LinkBack | Thread Tools |
#1 (permalink) |
Newbie to Honda and the forum. I just bought a very clean 05 trx450r with low hours and w/o the manual and I was wanting to give it a fresh oil change and filter before I start putting hours on it. I read on the forums that the manual recommends using HP4 10w-40 for the engine oil and HP Transmission for the tranny oil. I am wondering how much should I buy of each to change both and does anyone know where I can download or view an online manual that explains what goes where and how much. Thanks
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
a little less than a court just drain i pore a little oil in when i got the filter n plug out to get some extra oil out thats dirty,then put plug back in n filter then fill it up between L-H then run it let it sit for a while n check it out
i use the hp4 for my engine , and gear saver for the transmission on the transmission side u use oil with out MOLY cause slipping hope this helps
TRX533R |
#3 (permalink) |
Solid Gold DASA500R!
the engine side is fairly easy to do. just poor until the glass shows full. i think its like .82 quarts. on the tranny remove the check oil bolt, it is on the bottom right side of the clutch cover. it looks like you can remove it with a phillips screw driver. add hp tranny fluid (red bottle 80/85) untill a little starts pooring out then just replace the check bolt. once you turn on the bike let it run a while then check your engine side to see if it needs a couple more drops of oil.
Ordinary people, simply doing their jobs, and without any particular hostility on their part, can become agents in a terribly destructive process. Moreover, even when the destructive effects of their work become patently clear, and they are asked to carry out actions incompatible with fundamental standards of morality, relatively few people have the resources needed to resists. -Milgram ![]() R.I.P. Jesse aka Jay Dash you were a great friend for sure! and always will be |
#4 (permalink) |
Venom Sand Slinger
Oops! Darn newbs, double posting topics and all. j/k man, lol.
Anywhoo, I responded already in your other duplicate topic. BTW- Welcome to the site!!! Almost anything you want to know/learn about the Honda 450R can be found on this site. Welcome to the addiction.... Later- Kris
2004 TRX522R 61.6hp/41.45 ft lbs Venom Porting, Immortal Intake & +1 KW exh. valves, 99 mm 12:1 Wiseco 2-ringer piston, +3mm stroker crank, HC Stage 3 cam, 43.5mm Sredrum taper-bored FCR, Venom full exhaust, Modded ESR intake/ K&N, Dynatek prog. ignition. 2008 Yamaha Raptor 815 Venom big bore stroker 87hp/64.5 ft lbs |
#5 (permalink) |
Thanks everyone for the replies, this ex 2-stroker turned 4-stroke should be able to get-r-done now. Found a manual on here to download too. Great forum.
<span style="font-family:Century Gothic">FLYNBRIAN |
#7 (permalink) | |
Put 650 cc in the trans! The above method shorts you oil and you will prolly strip the check bolt! LEAVE THE CHECK BOLT ALONE AND MEASURE THE AMOUT OF OIL YOU POUR IN !! |
#8 (permalink) | ||
#9 (permalink) | |||
The method you use will leave the trans level low. Next time you fill your trans using your method see how much oil is left in the bottle when it comes out of the check hole , I will bet it is more than 300 cc left in the bottle! Alot of people on this site brag about the bolts they strip or break off . This is one of those bolt that is easy to break or strip. Anyway no offence,I personally don't like filling the trans with the check bolt method.... |
#10 (permalink) |
Welcome aboard Brian. This is a great site for 450R riders.
Keep our riding areas open! Blue Ribbon Coaltion http://sharetrails.org/ National Off-Highway Vehicle Conservation Council http://www.nohvcc.org/ Washington ATV Association http://www.waatva.org/ ATVA http://www.atvaonline.com/ OMRA http://www.omraoffroad.com/ Jones Creek Trail Riders Association http://www.jctra.org/ Dirt Church http://www.dirtchurchatv.com/ OOHVA http://www.oohva.org/ WOHVA http://www.wohva. org/ Battle Ground Washington Interior/Exterior House Painting Contractors |
#11 (permalink) | |
Welcome to the site
2009 Mustang GT Premium! Some stuff to come! Brakes are for sissies’ Quote:
#12 (permalink) |
Dose anyone know if you fill the oil to full in the glass eye, then start it for a few mins to let oil pump through the engine and drain, and then fill it back up once it drops,. Or do I just fill it to H on the eye piece without it pumping through and leave it there. The only thing is, is that when I did that the oil dropped significantly and there was no oil left because it all pumped through the engine. I know on a blaster you fill it up, then turn on the engine for it to drop, then fill up up more so that when the engine is running it is on full.
#13 (permalink) |
Long story short .....just make sure the engine side oil is always between the L and H marks on the sight glass. Check the level after the quad has been sitting for at least a few minutes so the oil can drain down.
Tim 07 TRX470ER ![]() 14.4:1 98mm CP piston Dasa custom ported head with Ferrea SS valves Web 242/921 Web HD dual valve springs/ ti keepers Dasa 43.25mm FCR Dasa intake Dasa Classic Exhaust JD +2 ST A-arms Elka Stage 3 Dune Series shocks F/R QUIKSHRK (OCP) +4 arched ladder swinger w/Derisi link G Force axle Pro Taper Contour CR Hi bars Houser +2 stem HID headlights Last edited by rocknhorse76; 04-20-2013 at 12:55 PM. Reason: Added text |
#14 (permalink) | |
Also on the tranny side I used the oil level plug when refilling, screw it back in and add a little more. And as far as stripping the srew plug, I also worry about this because it feels very easy to over tighten. I may start measuring the oil also like stated above to avoid possibly stripping the plug.
2005 450r hot cam Modified 05 hmf performance to fit 08 hrc header k&n intake dynatek cdi 185/45 jets, dynojet needle brm custom full graphics GBC xc masters fronts Sedona bazooka rears renthal 40 tooth rear sprocket jt 13 tooth front sprocket full skids pro taper contour fat bars Dwt rock n lok 4:1 fronts hiper duals rear houser +2 a-arms dual rate revalved front shocks Derisi linkage Quad tech humpseat maeir race plastics rock pro nerf bars dg bumper Armidillo drop bar |
#15 (permalink) | |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
