Hard start 05 450.. when cold - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 8 (permalink) Old 01-08-2008, 10:26 PM Thread Starter
450R_003's Avatar
Got a question... I bought a used 05 450... It starts kinda hard when it's cold but then first kick after its' been ridden.... Also It likes to back fire a few times then it seems to start after that?? Could this be a jetting issue.. I came with a full sparks exhaust, aluminum air box and sparks foam filter... Any help is apprecieated... thanks
450R_003 is offline
post #2 of 8 (permalink) Old 01-09-2008, 03:51 AM
Flippincgfighter's Avatar
Valve adjustment?
05 Drag Bike
Flippincgfighter is offline
post #3 of 8 (permalink) Old 01-09-2008, 09:05 AM
Got a question... I bought a used 05 450... It starts kinda hard when it's cold but then first kick after its' been ridden.... Also It likes to back fire a few times then it seems to start after that?? Could this be a jetting issue.. I came with a full sparks exhaust, aluminum air box and sparks foam filter... Any help is apprecieated... thanks[/b]
man i thought the same when i first got my 450 i pull choke hit gas 2 times and kick and it usally starts for sure one third kick
2004 trx450r
hott cam II
fmf full exhaust
esr intake
maxxis razers
okla450r04 is offline
post #4 of 8 (permalink) Old 01-09-2008, 09:35 AM
Raider's Avatar
Send a message via MSN to Raider
The jetting could be off for cold weather conditions. I read an article once that if you have a hard time starting the quad when cold that the jetting may be off a bit. My friend had a Predator that did the samething and sure enough, he adjusted his jetting a lil bit and she fires right up now.
2004 Honda 450R[/b][/u]
<span style="color:#FF0000">Wiseco 13.5:1 Piston
Stage II Hotcam
P&P Head
HRC Jet Kit
HMF Head Pipe
WB XCR Slip-on
K&N Air Filter with OuterWear
AC Pro Peg Nerfs
+2 Houser A-Arms
Geforce Rear Hubs
Renthal Fat Bars
+1 Gibson Steering Stem
GT Thunder Rear Shock w/ Link
Pro Armor Full Skid
Myspace Link
Raider is offline
post #5 of 8 (permalink) Old 01-09-2008, 04:04 PM
Banned
Send a message via AIM to BATCH450r Send a message via MSN to BATCH450r Send a message via Yahoo to BATCH450r
wait, didnt i post on here last night? maybe i got my post deleted
but yeha, the others pretty much got your back
BATCH450r is offline
post #6 of 8 (permalink) Old 01-09-2008, 05:11 PM
sandshots's Avatar
its normal for the bike to have a hard time starting in the cold.
if you got it used id deffinately would check vavle, and decompression specs.
R.I.P TRX450r
sandshots is offline
post #7 of 8 (permalink) Old 01-10-2008, 10:44 AM
HondaTRX450Rider's Avatar
common problem, what is your jetting now? It will run lean in the winter, try covering up the air box, make sure the choke is on, if you have a propane heater point it at it for maybe 20 minutes of so(not to close dont want to melt stuff. Also make sure you warm in up before riding it.
-Nathan
2005 Honda TRX450R
1986 Suzuki LT230S
Looking For:
Shocks
Belly Skid
A-Arms (+1)
PM me with Pics and deatails
HondaTRX450Rider is offline
post #8 of 8 (permalink) Old 01-10-2008, 10:55 AM
bmxzippy180's Avatar
Send a message via Yahoo to bmxzippy180
I had to put the stock air box lid back on to make my 450r kicker start in the winter. It fires after about 3 kicks with the choke on. Make sure you pump the gas at least once before you kick.
[b]04' 450r & 03' 400ex
Hot Rod +3 Stroker Crank, Yoshimura RS-7 Full Titanium Exhuast w/ stepped header, Stage II Hotcam, K&N with Outwear and Removed Air box lid, Dyno Jet kit -175 main, Dynotek Programmable CDI Skat Trac Haulers 8 paddles on Black Labels, DG Chrome Light Nerf Bars with Black Nets and Pro Armor Black Heel Guards, IMS Intimidator Bumper , Elka XC Rear Link, Tag T2 Anodized Red with MSR Clutch Lever and OURY grips, Carbon Fiber Fox Warning Label Kit and Tusk Black Gas Cap, FX Gripper Seat, ProArmer Grab Bar
bmxzippy180 is offline
