LinkBack | Thread Tools |
#1 (permalink) |
I just bought a 2007 TRX 450 today. After getting it home and riding it around for an hour or so, the red warning light next to the green neutral light is staying on. I hope it is some thing minor. It didn't have the manual with it so I don't know what might be causing this. I was wondering if maybe the oil was low or some other easy fix. Any information would be great.
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) |
The light never came on while I was riding even though I was riding pretty easy, (I got lucky there Ha-ha). It has been sitting for a couple of hours and now when I start it the red light stays on. Is there another fan besides the radiator fan?
#5 (permalink) |
I just let it run for about a minute and it never went off. The oil level is half full in the glass sight. Should it be full? I see the H and L marks on the case next to the oil sight but I assume that it is like most other bikes. You want the oil to fill the glass oil sight about half way?
#6 (permalink) |
Desert Racer
That light is not the oil temp light, it is the coolant temp light. If it comes on while riding, it usually means the quad is overheating. The fan should also be on. If the quad is overheating, then you should shut it off when the light comes on. Check coolant level and see that the radiator is full.
Now from what you say, the quad may not be overheating. If the quad sits for a couple of hours and then you start it, does the light stay on? If so, the temp sensor could be bad and may need to be replaced. If the sensor is good, it could be a wiring problem, need to check over the harness. Doug
2004 TRX450R, 2008 TRX700XX (BITD #639 Quad Ironman Expert) 2013 sponsors: Teixeiratech.com, Motowoz.com, Dirttricks.com, Snailmotorsports.com, My bank account. 2008 TRX700XX 2005 TRX450R 1986 TRX250R |
#7 (permalink) | |
now i feel like a idiot, of course its a coolant temp light its sensor is in with the thermostat lol |
#8 (permalink) |
Coolant is full, oil on both sides are at proper levels, and the fan is spinning fine. I was thinking something in the wiring is gone bad. I guess replacing the sensor is the only way to tell if it is bad? It seems fine but that light just will not turn off. I just got it today and it is making me really worried. I got a pretty good deal on the Quad at 2,450.00. It is an 07 ER in great shape. He in my area they are selling for about 3500-4000. I am hoping to flip it and make a couple hundred bucks. If I have to start fixing stuff that won't work. I really hope it is simple. The rear brake light has been removed. Would that mess up other things in the electrical system?
#9 (permalink) |
No the break light has no effect on it. I would have to agree with the previous post and say its a sensor if your fan is working correctly and it is on even when its cold. I have seen a thermostat stick and cause machines overheat but I don't think this is the issue in your case.
06 450r sb/ss Cp 13.5 dasa classic exhaust green wire mod Web 208 rbc crf headgasket re +1 Gen 1 head Cr500 springs Re taper bored carb +2 arms Lonstar axle Propegs Fly fat bars One graphics TO MUCH IS NEVER ENOUGH! |
#10 (permalink) |
Does the green light come on when its in neutral?
You let it run for just a min shut it down and you didnt see it turn off in that time? try a little longer i know mine stays on for a little bit and then goes off Where are you located?
2006 TRX450ER Black Glued On Racing # 89 HRC kit Bill Ballance Carbon HMF GTT Suspension HD USA +2 A Arms GForce +4 Axle Hiper Tech3s / Maxxis Tires Lonestar +1 Antivibe stem FCI Intake Kit CCP Stabilizer AC Racing Pro Armor PRM Powermadd |
#11 (permalink) |
unplug the sensor, does the light go out? if not then the wire is cut or shorted to the frame. if it goes out it's the sensor bad.
drag bike 06 450ER Powered by Racers Edge, AZ SS/SB still clutch'n 4.57 in 300' trail bike 07 450ER SS/SB powered by spare parts and still faster than yours
#12 (permalink) | |
I am located in Western Wyoming about 75 Miles South of Jackson Hole. |
#15 (permalink) | |
thats what I was getting at... but he didnt answer the question
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
