Transmission Oil - Honda TRX Forums: Honda TRX 450R Forum
Old 04-07-2007, 10:35 PM   #1 (permalink)
Seeves's Avatar
Default
The 450r manual recommends 10w40 oil for the tranny, but most transmission oils are around 70 to 90 weight. Are there any good none sythetic gear oils that are around 10w40 other than the stock honda oil? And does anybody have any idea what damage a thicker oil could cause? Also does anyone have any experience using 70 to 90 weight tranny oil in the 450r?
Thanks,
Seevers
'05 TRX 450r
AC Racing Nerf Bars
AC Racing Front Bumper
AC Racing Rear Grab Bar
ASV F3 Pro Clutch Perch w/ Hot Start
ASV Unbreakable Levers
ASV Rotator Master Cylinder Clamp
Cobra Skid Plate
Cobra Swing Arm Skid
DG Case Saver
DynoJet
FCR Suspension Rebuild Setup for weight and riding style
HMF Complete Ballance Series Pipe
ITP GNCC Rear Tires
ITP Pro Lock Beadlocks Front and Rear
ITP XCR Front Tires
Maier Vented hood
Moose Racing Parking Brake Block Off
Power Madd Handguards
Pro Design Kill Switch
Pro Taper Contour Bars
Scott Works Compound Grips
Coming Soon!!!
Denton Steering Stabilizer
Possibly Hot Cams
Possibly Weighted Flywheel (Need More Info)
Seeves is offline   Reply With Quote
Old 04-07-2007, 10:40 PM   #2 (permalink)
sredish's Avatar
Default
I run Rotella 15w40 in the trans all year long. I also run it in the Engine side along with some moly additive.
sredish is offline   Reply With Quote
Old 04-07-2007, 10:45 PM   #3 (permalink)
Jim
Default
You can also use the Honda HP Trans oil 80W/85W it comes in a red bottle with a black cap.
05' TRX450R | JH Racing | DASA | Dynatek | Precision | JD Performance | Custom AXIS | Fasst | DWT | JE | Hotcam | SSi
"Integrity is like Virginity, once its Gone, its Gone!"
cleatus is offline   Reply With Quote
Old 04-07-2007, 11:00 PM   #4 (permalink)
Default
You can also use the Honda HP Trans oil 80W/85W it comes in a red bottle with a black cap.[/b]
Where does it say that in the owners manual?
Honda 450R Black
AC ProPegs Powdercoated Red
Cumminsman76 is offline   Reply With Quote
Old 04-07-2007, 11:07 PM   #5 (permalink)
sredish's Avatar
Default
You can use that HP Trans oil. That red bottle is not a true 85 weight or whatever, if it was, it would barely pour, it's just rated as such.
Old 04-08-2007, 09:47 AM   #6 (permalink)
briansgi's Avatar
Default
Thanks,
Seevers[/b]
10W40 motor oil is equivalant to a 90W gear oil, it's simply a different rating system for viscosities of the two.
briansgi is offline   Reply With Quote
Old 04-08-2007, 12:16 PM   #7 (permalink)
Seeves's Avatar
Default
<div class='quotemain'>The 450r manual recommends 10w40 oil for the tranny, but most transmission oils are around 70 to 90 weight. Are there any good none sythetic gear oils that are around 10w40 other than the stock honda oil? And does anybody have any idea what damage a thicker oil could cause? Also does anyone have any experience using 70 to 90 weight tranny oil in the 450r?
Thanks,
Seevers[/b]
[/b][/quote]
I thought maybe that was the case, but I wasn't sure. The first thing that made me think of this was that Motorex sells a gear oil and it says like 70w95 or something like that and then up in the upper right hand side of the bottle it says 10w30 or 10w40. Is there a website out there that shows you conversions?
Thanks,
Seeves
&#39;05 TRX 450r
AC Racing Nerf Bars
Cobra Skid Plate
DG Case Saver
DynoJet
ITP GNCC Rear Tires
ITP XCR Front Tires
Maier Vented hood
Coming Soon!!!
Possibly Hot Cams
Old 04-08-2007, 12:54 PM   #8 (permalink)
450R Racer
Send a message via MSN to Ripper Send a message via Yahoo to Ripper
Default
I just started using the Honda HP Trans oil, and I've got to say that it feels a lot better than using the Honda HP4 semi-synthetic w/o moly.
MachMoto.com
The #1 source for custom streetfighter parts.
Ripper is offline   Reply With Quote
Old 04-08-2007, 01:10 PM   #9 (permalink)
sredish's Avatar
Default
as far as Honda stuff goes, the HP Trans is the only way to go, tranny side.
Old 04-08-2007, 01:33 PM   #10 (permalink)
Default
Thanks,
Seevers[/b]
[/b][/quote]
Then why is plain 80W90 gear oil as thick as honey?
But then again, I know the HP trans oil I put in my tranny seems almost as thick as mototr oil.
prlandry is online now   Reply With Quote
Old 04-08-2007, 08:01 PM   #11 (permalink)
briansgi's Avatar
Default
<div class='quotemain'><div class='quotemain'>The 450r manual recommends 10w40 oil for the tranny, but most transmission oils are around 70 to 90 weight. Are there any good none sythetic gear oils that are around 10w40 other than the stock honda oil? And does anybody have any idea what damage a thicker oil could cause? Also does anyone have any experience using 70 to 90 weight tranny oil in the 450r?
Thanks,
Seevers[/b]
[/b][/quote]
[/b][/quote]
Because it's a "one weight" oil, meaning the 90 rating is equivalent to motor oil that is 40W. Multi weight motor oil that has a rating of say, 10W40 has a 10 weight rating at zero degrees and a 40W at 220 degrees. BTW, the W stands for winter, not weight like alot of people think.
Old 04-08-2007, 08:02 PM   #12 (permalink)
briansgi's Avatar
Default
Thanks,
Seevers[/b]
[/b][/quote]
Thanks,
Seeves
[/b][/quote]
Yes, here is a comparison chart of the two, you need adobe acrobat to read the pdf file though:
http://www.maximausa.com/technical/l...s/spring98.pdf
Old 04-08-2007, 10:34 PM   #13 (permalink)
Super Moderator
450RRR's Avatar
Default
info only....
Gear oil is exactly HALF the viscosity of ENGINE oil...
meaning 80w Gear oil is = to 40w Engine oil......
all I can say is this....there is NO BETTER OIL for your TRANNY than the Honda HP Tranny Fluid 80/85w......
jmho....Greg
86TRX250R (ESR310 72.5mm bore x 72mm stroke &#39;298cc&#39; fully modded) **SOLD**
88TRX250R (ESR330 77.5mm bore x 74mm stroker &#39;345cc&#39; fully modded)
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom &#39;QP&#39; pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
*STU Comp Cut 21x12x8 (6) paddle &#39;Padla Brats&#39; on Douglas Blue label 8x8.....
450RRR is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
