Head Porting - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 38 (permalink) Old 12-26-2006, 01:58 PM Thread Starter
DumontTRXer's Avatar
Send a message via AIM to DumontTRXer Send a message via MSN to DumontTRXer Send a message via Yahoo to DumontTRXer
I feel like a total noob asking this... But what is it that I need to do to the head to gain power? Does a port job and valve seat machining open it up to give me more power? Duncan racing offers that job for $450 ----> http://www.duncanracing.com/prods/PO-4VLV-VJ/ Is this a good deal? LOL. I need some major help with what to do.
Incase is matters, im running Ice Cube 498 with 13.5:1, rossier exhaust, hotcam 2. and aftermarket intake and jetting. But completely stock head, valves, everything.
DumontTRXer is offline
post #2 of 38 (permalink) Old 12-26-2006, 02:05 PM
sredish's Avatar
you ought to search this topic, which can be a touchy subject at times.
Site sponsors that do it and I'd suggest you go through one of them:
KBR/Venom
WPP Racing
Rossier Eng.
Max Power
sredish is offline
post #3 of 38 (permalink) Old 12-26-2006, 02:42 PM
lumi's Avatar
i havr heard good stuff from DRI PORTING....
they also use a serdi :D seems a bit pricey though.. 450..
-lumi
2006 TRX450ER
2009 BMW M5
lumi is offline
post #4 of 38 (permalink) Old 12-26-2006, 02:44 PM
VENOM all the way.
05- 480R -RED-
14.1 HammerHedz
Nelson Racing Ported Head/ KW springs
05 CRF cam/ HRC Kit
Ron Wood Racing Exh.
Dynatec CDI
41mm FCR-MX Carb-UNI Filter
909 Bars-CR High Bend-RED- Noss Stabilizer
Wicked Products +2 A-Arms-Graphite/Metalflake/triple rate Works
Rox Risers-1 1/4"-PCed Black-
ASV Perches and Levers-RED-
ProArmor-PRO XC Bumper-Graphite/Metalflake
Rear Grab bar-Graphite/Metalflake
A/C ProPeg Nerfs Modified
Axe Skidplate-RED- 06 Swingarm - G-Force Axle +2+2
Shockwears-BLACK-
Douglas Red Lable Rims
Kenda Klaws-Front 22"
Kenda Klaws-Rear 18''
supeRman is offline
post #5 of 38 (permalink) Old 12-26-2006, 03:59 PM
That One Mod
ghott's Avatar
Send a message via AIM to ghott Send a message via MSN to ghott
Check out the site sponsors!!!!!!!!!!! :)
Gary
My 04/05 Honda TRX450R Site
(^^^TRX450R tech articles, dyno testing, pics, vids, and more)
| '04 Racers Edge, AZ - WV #304 Bike...649cc Business Flat Dragger|
| '05 Racers Edge, AZ - Little Bike...450cc Play Flat Dragger|
ghott is offline
post #6 of 38 (permalink) Old 12-27-2006, 10:38 AM
450RRR's Avatar
a 'Serdi' would not be used for porting....but rather for a valve job by cutting the seats.....
not a standard procedure for porting......
I can attest to Venom/KBR......... but wont count out other sponsors here on the org...
good luck.....Greg
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #7 of 38 (permalink) Old 12-27-2006, 10:52 AM
lumi's Avatar
i think the serdi and porting are standard procedure with them.. but the depends on the number of valve which give the final cost...
-lumi
2006 TRX450ER
2009 BMW M5
lumi is offline
post #8 of 38 (permalink) Old 12-27-2006, 01:04 PM
Chuck's 06 450's Avatar
I have yet to see any documentation or dyno charts from companies like Duncan, Sparks, Pro-Circuit, Alba etc that show the gains they achieved by porting a 450. They might exist, but I haven't seen any of them.
Sponsors here actually show their results, and members verify and post results here.
Proof is in the pudding - as they say. I would never buy anything from anyone that is not willing to have their results published and showcased.
