#1 (permalink) |
Just wanted to show this graph of a YFZ using the Fuel Custom Intake. Blue is all stock and red is the Fuel Custom (plus HotCams and Pulse Charger, so don't misinterpret the power gain as a sole result of the intake).
This is one of the flattest fuel traces you will ever see. You'll pull your hair out trying to get a line this smooth and consistent with other intakes, very impressive. I'm dying to see how one of these will work on a TRX.
Dan '05 450R - lot's of stuff'02 400EX - see above '02 90Kasea - "Blue Dragon" '06 90Kasea - flower stickers '70 Dude - lot's of miles but still runs '70 Blonde - handles great but requires lot's of upkeep '95 Lil Man - reliable and predictable '96 Chic - loud and uncontrollable |
| Sponsored Links | |
Advertisement |
#2 (permalink) |
Administrator
The person who is getting that build is sure getting there moneys worth.
Nice post.
The Problem With Socialism Is You Eventually Run Out Of Other People's Money. - Margaret Thatcher |
#3 (permalink) |
there is a reason why all the factories choose to go with a wide diameter filter end and a constant taper to the carb bell.... quite a few reasons actually
the FCI intakes are taking over where the factories call it "good enough" and are going for all the extra they can get within the design limitations imposed by the frame\suspension last summer Mr, Habit and i were discussing how to go about making such an intake....short of having access to an injection molding factory..... but it seems as though FCI was already a step ahead..... all props to them great mid to top curve....more of a plateau actually :)
Venom Performance 517 655-2870 SREDRUM Racing \Ohio \ Dyno Tuning 419 618-5982 KBR Sand Sspecialists 801 967-7100 ....learn to have some patience??!!......how long is THAT going to take??!!! |
#4 (permalink) |
The first set-up with the FCI was also flat like that but, that was on a VERY dialed in machine and I attributed it to the fact that I had worked extensively with this machine to get it there. This machine was done with baseline jetting from the last FCI install and one main jet change after the first pulls the machine made. A total of 13 runs!!! The first series of pulls was 8 pulls to get the machine up to operating temp. I rejetted and it took another 5 before it lost power due to heat soak. Simply AWESOME. I left it that rich purposefully and will dial it when in the spring before the first race.
That is a properly designed velocity stack, it just happens to have a turn in it. Tony
Hi ho. Hi ho. It's off to work we go......... You can drink an ugly girl pretty but you can't drink a fat girl thin...........Jeff Daniels You can fix ugly but, you can't fix stupid...............Ron White
#5 (permalink) | |
:D i guess that about says it all
#6 (permalink) |
Comparison
![]() WOW!!! Where's the Honda's?
#7 (permalink) |
i'm waiting very impatiently myself to try out a FCI setup on old Booster..... as soon as they are ready, i gotta have one!
#8 (permalink) | |
#9 (permalink) | |||
I KNOW it's coming but, the Honda NEEDS help. Tony
#10 (permalink) | |||||
#11 (permalink) |
#13 (permalink) |
i know they know what they are doing enough to make a super one for the honda....
but actually the yamaha intake had more room for improvement.. on another topic....my Z400 needs one too.... the ESR i have on it is way too long with its single dia \ parallel wall section!!
#14 (permalink) | |
Banned
#15 (permalink) | |
also important to Garret and Bro is having dyno runs with jetting info on all sorts of setups so take a number and get in line
| Thread Tools | |
