LinkBack | Thread Tools |
#1 (permalink) |
Super Moderator
So I've read around here that storing your gas in plastic gas containers is not the greatest. I thought I saw where the gas stored in plastic gas containers over time actually lose points.
Unfortunately, I only have 1 metal gas container, and the rest are plastic. When I purchase my fuel (110 sunoco), I purchase 9 gallons at a time. 5 gallons in a plastic container, and 4 in the metal container. I use the plastic container first, to go ahead and burn it up so it doesn't have to spend a lot of time in the plastic container. And I use the gas in the metal container last. I've been looking around to buy another metal gas container, but they don't make them too much any more. The only thing I can find is this thing called a "safety gas container" for $40! So can anyone shed some light on the metal vs. plastic gas container debate? And does anyone know where they sell cheap metal gas containers? Any info is appreciated.
Gary My 2005 Honda TRX450R Site (^^^tech articles, dyno testing, mods, pictures, videos, etc.) ![]() | Wicked Motors | Xceldyne/PSI | JE/DASA | Dynatek | SREDRUM | Web Cams | | RE AZ/Rage | Direct Drive | Ohtsu/Pro Wedge/Douglas | Stellar | Marvin Shaw | |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
My VP rep tells me the same thing about metal and plastic containers. He didn't get into specifics but did say that over time gas will turn bad in plastic containers and will last up to 6 months in a metal one. He also said that if I'm done using gas for the weekend in the plastic jug then you can pour it back into the 5 gallon or 55 gallon metal container it came out of. Hope this helps.
Sonny
Demon Industries TRX522 |
#3 (permalink) |
I transfer the fuel I'm immediately going to use from a metal can into a plastic then into my quad's tank. Reason I use the plastic at all is to help keep from spilling it, since the plastic one has the long tube.
Plastic breathes and lets the pressure of the fuel out. If you've ever seen a quad's tank with graphics that's bubbling, it's because of the gasses escaping from the tank. Metal is sealed tight and that's why fuel won't go bad in it. Fuel can go bad in a plastic tank over time. |
#4 (permalink) | |
Super Moderator
#5 (permalink) | |||
#6 (permalink) |
Direct sunlight on the plastic jug will speed up the process of ruining the fuel.
Different levels (thickness and type) of plastic containers affect the process as well. I have heard it takes 6 months of normal storage in a VP approved plastic jug before it goes "bad".
Why is it that slim and fat chance mean the same thing? ----------------- 07 CRF250R 05 450r- Venom Piston- Mixxer Magic- Kibble White- Dynatek- HC2- Pulse Charger- GT Thunder
#7 (permalink) |
Super Moderator
So does anyone know who sells a decent priced metal gas container? :)
#8 (permalink) |
I have always bought my race gas in the 55 gl barrels...back When I raced 2 wheel moto cross I would go through it fast so there was never a worry about age....But I have always kept the barrell in my shop on a pallett....I do remember reading a VP brochure a few yrs back about that if its kept in a metal sealed container something like indefinite storage...? But One thing I can tell ya for what its worth is The last barrell I had left over took me 3 yrs to use up!!! NO BS even still looked and smelled great...But I have no way of knowing how deterioraed it was??? But my 250R LRD hi comp 350CC race gas motor ran fine on it to the end...SO my feeling is..keep it in the barrell,off the floor,dry and in an insulated shop......Late
"04" TRX 450..Leager,AXIS,Vortec "00" Lonestar 250R 350 bigbore "05" TRX 90 sons old bike..now pit bike "07" TRX 450R HRC..White Bros ex. "07" TRX 400 EX LAEGER +2 A-ARMS CUSTOM AXIS TAG STEERING STEM TAG HANDLE BARS ASV LEVERS BRADED FRONT BRAKE LINES AXLE W/ANTI FADE NUT WHITE BROS EX. 04 HRC CAM WISECO 13.5 PISTON VORTEC IGNITION K&N AIR FILTER BLINGSTAR NERFS TAG FRONT BUMPER QUADTEC HOOD QUADTEC SHOCK COVERS |
#9 (permalink) |
I guess im lucky I ride so much things like plastic vs metal containers just dont come in to play.....
**06 450ER**... #3 (Dale lives on) 86TRX250R (mostly stock 66mm bore x 72mm stroke) **for sale** 86TRX250R (ESR310 72.5mm bore x 72mm stroke '298cc' fully modded) **SOLD** 88TRX250R (ESR330 77.5mm bore x 74mm stroker '345cc' fully modded) HRC kit (all but gone) Hot Cams stage III Okie porting w/ATP CV4 springs (36mm Ti/31mm) Venom/KBR N2O Porting w/KW springs (37mm/31mm) Venom/KBR 487 100mm 14.25:1 piston Cold Fusion Nitrous** Venom 'QP' pipe ESR Pro Series pipe ESR modded intake w/RAT stack 42mm Taper-Bored FCR Direct Drive clutch lockout, CR500 springs GT Thunder-Link w/Durablue Lowering Link Durablue Anti-Sway Bar Modded shock mounts Rage Modded Tranny Jetting/Carb: #168, #45slow, NGPR needle 3rd clip, #55 Leakjet, Pilot 2 turns out. Jetting/N2O: 22N/21F (22hp) *STU Comp Cut 21x12x8 (6) paddle 'Padla Brats' on Douglas Blue label 8x8..... Thanx to: Venom/KBR (Mixxer/Kam), Rage ATV (Dee), Sredum (Chris), and many ORG members |
#10 (permalink) | |
Super Moderator
I only get to ride on the weekends...can't bring my quad to the dorms here at my university....some higher ups might get a little pissy :D
#11 (permalink) | |||
What? no track leading from the men's dorms to the fem's? then back around the Dean's residence and upstairs to the restrooms? I figured you would of had burms in the hallways by now.... vroooom....
#12 (permalink) |
http://www.forestry-suppliers.com/product_...age.asp?mi=6301
That's a metal gas can, 40 bucks and 5 gallons, wait make that 50 because you have to buy the metal spout. not worth it haha northern tool has it too, http://www.northerntool.com/webapp/wcs/sto...366&R=200323366 |
#13 (permalink) |
Super Moderator
Geez that stuff is expensive. I think I'll just be watching yard sales or something for old metal gas cans....
#14 (permalink) |
Find a VP (or other brand) distributer and by some gas in 5 gallon pales. Where I last bought VP fuel it was an extra $10 to get it in it's own 5 gallon metal container than to have it pumped into my jug from a big drum.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." -- Mark Twain
#15 (permalink) |
Just to reiterate, storage in plastic jugs is bad. The lighter hydrocarbons evaporate at ambient air temperatures--plastic jugs can't contain them. Loose too many and cold starting deteriorates as does octane rating. Also, sunlight oxidizes tetraethyl lead further reducing octane rating (if it's a leaded fuel).
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
