Old 04-16-2008, 07:02 AM   #1 (permalink)
450R Racer
Send a message via MSN to Ripper Send a message via Yahoo to Ripper
Default
So, you want to get an aftermarket hood and still run the Honda lighting? Well until Trew Industries/FourWerx Came out with there 100% Carbon Fiber hood you were left with the idea of hacking up your new bike to make it happen. But now, with this new hood that is designed to work with the stock 06-08 Headlight you can upgrade your 04-05 machine to better lighting and styling.
Introducing the FourWerx Stealth II </span>
To install the Stealth II Hood on a 04-05 TRX450R you will need the following items shown in the picture below. You can get them from VanWall or any local dealer. I was able to pick up a used light very cheap which included all the brackets and bolts, so I would suggest checking out the "for sale" section or other sources for used parts if you really want to save some cash. Some of the parts shown are not needed so I made a list of the parts with there Honda part number for you. You can use most of the bolts and what not from the 04-05 hardware you are about to remove so don’t throw them bolts out!
#1 HEADLIGHT UNIT
33110-HP1-600
#2 PIPE, CP
33113-MBW-D21
#5 STAY, R. HEADLIGHT
61105-HP1-600
#6 STAY, L. HEADLIGHT
61106-HP1-600
#7 STAY, HEADLIGHT
61108-HP1-600
#8 PLATE, HEADLIGHT
61109-HP1-600
#9 RUBBER, RR.
80116-MR1-000
You will need three of these.
#10 COLLAR
84706-HP1-600
#11 BOLT, FLANGE (6X12)
90004-GHB-610
You will need six of these.
#12 BOLT, FLANGE (6X25)
90004-GHB-670
#13 BOLT-WASHER (6X25)
93404-06025-08
<span style="color:#FF0000">You will need two of these.
Step by Step
1. You will want to remove the front plastics and stock 04-05 headlight housing and mounting hardware.
2. Remove the Fender Stays from the bike and discard.
3. Install the new fender stays #5 STAY, R. HEADLIGHT #61105-HP1-600 and #6 STAY, L. HEADLIGHT #61106-HP1-600. Note that the fender stays and the Headlight mounts are the same parts.
4. Attach the light to the fender stays/headlight mounts.
5. Locate and install #7 STAY, HEADLIGHT #61108-HP1-600 and #8 PLATE, HEADLIGHT #61109-HP1-600. You will need to drill mounting holes into the cross section of the frame for this portion. Be sure to put silicone sealant over the holes prior to running the bolt down in to keep things nice and sealed.
6. Once the rear of the light is all mounted up you can tighten down all the bolts and reinstall the lights into the headlight housing and hook up the wiring.
7. Reinstall your fenders.
8. Install your new FourWerx Stealth II Hood and enjoy the better light pattern of the 06-08 headlight and the killer look of your new hood.
When I get the time, I will take every thing off of mine and get pictures of each step to aid in your headlight / hood upgrade. But for now this will get you started.
MachMoto.com
The #1 source for custom streetfighter parts.
Ripper is offline   Reply With Quote
Old 04-16-2008, 07:12 AM   #2 (permalink)
Super Moderator
gumby46's Avatar
Send a message via AIM to gumby46 Send a message via MSN to gumby46 Send a message via Yahoo to gumby46
Default
Good one Steve, here is my walkthru for the headlight conversion to supplement your own.
I'm gonna be ordering myself a FourWerx hood to go with my new plastics!
<span style="font-family:Arial Black">k
2005 TRX450R - Red
HRC Kit (What is left)
12.25:1 Venom Piston
Venom Porting
HotCams Stage 2
DASA Exhaust System
ESR Intake (Ported by Bob McKray)
JD Performance +2 STD Travel Race Arms
2007 OEM Swingarm w/ GT Thunder Rear Re-Valve and MX Link
RPM Dominator II & Anti-Fade
...More pics and specs...
Online Reference Material for the TRX450R
gumby46 is offline   Reply With Quote
Old 05-06-2008, 10:49 AM   #3 (permalink)
stewster23's Avatar
Default
hey dont u need #3 socket, headlight?
port and polish
13:1 CP piston
+1 fierra valves all around
Kibble White Springs
DynaTek Programmable
HC Stage 3
13t front
39t rear
Fcr 42mm stock intake boot with dasa filter and sleeve
Full Dasa exhaust system
AC Black-line Front Bumper
ASV Clutch Lever with Hot start
Motowoz Triple Rate LT Comp/Rebound Adj(front)
Motowoz Dual Rate LT Comp/Rebound Adj (rear)
Elka Dual Link
RPM Dom #2
JD Performance +2 LT Black
21x12x8 8 Paddle Haulers on black baja t-9
21x11x10 Front sand stars on black baja t-9
Special thanks to: Dave at JD performance, jim and suzi at motowoz, and Morgan and john at Racers Edge.......
