Hot rods crank problems - Page 2 - Honda TRX Forums: Honda TRX 450R Forum
post #16 of 102 (permalink) Old 12-06-2007, 12:07 AM
poorboy's Avatar
i have a stockl length hotrods heavy duty rod sitting right next to my sopposed stroker crank the rod has the exact same hr 632 on its side. Not another headache.
My life is not a journey with the intent of arriving safely in a pretty and well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out loudly proclaiming... WOW What a Ride!!!
poorboy is offline
post #17 of 102 (permalink) Old 12-06-2007, 12:09 AM
Stock 05 450R
Nor*Cal's Avatar
i think people should do some measuring for us like one of the site sponsors who will have the 2 different ones in stock and do a number check also[/b]
Yes. Maybe all the +3 crank rods have 632... Maybe the stock has 8632 ????
Also, don't you have to take the crank assembly apart to measure?? If not, tell me how to measure it and I'll do it right now. Maybe measure the highest point of the Rod (as assembled)?
EDIT:
Just noticed poorboy posted info while I was typing the above. So maybe all rods have the same p/n on them?? Which would be scary!
Nor*Cal is offline
post #18 of 102 (permalink) Old 12-06-2007, 12:10 AM
well this blows i definately think my bros is a plus 3mm i dont think hed a got the hp n tq he has if it isnt
TRX533R
jwilson84 is offline
post #19 of 102 (permalink) Old 12-06-2007, 12:15 AM
poorboy's Avatar
no the stock definatley has hr 632 on it im holding it right now and the claimed +3 is sittin right next to me if i had a way to measure them i would.
poorboy is offline
post #20 of 102 (permalink) Old 12-06-2007, 12:17 AM
stevefarris's Avatar
no the stock definatley has hr 632 on it im holding it right now and the claimed +3 is sittin right next to me if i had a way to measure them i would.[/b]
A simple ruler may do the trick. The stroker is supposed to be 1.5mm longer, correct? See if you can tell.
Steve
stevefarris is offline
post #21 of 102 (permalink) Old 12-06-2007, 12:22 AM
poorboy's Avatar
wont really work since the crankshafts rod is in the crank i cant find my dial calipers i dont think they go to 4 inches anyway
poorboy is offline
post #22 of 102 (permalink) Old 12-06-2007, 12:23 AM
Knowpig's Avatar
FYI, the sticker on my box is EXACTLY the same as tuffguy's. And if you look close, the sticker underneath looks like "4060".
Guess what that number crank is.
Welcome to California! We pay the highest State sales and income tax in the nation..................
<strike>And we're trying to raise them EVEN HIGHER!!!!!!</strike>
Never mind. We did it. They're even higher now.
Good Job California Government!!!!!!!
Knowpig is offline
post #23 of 102 (permalink) Old 12-06-2007, 12:24 AM
shouldnt u be able to grab the crank by the pin hole and let it fall to its lowest point then measure
TRX533R
post #24 of 102 (permalink) Old 12-06-2007, 12:25 AM
Knowpig's Avatar
wont really work since the crankshafts rod is in the crank i cant find my dial calipers i dont think they go to 4 inches anyway[/b]
Just measure from the top of the big end to the bottom of the small end. You should be able to get an idea of what you have.
Knowpig is offline
post #25 of 102 (permalink) Old 12-06-2007, 12:25 AM
poorboy's Avatar
unfortanatley my cranks box was used to ship my head to mixxer and he used a diff box to ship it back. but i remeber a double sticker. you think a distributor might have screwed something up???? mine came from new york.
poorboy is offline
post #26 of 102 (permalink) Old 12-06-2007, 12:30 AM
poorboy's Avatar
hey you know what i think your on to some thing know pig but i would still need a something to campare it to....(smacks self in head) duh i have a stock length rod right here in my hand be right back.
<<<<upstairs diggin for machinist ruler gonna go down to the 64ths if i can
poorboy is offline
post #27 of 102 (permalink) Old 12-06-2007, 12:37 AM
Stock 05 450R
Nor*Cal's Avatar
Thinking out-loud here....... but....
What if Hot Rods somehow assembled some of the +3 cranks with stock size rods?
Hope this is just a big mis-understanding and our cranks are all okay.
Poorboy, if you can tell me what to measure I'll grab the calipers and go to it...
Nor*Cal is offline
post #28 of 102 (permalink) Old 12-06-2007, 12:37 AM
Knowpig's Avatar
<<<<upstairs diggin for machinist ruler gonna go down to the 64ths if i can[/b]
Knowpig is offline
post #29 of 102 (permalink) Old 12-06-2007, 12:39 AM
Knowpig's Avatar
What if Hot Rods somehow assembled some of the +3 cranks with stock size rods?[/b]
Then the piston would smack the head and valves!!!!
Knowpig is offline
post #30 of 102 (permalink) Old 12-06-2007, 12:41 AM
poorboy's Avatar
ho ho check it out i forgot it had millimeters
measred from top of big ends machined side to bottom of little end machined side guess what exactly the same
if anyone cares to know my numbers were both 71 mms but you maynot get the exact same number do to exactly the way you measure
thanks knowpig you kick my mind into high gear there it had all but gone to sleep.
now what do i do i maile hot rods already im gonna call them tommorow.
what gives here **** i cant even find a listing for a hotrods stroker for an 04-05.
poorboy is offline
