut's Avatar
oh ya, kippo clipping the green wire does change the curve, it advances the timing. I figured you'd know that already....
---06'---
hondanut is offline
post #8 of 28 (permalink) Old 02-22-2010, 08:07 PM
i just clipped the green wire...is it better to have a switch so u can go back to stock rev limit? and i also have an aftermarket rev procom rev box that isnt installed.. what would u say to installing the aftermarket rev box with the green wire mod?
dre_sone is offline
post #9 of 28 (permalink) Old 02-22-2010, 09:11 PM
jeepdude84@hotmail.com's Avatar
Send a message via MSN to jeepdude84@hotmail.com
The green wire mod is absolutely worthless WITH an aftermarket cdi box because the the box is a set rpm limit and timing curve and you can't change it with the green wire like the factory cdi is capable of
SOLD:06 450er Kicker Conversion,
04 KFX 700 Hmf Slip on, Kawi Nerfs,Bumper,Grab Bar LED Tail light Itp C Series With Sandstars front and rear Hid Lights
2010 Pearl White Polaris RZR S Polaris Pre Runner Bumper,Windshield,Roof,Winch and storage bags, HID Lights, Iitp SS Wheels with dunestar paddles,Dragon Fire Racing 4 point harnesses.
jeepdude84@hotmail.com is offline
post #10 of 28 (permalink) Old 02-22-2010, 09:15 PM
Super Moderator
want2bfast's Avatar
Send a message via Yahoo to want2bfast
Procom is junk...
want2bfast is offline
post #11 of 28 (permalink) Old 02-22-2010, 10:19 PM
OCP
Oregon Coast Powersports
OCP's Avatar
Send a message via Yahoo to OCP
i did a similar green wire mod on my 05. mine is attached to my hotstart lever though. when im riding across the dunes, pinned in fifth, i can push the lever and it will straight up rip the front tires off the ground when the new curve is selected. seriously.
OCP is offline
post #12 of 28 (permalink) Old 02-22-2010, 10:32 PM
450RRR's Avatar
i did a similar green wire mod on my 05. mine is attached to my hotstart lever though. when im riding across the dunes, pinned in fifth, i can push the lever and it will straight up rip the front tires off the ground when the new curve is selected. seriously.[/b]
umm....im gonna hafta call your bluff on this one.....LOL
can anyone tell me WHY you would ever want to use the stock ICM setting instead of the much preferred HRC modded (or green wire mod) setting?
im confused.....
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #13 of 28 (permalink) Old 02-22-2010, 10:37 PM
OCP
OCP's Avatar
greg, have you dynoed your machine with nitrous? with and without the green mod?
i wonder if that or one of the other methods of forced induction would be when the stock curve would be beneficial?
going back to muscle cars, my msd box has a selectable retard for nitrous and such.
OCP is offline
post #14 of 28 (permalink) Old 03-19-2010, 02:02 AM
i read in another post on here that this mod is only good for the er's... is this true? i have an 05 and was wondering how it is done if it is different.. thanks guys
jlwalker9 is offline
post #15 of 28 (permalink) Old 03-19-2010, 02:14 AM
Super Moderator
It's only for the 06 and up.... Not for the 04/05
Baileygunns is offline
