loud exhaust pop when starting - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 7 (permalink) Old 11-03-2008, 08:00 PM Thread Starter
jjm450er's Avatar
Sometimes when im starting my bike, while its still cranking it will make a really loud pop through the exhaust. It seems to be getting worce. its a 06 450er with hrc, twin air intake ring and filter, hrc jetting. lots of hard hours but still runs great.. could it be valves out of adjustment..
06 Xc racer
06 duner
jjm450er is offline
post #2 of 7 (permalink) Old 11-04-2008, 12:30 AM
tersejr's Avatar
I would check the decomp adjustment and the valve clearances.
Rat Rod
tersejr is offline
post #3 of 7 (permalink) Old 11-04-2008, 08:05 PM
mine kind of does this, i think mine does cause cold weather and takes more cranks to start, and back fires once cause the fuel isnt burning. i think mine needs add alittle for fuel for the weather.
2009 yfz450R
05 yz250f
carbon pro pipe
erskine is offline
post #4 of 7 (permalink) Old 11-04-2008, 08:13 PM
oneill_1952's Avatar
Send a message via MSN to oneill_1952
Sometimes when im starting my bike, while its still cranking it will make a really loud pop through the exhaust. It seems to be getting worce. its a 06 450er with hrc, twin air intake ring and filter, hrc jetting. lots of hard hours but still runs great.. could it be valves out of adjustment..[/b]
sounds lean, mabye getting worse with cold weather, bump your HRC needle down one notch, let me know how that works for you.
Andrew
2006 TRX450ER
Spending money I don't have, on a quad I barely ride, to impress people I don't even know...
oneill_1952 is offline
post #5 of 7 (permalink) Old 11-04-2008, 09:27 PM
cheapfast450r's Avatar
Andrew
would u not want to change the pilot to help the starting? that would give it more gas at the idle ckt where the needle change will give it more gas at the 1/3 to 2/3 throttle.
i would adj the fuel screw out a little, if that didn't work i would go up on the pilot a little.......just my .02
drag bike 06 450ER
Powered by
Racers Edge, AZ
SS/SB
4.42 in 300'
trail bike 07 450ER
SS/SB
powered by
spare parts
cheapfast450r is offline
post #6 of 7 (permalink) Old 11-05-2008, 01:32 PM Thread Starter
jjm450er's Avatar
thanks for the help, i'll try those suggestions this weekend..
06 Xc racer
06 duner
jjm450er is offline
post #7 of 7 (permalink) Old 11-05-2008, 01:40 PM
hondanut's Avatar
If you ae popping when starting, or/and on decel you should change the needle clip and the pilot. This will smooth out your jetting, and prevent a hesitation between your pilot control and your needle. Kehin carb chart
---06'---
A rider that gets the job done.
I decided that the internet is a scary place, I will leave you all to your imagination what's done to my bike. Who wants to race, or give me a dyno sesh? ;].
hondanut is offline
