All Special Honda Tools Needed For Complete Engine Teardown - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 15 (permalink) Old 01-31-2008, 11:50 PM Thread Starter
Well I got to taking the balancer shaft off..... I definetely need the tool for this one... I want to just do this right and order ALL special tools needed for the complete reassembly. Bearing pullers, gear holders, and so on.......
Just let me know what they all are... I couldn't find it anywhere on here.
Thanks
-Danny
06erdj450 is offline
post #2 of 15 (permalink) Old 02-01-2008, 12:11 AM Thread Starter
I know I need the lock nut socket 07716-0020100
-Danny
post #3 of 15 (permalink) Old 02-01-2008, 07:18 PM Thread Starter
What has no one used these tools? I need to get them ordered.
-Danny
post #4 of 15 (permalink) Old 02-01-2008, 08:13 PM
kandc1994's Avatar
tools ! im looking for a list of all the tools also. i would get the bearing puller any where tho . its a basic tool.
is the flywheel tool for 300ex the same?
good luck and let me know !
04 530R #132 40plus NEATV
BCS/BETTENCOURTS
kandc1994 is offline
post #5 of 15 (permalink) Old 02-01-2008, 08:17 PM Thread Starter
No. I had a flywheel puller for a 300ex and it wasn't the same!
-Danny
post #6 of 15 (permalink) Old 02-01-2008, 09:03 PM
hondaman01's Avatar
the only special tools i used when changing mccowns crank was the flywheel puller
but he didnt replace bearings, so i would defiantly suggest the bearing puller
but here is everything needed, except the flywheel puller
Bearing remover handle
07936-3710100
Bearing remover, 17 mm
07936-3710300
Bearing remover, 20 mm
07936-3710600
Remover weight
07741-0010201
Driver
07749-0010000
Attachment, 32 x 35 mm
07746-0010100
or 07936-3710200 or 07936-371020A
(U.S.A. only)
Attachment, 37 x 40 mm
07746-0010200
Attachment, 42 x 47 mm
07746-0010300
Attachment, 52 x 55 mm
07746-0010400
Attachment, 62 x 68 mm
07746-0010500
Attachment, 72 x 75 mm
07746-0010600
Pilot, 17 mm
07746-0040400
16
Pilot, 20 mm
07746-0040500
Pilot, 25 mm
07746-0040600
Pilot, 30 mm
07746-0040700
Lock nut wrench, 20 x 24 mm
07716-0020100
w
Extension bar
07716-0020500
or commercially available
equivalent
Gear holder, M2.5
07724-0010100
or 07724-001A100 (U.S.A. only)
Gear holder, M1.5
07724-0010200
or 07724-
hondaman01 is offline
post #7 of 15 (permalink) Old 02-01-2008, 09:06 PM Thread Starter
Thanks.. But I don't even know what half of those things are by their description.....
I asked Woodward if they carry these tools, or if they can get them because I don't know where to get them from.
-Danny
post #8 of 15 (permalink) Old 02-01-2008, 09:12 PM
hondaman01's Avatar
oh sorry lol i found them in the service manual
post #9 of 15 (permalink) Old 02-01-2008, 09:17 PM
millertime's Avatar
i tryed to order them from service honda when i bought a new crank from them , but they said i had to order them from a honda dealership... so i went to the honda dealer in town and ordered them... but the one for the balancer shaft was back ordered...so they loaned me there's... then mine came in... never did use it... if you want to buy it i will sell it to you.. i also bought the crank puller.. that i want to keep.. i can use that for other motors... shoot me a pm if you want the speacial socket for the balancer nut
millertime is offline
post #10 of 15 (permalink) Old 02-01-2008, 09:17 PM
Stock 05 450R
Nor*Cal's Avatar
Just get the flywheel puller and the lock nut socket. Motion Pro makes them.
To get the honda tools you got to go through the dealership and you would probably spend over $500. No joke.
Everything else you should find alternatives at Harbor Freight.
Nor*Cal is offline
post #11 of 15 (permalink) Old 02-01-2008, 10:17 PM
Flyin450R's Avatar
Just send the bottom end to someone like KBR, or Rage for hardend gears etc..
2009 Mustang GT Premium! Some stuff to come!
Brakes are for sissies’
Welcome to America....We speak English here!
A Veteran is someone who at one point in their life, wrote a blank check payable to the USA for an amount up to, and including, their life. That is beyond honor, and there are way too many people in this country who no longer remember that fact.
Flyin450R is offline
post #12 of 15 (permalink) Old 06-14-2011, 06:05 PM
if you happen to have a flywheel puller for a kx85 laying around. that will take the 450r's off...
shift714 is offline
post #13 of 15 (permalink) Old 06-14-2011, 06:17 PM
usmcvet's Avatar
hmmmmm-that a 3 year plus old post.
2008 trx450er
Houser +1 LT Slicast a-arms
Axis 18.75 triples
Houser Stem
GPR Steering Stabilizer
Houser swinger w/ houser link
Fox Podium rear shock
Atv Fourplay Soft Bars
Hiper Tech3 Beadlocks w/ Holeshot GNCC's
Dirt Works 24v system
Uni Filter
HRC kit
HMF Ironman full System
165 main,48 pilot,55 leak jet
PRM front bumper, Houser Rear grab bar
more to be added...
2007 trx450er
|.......TRX450R .....| ||'|";, ___.
|_..._...________=|=||'_|__|.,] -
usmcvet is offline
post #14 of 15 (permalink) Old 06-14-2011, 06:22 PM
69quadracer's Avatar
I made my own socket to remove the balancer nut, think i used a 7/8" deep socket ant took my dremal tool with a cut off wheel and wnt to cutin fits the nut perfect and still workin today.
07 TRX 450ER 14/1 CP piston/ +1 valves intake & exhaust/ 208 web cam/ High Rev valve springs/ potred & polished/bored carb by DASA/ DASA Classic exhaust / Leagers +2 MX Lt a-arms/ Ohlins Lt front & Fox Podium X DSC Rear shock and LSR DC-6 linkage/LSR duel row carrier/ lsr Axcaliber Pro axle/ Pro Armor skid & rear bumper/ Hiper Bead locks/ Quadcross Pro's/ Houser +1 stem/ Precision stablizer / Pro Taper Fat bars/ ASV levers/ Quadtech hump seat. My trail ride is a 07 GRIZZLY 700 !
69quadracer is offline
post #15 of 15 (permalink) Old 06-14-2011, 08:29 PM
ATVRACING250EX@aol.com's Avatar
this post is super old but bikebandit.com has lots of tools incase any1 was still wondering
2006 Honda TRX450ER
-HMF slip on
-HRC header
-HRC cam
-12/38 sprockets
-jetted
-K&N air filter
-Full Skids
-ITP Holeshots
-MORE SOON
ATVRACING250EX@aol.com is offline