stewster23 is offline   Reply With Quote
Old 05-07-2008, 08:24 AM   #4 (permalink)
stewster23's Avatar
Default
bump
port and polish
13:1 CP piston
HC Stage 3
13t front
39t rear
Elka Dual Link
RPM Dom #2
Old 05-07-2008, 08:41 AM   #5 (permalink)
Super Moderator
gumby46's Avatar
Default
hey dont u need #3 socket, headlight?[/b]
#3? The #3 part in the diagram?
2005 TRX450R - Red
Venom Porting
HotCams Stage 2
DASA Exhaust System
Old 05-07-2008, 11:36 AM   #6 (permalink)
450R Racer
Default
No, the 04-05 wiring (part #3) is a direct fit into the 06-08 headlight housing.
MachMoto.com
Old 05-07-2008, 01:53 PM   #7 (permalink)
trxjwb's Avatar
Default
How much is the Hood shipped?
YUMA AZ
06 450R
trxjwb is offline   Reply With Quote
Old 05-07-2008, 01:55 PM   #8 (permalink)
Send a message via ICQ to mccown450 Send a message via AIM to mccown450
Default
i wish i would have done a write up on how to go from an 06 front end to an 04, but me and rick just swapped out whatever we thought we needed haha
Jordan McCown
foo why would i upgrade? fak no, this ones not even got 20 hrs, i plan on having it in there for at least 2 yrs, im mexican bro, i aint gonna replace it after not 20 hrs or w/e fak that.
I look at women like fishing....and i opperate off of a slot limit...either gotta be 20-22 other wise i throw em back LOL but I will take a cougar for sport every now and den hehe
<a href="http://www.atvdistrict.com/members/mccown450" target="_blank">
</a>
mccown450 is offline   Reply With Quote
Old 05-07-2008, 02:08 PM   #9 (permalink)
FourWerx's Avatar
Default
$190 shipped for now.. Prices will be going up soon though due to the cost of carbon fiber going thru the roof.
SO get them cheap now..
Thanks, Jay
*FourWerx Carbon*
"Innovative Lightweight Products"
www.fwcarbon.com
contact email: jay@fwcarbon.com
* Titanium Motor Mount Sets * 04/05 TRX450R - $70.00 Shipped inside US
* Stealth I Carbon Hood * $152.00 + shipping
* Stealth II Carbon Hood * $152.00 + shipping
* TRXS Carbon Hood * $152.00 + shipping
* TRXS White Hood * $108.00 + shipping
*ASV Lever, WalshRC Suspension, JB Racing Suspension, Ohlins , Precision, CP Pistons*
FourWerx is offline   Reply With Quote
Old 05-19-2008, 11:31 PM   #10 (permalink)
stewster23's Avatar
Default
funny i didnt even need to cut old brackets off from the 05 light
port and polish
13:1 CP piston
HC Stage 3
13t front
39t rear
Elka Dual Link
RPM Dom #2
Old 08-22-2009, 08:39 PM   #11 (permalink)
ridinredodb's Avatar
Default
do you have to drill holes to do the 06-08 headlight conversion? i really want to do this conversion, it looks so much better than the 04-05 hood and light
04 honda TRX 450R
way too many extras to list
ridinredodb is offline   Reply With Quote
Old 08-22-2009, 09:03 PM   #12 (permalink)
450R Racer
prlandry's Avatar
Default
I wish those pics were still up...... I'm curious as to what that hood looked like.
prlandry is offline   Reply With Quote
Old 08-27-2009, 05:54 PM   #13 (permalink)
HRE
HRE's Avatar
Default
I wish those pics were still up...... I'm curious as to what that hood looked like.[/b]
visit us on the web at www.fwcarbon.com, i believe there is a picture on the website.
HRE is offline   Reply With Quote
Old 09-10-2009, 04:05 PM   #14 (permalink)
rallysoob's Avatar
Send a message via AIM to rallysoob
Default
only thing on your website for the 450r is the trx-s hood. and a coming soon pic of the stealth 3. can you guys get sum pics up so we can start buying these hoods... they 'sound' great so far...
rallysoob is offline   Reply With Quote
Old 09-13-2009, 12:46 AM   #15 (permalink)
Default
Yea I need a pic of that new stealth lll hood. Im in the market for one.
marinenyc is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
