2003 Z400 Wont Start, Help!!!!! - Honda TRX Forums: Honda TRX 450R Forum
Old 03-09-2005, 06:21 PM   #1 (permalink)
Banned
Default
Buddy has an 03 Z400 and it will not start on its own ( with the satrter) but if you pull it it will fire right up instantly. It has great spark, its getting fuel, comp is good and its getting air. Please help.
There are only 3 things required to run an engine as far as I know, Fuel, Air and Spark and it has all 3.
8
#8trx450r is offline   Reply With Quote
Old 03-09-2005, 06:37 PM   #2 (permalink)
trx480ryan's Avatar
Send a message via AIM to trx480ryan Send a message via MSN to trx480ryan
Default
Charge the Battery
Thats all i can Think of. Is there a clicking when you hit the starter.
Ryan
1995 Ford Ranger Splash
6'' Rough Country Lift
33'' BFG M/T's On Procomp 1089 Wheels
Super Runner Steering Kit
2004 TRX480R
Bored 30 over, 12.5.1 Comp
Rage Ported Head
Sredrum Bored 42.5 FCR
Powder Coating
Rossier Exhaust
Stage 2 Hot Cam
trx480ryan is offline   Reply With Quote
Old 03-09-2005, 07:39 PM   #3 (permalink)
Banned
Default
The starter works fine guys, it just doesnt start.
Thanks, 8
Old 03-09-2005, 07:49 PM   #4 (permalink)
TRX450rlude's Avatar
Default
the choke is stuck off, this happens to all of them. Do this and it will prove it. Take the airfilter off, put your hand over the hole where the air filter goes, closing it off. Then start it. This manually chokes it and it will start right up. What you will find is where the choke screws into the side of the carb, unscrew that and the choke will be stuck in there, You will have to pull really hard to get it out but it will come out with enough force. Then clean it all out and put it back together.....this will fix it. Ebay sells a manual choke that fixes this problem...good luck and ask me if you have any questions. B)
= Kansas City Missouri =
04 TRX450r
86 310R (250r)
03 Suzuki Z400 (my sons)
06 Yamoto 150 (my sons)
02 KX65 ( my sons)
03 CRF450r
05 Nissan Titan
91 Yamaha FZR600
TRX450rlude is offline   Reply With Quote
Old 03-09-2005, 08:08 PM   #5 (permalink)
Banned
Default
Lude I disassembled the entire carb today and cleaned it all out to see if that may have been the problem but it was clean, the choke thing came right out with no trouble too. The choke lever moves perfectly too, I am lost on this one, I thought maybe it was some type of a safty switch or something ( neutral safty swith or?) but it has good spark so that kinda eliminates that too.
This bike is out to drive me nutts I think! Makes no sense that if I pull start it it will fire up instantly but you can hold the starter button and it will just whirl over like nothing and not start. Any other ideas?
Thanks, Corey
Old 03-09-2005, 08:16 PM   #6 (permalink)
Default
This might be a dumb question, but are you sure the starter is turning the motor over?
Port Work [/url]
BOONE450R is offline   Reply With Quote
Old 03-09-2005, 08:22 PM   #7 (permalink)
Banned
Default
<div align="right">
[/quote]
Yeap, its sucken air in the carb and pushin air out the exhaust :) . The only dumb question is the one not asked .
I figure the problem is its scared of all the Hondas surounding it in the garage :ph34r: .
8
Old 03-09-2005, 09:57 PM   #8 (permalink)
Default
Thanks, Corey
<div align="right">
[/quote]
thats crazy, I would try to manually choke it like I said before just to see if that starts it. I had to start my z like this a few times until i fiqured out it was the choke. My choke acted fine too, but when I took the top off the carb off. there is a little hole that you can look in, while looking in there and moving the choke back and forth, the choke would never actually move, but everything else would....Thats all I can think of though....good luck.
04 TRX450r
86 310R (250r)
02 KX65 ( my sons)
03 CRF450r
05 Nissan Titan
91 Yamaha FZR600
Old 03-09-2005, 10:05 PM   #9 (permalink)
Banned
Default
Thanks Lude, i will check it in the morning along with the valve clearences and I will keep ya posted.
8
Old 03-09-2005, 10:57 PM   #10 (permalink)
Fender's Avatar
Send a message via AIM to Fender Send a message via Yahoo to Fender
Default
does it have gas??lol j/k :D
08 Mx Ltr.
05 Mx Trx.
Cu Remarketing,Cernics, Rat Ind.
Fender is offline   Reply With Quote
Old 03-09-2005, 11:10 PM   #11 (permalink)
Default
Is the battery good? If the battery is weak it will not turn the motor over fast enough to start. My sons Z did that, the motor would turn over but not start unless pulled. Fully charged battery and it would fire up but once it sat and the battery drained some it would just turn over and not start.
450r38 is offline   Reply With Quote
Old 03-10-2005, 07:37 PM   #12 (permalink)
Banned
Default
Okay the problem was the valve clearneces , the valve seats are pushing themselves into the head, responsable for reducing the clearences.
Intakes are suposed to be between .010 and .020
These were .001 and .004
Exhaust are suposed to be between .020 and .030
These were .009 and .010
The guy didn't want to spend the big bucks so I reshimed all of them to their greatest tolorences and guess what???? It fired RIGHT up and runs perfect but for how long??? I will report back if and when it fails again :) .
8
Old 03-10-2005, 09:18 PM   #13 (permalink)
trx480ryan's Avatar
Default
Good job, lol well i guess time will answer you question.
Ryan
6&#39;&#39; Rough Country Lift
33&#39;&#39; BFG M/T&#39;s On Procomp 1089 Wheels
2004 TRX480R
Rage Ported Head
Powder Coating
Rossier Exhaust
Stage 2 Hot Cam
Old 03-13-2005, 03:06 PM   #14 (permalink)
diezel's Avatar
Send a message via Yahoo to diezel
Default
i had the same problem ,i bent the valves,i was being chased by cops and pinned it ,got home she wouldnt start,only if you pushed start it.
05 trx 450r(waiting on hrc kit,hmf slipon)
03 cadillac cts l,love this car!!
03 cadillac escalade
02 grand am coupe
06 vette coming next!!!
diezel is offline   Reply With Quote
Old 04-16-2005, 10:27 PM   #15 (permalink)
rider's Avatar
Default
hah i was gunna say the battery to
03 Z400
909 Bars
CT Pipe
Wisco Piston
K&N airfilter
Dyno jet kit
AC front bumper
Pirelli Race Rail 6PLY (tires)
hotcams stage 2
ac nerfs propegs
renthal chain & Sprockets
Silver maier plastics
3 curve cdi
power coated black frame
Hot Rod crank
Any Suggestions on a decal kit?
50-PIT BIKE
Po po 90 troylee edition
rider is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.6.0