07 HD FLHT - sorry, but let's face it, riding a hog gets you laid more than riding a trx ;-)
06 TRX511ER - SOLD
Venom Porting and Head Mods with +1 KW Valves all around
Venom 100mm 14.25:1 Piston
Venom Modded ESR Intake
Venom Modded 43mm FCR with Rat Stack
Venom Exhaust
Hot Rods +3 Stroker
MaxPower Ice Cube Cylinder
Early HRC Cam
Chuck's 06 450 is offline
post #9 of 38 (permalink) Old 12-27-2006, 01:24 PM
mwsartain's Avatar
Here's a couple;
Rage Atv / Dee Manshack - Builder for the 2005 National Champ, John Natalie
Dasa / Dan Lamey - Builder for the 2006 National Champ, Joe Byrd
I've never used Dasa, but I have experience with Rage. Highly recomended!
Accept that some days you're the pigeon, and some days you're the statue.
04' TRX450R
Rage Racing Head, Ferrera Valves w/ + 1 exhaust, 05 CRF cam twisted 3 degrees, Racers Edge 490 13:1, 44 mm FCR, Trail Tech -4 Flywheel, Vortec Ignition, Rage Racing Pipe, LoneStar Long Travel, Lonestar Axle, Hermman Swingarm, Axis Shocks, GT Thunder Link, Douglas Shamrocks, Burgard +1 Stem, Protaper Bars, Fullbore Hood, AC nerfs, IMS pegs, Jannsen ant-fade, Lonestar carrier, ASV levers, Lonestar Hubs, Duncan Bumper, IMS Nerfs-Pegs and Heel Gaurds
mwsartain is offline
post #10 of 38 (permalink) Old 12-27-2006, 01:52 PM
ernie660r's Avatar
Rage ATV or Dasa are excellent choices.....
07 Renegade 840cc, 89 TRX250R
04 TRX450R stock stroke and bore, play bike!!
Racers Edge Tuscon AZ, Top Notch Guys
ernie660r is offline
post #11 of 38 (permalink) Old 12-27-2006, 02:03 PM
Love my Venom!!
Why is it that slim and fat chance mean the same thing?
07 CRF250R
05 450r- Venom Piston- Mixxer Magic- Kibble White- Dynatek- HC2- Pulse Charger- GT Thunder
Sheepless is offline
post #12 of 38 (permalink) Old 12-27-2006, 02:08 PM
I highly recommend Rage as well.
Special thanks to Rage for all your hard work...
Team DTO
Vital is offline
post #13 of 38 (permalink) Old 12-27-2006, 05:22 PM Thread Starter
Awesome... Thanks for the help guys! Both Rage and Dasa have VERY good credentials... but looks like I will be going through Dasa since their shop is only 15 min away. Ill be sure to post up the flow chart when it gets done.
post #14 of 38 (permalink) Old 12-27-2006, 05:37 PM
Awesome... Thanks for the help guys! Both Rage and Dasa have VERY good credentials... but looks like I will be going through Dasa since their shop is only 15 min away. Ill be sure to post up the flow chart when it gets done.[/b]
I think we'd all be much more interested in a dyno run...
06 TRX511ER - SOLD
Venom Exhaust
Hot Rods +3 Stroker
Early HRC Cam
post #15 of 38 (permalink) Old 12-28-2006, 08:56 PM
Lord of Combustion
mixxer's Avatar
<div class='quotemain'>Awesome... Thanks for the help guys! Both Rage and Dasa have VERY good credentials... but looks like I will be going through Dasa since their shop is only 15 min away. Ill be sure to post up the flow chart when it gets done.[/b]
[/b][/quote]
flow charts don't mean anything...and sometimes they mean less than that.....
a dyno run...done on the industry standard : DYNOJET..... would be a lot more useful for a comparison that really means the most for the most people....
hit me up at jcziehl61@gmail.com
My non "wheelchair class" ride: 2007 CRF270R / extra armor and guards / pumped up / geared up/ soft terrain woods runner..... dyno was B4 pump gas Big Bore
mixxer is offline
