Old 01-28-2009, 08:41 PM   #1 (permalink)
Talking
MY raptor 700
yeah, but does it go fast!!!
dlkfx450 is offline   Reply With Quote
Old 01-28-2009, 09:05 PM   #2 (permalink)
flippincgfighter's Avatar
Default
Wow, great build. Who did your Motor?
Motor Specs?
-Kip
05 Drag Bike
flippincgfighter is offline   Reply With Quote
Old 01-28-2009, 09:06 PM   #3 (permalink)
Default
BTW, i have always been jealous of raptor TQ. Lol
-Kip
05 Drag Bike
Old 01-28-2009, 10:53 PM   #4 (permalink)
Default
-Kip[/b]
i built and dyno tuned the motor....
its stock 102mm bore
thats about it....
its a full trail/ duner with skid plates and full plastics.... but it rips for sure.... needs a swinger, maybe a +4
Old 01-28-2009, 11:17 PM   #5 (permalink)
stevefarris's Avatar
Default
Very nice!!
I'm hoping to make similar numbers after a couple small changes pretty soon.
Steve
stevefarris is offline   Reply With Quote
Old 01-29-2009, 02:55 AM   #6 (permalink)
Default
Very nice!!
I'm hoping to make similar numbers after a couple small changes pretty soon.[/b]
whats your build bueller?
Old 01-29-2009, 08:06 AM   #7 (permalink)
Default
Very nice!!
Ported head, valves/springs, megacycle x-2, cp 12.5:1, barker duals, pro design intake, dynatek controller, +2 KDS TB.
The controller is getting swapped for the PC5 when they're available and a dynatek ignition is in the very near future. It won't make the numbers you have but they should be decent. It made 60/49.5 on the KBR dyno in it's current state. With the proper tune and better ignition, I'm hoping to gain a couple HP. I've been told the ignition should fit my build pretty well.
Steve
Old 01-29-2009, 08:30 AM   #8 (permalink)
556KingR's Avatar
Default
looks like it would be tough to beat that thing with a 450r! Nice power for sure.
556KingR is offline   Reply With Quote
Old 01-29-2009, 02:38 PM   #9 (permalink)
Default
the ignition adds a couple of hp but it mainly helps in lengthening the power band up top , as well as the FCI intake......notice my bike makes within 10% of peak power at redline.... the rpm's are off for whatever reason but the bike hit the rev limier @ 9100
KBR"S dyno reads similar to mine, maybe a tad higher due to different tires...... it always good to get REALISTIC numbers though...
Old 01-29-2009, 06:50 PM   #10 (permalink)
Default
KBR"S dyno reads similar to mine, maybe a tad higher due to different tires...... it always good to get REALISTIC numbers though...[/b]
Tell me about it. I see a lot of posts on other forums where guys brag about a three mod raptor doing 54-56 hp. Some dynos can be heartbreakers.
As far as lengthening the power up top, that's exactly what I need. Mine peaks HP at 7000 and drops 10 hp before it hits the limiter.
Steve
Old 01-29-2009, 07:00 PM   #11 (permalink)
greylynn's Avatar
Default
Nice numbers and killer torque! I have been eye balling my wifes 07 Raptor in the garage for awhile now..... Thing has no hours on it, perfect to turn into my lil project since she is knocked up and can't ride it anyway! lol
Bueller I never knew you picked up a raptor
Grey
06' TRX
Fast when towed by buddy......
greylynn is offline   Reply With Quote
Old 01-29-2009, 10:48 PM   #12 (permalink)
Default
i have the dynateks and FCI intakes here....
here are some sheets
FCI VS prodesign... 734 trinity build
with the FCI and prog dynatek this bike had a nice long powerband
Old 01-30-2009, 01:51 AM   #13 (permalink)
Default
If i had that trinity raptor, i would be running that prodesign intake and short shifting that thing at about 7 grand. The FC carrys it farther, but the prodesign seemed to make a good bit more TQ and HP down low.
-Kip
05 Drag Bike
Old 01-30-2009, 12:25 PM   #14 (permalink)
Default
-Kip[/b]
the gear spread is about 2500 rpm...
so if u shift @ 7k that puts u down at 40 hp at 4500.... well out of the power band
With the FCI u can shift later @ 8k and drop down to only 50hp at 5500 rpm
Old 01-30-2009, 04:39 PM   #15 (permalink)
KBR
KBR's Avatar
Default
Do both of those graphs have the Dynatek or just the FCI intake one?
KBR is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
