Best Stroker kit???? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 4 (permalink) Old 12-30-2006, 04:36 PM Thread Starter
FARAS04's Avatar
My Honda just went down with crank bearing issues. The case has to be cracked.... so I was thinking I might as well increase the stroke. Currenty I have an ESR480 kit, I have been looking at the Ice Cube stroker kits TRX522 and TRX542 is there a better option?. If I install one of these will my bike become only a drag bike or can i still ride trails? Any ideas???
2005 TRX450R
ENGINE MODS:
DASA 500 KIT
JE 13.0:1 PISTON
"RACERZ EDGE AZ" PORT AND POLISH
208 WEB CAM
KEHIN BORED OUT 44MM FCR CARB "RACERZ EDGE AZ"
DASA FULL EXHAUST
DYNA TEK REV BOX
MODIFIED STOCK INTAKE "RACERZ EDGE AZ"
VP 112 FUEL
62/40
FARAS04 is offline
post #2 of 4 (permalink) Old 12-30-2006, 05:00 PM
DumontTRXer's Avatar
Send a message via AIM to DumontTRXer Send a message via MSN to DumontTRXer Send a message via Yahoo to DumontTRXer
The '05 model has 2 options, 498 or 542. And they are very reliable
from what I hear. Ill be getting the 498 myslef. I drag, ride dunes, and mx. It seems like the best option for me.
DumontTRXer is offline
post #3 of 4 (permalink) Old 12-30-2006, 05:36 PM Thread Starter
FARAS04's Avatar
I like the idea of the 498. But the 498 Ice cube is just a cylinder kit. If I go that route, I would have to keep my stroke the same as stock. The crank needs to be replaced so should I use the OEM one or an aftermarket such as Falicon or Hotrods?
2005 TRX450R
ENGINE MODS:
DASA 500 KIT
JE 13.0:1 PISTON
208 WEB CAM
DASA FULL EXHAUST
DYNA TEK REV BOX
VP 112 FUEL
62/40
FARAS04 is offline
post #4 of 4 (permalink) Old 12-30-2006, 05:58 PM
The kit includes a wiseco piston. And you can get it in one of 2 compressions.... a 13.7:1 and a lower compression pump gas one.
