wtb a flywheel puller! - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 15 (permalink) Old 04-05-2008, 10:47 AM Thread Starter
teamexileracing's Avatar
Well i have a few 450r engines i need to do a total rebuild on and i need a flywheel puller. Anyone got one they want to sell for an 05 r?
Let me know.
Thanks,
Luke
teamexileracing is offline
post #2 of 15 (permalink) Old 04-05-2008, 12:33 PM
hondaman01's Avatar
i doubt anyone will sell theres but ripper suggested to me what he done and that he took his motor to his local honda shop and had them pull it off and they charged him 5 bucks
hondaman01 is offline
post #3 of 15 (permalink) Old 04-05-2008, 08:16 PM Thread Starter
Well i refuse to go to my local shop unless im desperate.....they are a bunch of ass holes and they rip you off soo bad.....check this out. We got a mojave 250 from them, they said it was perfect, there machanic when all over it and said it was perfect, inside and out. Well we noticed it was hard to kick, but we never did anything about it. Went to check the timing and come to find out it has no decompression valve. Went up to them and bitched about it and they just turned there sholder. They lost customers for life!
post #4 of 15 (permalink) Old 04-05-2008, 11:23 PM
ledouxmike's Avatar
Well i refuse to go to my local shop unless im desperate.....they are a bunch of ass holes and they rip you off soo bad.....check this out. We got a mojave 250 from them, they said it was perfect, there machanic when all over it and said it was perfect, inside and out. Well we noticed it was hard to kick, but we never did anything about it. Went to check the timing and come to find out it has no decompression valve. Went up to them and bitched about it and they just turned there sholder. They lost customers for life![/b]
order you a trail tech. I don't think the generic ones will work.
2005 Black 450R Factory effex graphic kit
mobil 1 true synthetic turbo diesel 5w40
hp red gear oil
hotcams stage II
dynojet - 175 main jet
hrc lid
modified snorkel
breather drilled
air box silencer removed and plugged
Uni filter
dmc afterburner quiet full exhaust
13/40 rocket sprockets
maxxis razrs 20x11x8 21x7x10
itp baja wheels
dg nerf bars
pro-taper handlebars
relocated ignition key
go fast stickers-5 hp per sticker, lol
ledouxmike is offline
post #5 of 15 (permalink) Old 04-06-2008, 12:06 AM
hondaman01's Avatar
yea generic flywheel pullers wont work on them you can only use the specific OEM or trail tech flywheel puller and the 04-05 are different than the 06-07
post #6 of 15 (permalink) Old 04-06-2008, 03:21 AM Thread Starter
thanks guys. anybody know how much they are?
post #7 of 15 (permalink) Old 04-06-2008, 03:26 AM
hondaman01's Avatar
20 bucks straight from trailtech.net + shipping
post #8 of 15 (permalink) Old 04-06-2008, 10:13 AM
bawb's Avatar
Send a message via AIM to bawb
Ive never bought one, and rebuild 3 motors so far. I used a pulley puller, it takes some time and patience but it CAN be done.
pulley puller
This is what worked best for me, its supposed to be a steering wheel puller, im just a dumb hick from ohio what do I know though lol....
05 450
bawb is offline
post #9 of 15 (permalink) Old 04-06-2008, 10:51 AM Thread Starter
Dont worry us dumb hicks from ohio got to stick to gether......my and my friend tryed one of those on his warrior engine hahaha. We tryed for like an hour and nothing so we took it to a shop to get pulled.
post #10 of 15 (permalink) Old 04-06-2008, 10:58 AM
bawb's Avatar
Theres definetly a trick to it, you gotta take your time like I said, I put the bolts though the backside of the flywheel and threaded the nuts onto the puller, kinda hard to explain ill get pics if I remember today.
Should fire it up this afternoon, I just need to get off here and go shim the valves and put the sidecovers on
VROOM VROOM!!!!
05 450
bawb is offline
post #11 of 15 (permalink) Old 04-06-2008, 12:00 PM
hondaman01's Avatar
VROOM VROOM!!!![/b]
i would NEVER use one of those, and here is why
that type has a center tool on it and presses into the center of the shaft to pull from
well the end of the crank has a oil squirt hole and that hole is how the roller bearing gets its oil to function properly, this is the bearing that always goes out to so less oil is going to be horrible
the RIGHT flywheel tool has a deep nut that threads over the entire end of the shaft to keep it from screwing up the oil squirt hole
that center puller will definatly screw that hole up and the seal inside the stator that it goes in
it will work MAYBE if your going to be putting a new crank in, but do not use that if your going to be re-useing the crank
post #12 of 15 (permalink) Old 04-06-2008, 12:06 PM
ledouxmike's Avatar
VROOM VROOM!!!![/b]
I've also heard you can break off a piece of the crank with the generic kind.
hp red gear oil
hotcams stage II
hrc lid
modified snorkel
breather drilled
Uni filter
itp baja wheels
dg nerf bars
post #13 of 15 (permalink) Old 04-06-2008, 12:08 PM
ledouxmike's Avatar
VROOM VROOM!!!![/b]
lucky *******. Enjoy your ride. bawb thanks for the help you've given my by the way.
hp red gear oil
hotcams stage II
hrc lid
modified snorkel
breather drilled
Uni filter
itp baja wheels
dg nerf bars
post #14 of 15 (permalink) Old 04-06-2008, 06:40 PM
bawb's Avatar
Like I said im just a dumb hick what do I know lol
05 450
bawb is offline
post #15 of 15 (permalink) Old 04-06-2008, 09:54 PM Thread Starter
Okay thats a lot easyer to get out then the warriors. That seems like it would work unlike how we had to do it.
