Old 08-24-2009, 01:42 PM   #1 (permalink)
Default
Hi there,
Racing Bikes and cars is my passion and for almost 20 years. I bought my first fourwheeler during my yearly visit at my friend place in Baton Rouge Louisiana. Now I just bought a 2006 TRX with a high compression Wiseco piston in it, other camshaft (have no clue about degrees or camprofile because my friend is not at all a technician) and other needles in the carb. Now he has put on a standard exhaust and filter box. The problem I have it that if you accelerate hard that he hold's back. Also if you accelerate gently to max RPM he stutters and in higher rpm's gains some smoothness. I can drill some holes in the filterbox but need some advice for the exhaust. Would a slip on be enough, and which one. it dousn't have to make to much noice because my neightbour is an Al Gore fan and thinks he can save the world by driving his bicycle!!!
So please some expertese on the exhaust.
I know that my facts and info on the bike are not very technical (hate this because I tune race engine's for years) but I don't have more info without opening the carbs and engine.
Thanks a lot already for reading my problem
Tom
tompi69 is offline   Reply With Quote
Old 08-24-2009, 05:08 PM   #2 (permalink)
zakthemaster's Avatar
Default
sounds like jetting is wacked. if it was me, i would go buy the HRC jet kit and start over from scratch. i would say it pry has a hot cam camshaft in it. just because they are very popular
2006 trx450r
tusk gas cap..........and a few other items
zakthemaster is offline   Reply With Quote
Old 08-24-2009, 05:22 PM   #3 (permalink)
dirtycarl's Avatar
Default
Your best shot at getting an answer to your engine question is definitely to post it in the raffle section.
05 YFZ450
dirtycarl is offline   Reply With Quote
Old 08-24-2009, 06:05 PM   #4 (permalink)
Default
yeah, 10 wrong answers for 20 bucks. :p
Id ask for your question to be moved to the engine section and youll get more help. You might want to find out what jets and cam you have because they will need to know that to help you.
04 450r
14.8 cp/rage piston
dasa head, intake and exhaust
web 208
43mm fcr
boosted3g is offline   Reply With Quote
Old 10-17-2009, 03:33 PM   #5 (permalink)
Default
I feel dumb telling you this since you have experience with high perf. car engines, but have you considered that since you have an aftermarket camshaft installed that your valves might need to be adjusted regularly, and it might run "lumpy" because of the camshaft installed? Depending on which stage/brand of cam you have it will run differently. Also with a bunch of different carb settings on a completely stock intake/exhaust system messes with the engineering behind the orignal setup. A camshaft doesn't require any fuel setting changes. I'm confused about why the original owner would change the needle unless the sea level was requiring these changes. I'm going to guess if u check your main/pilot jets they are going to be too big. The best thing to do would be take your carb out, clean it, and rejet. Once you do that you could buy a full exhaust and remove your airbox lid and buy a twin air air filter to fully utilize the aftermarket camshaft installed previous to your purchase. You should talk to the person you bought it from and check out which stage/brand of camshaft he installed. Then you can tune your bike and purchase future parts based around that cam.
Click here if you want to see my quad. Kick rocks if you don't!
<span style="font-family:Trebuchet MS">2004 450Riot
<span style="color:#000000">170 Keihin Main, 3rd Clip HRC Needle, 52 Pilot, A/F 1.5 Out, HRC Airbox Lid, Moose Racing Black Exhaust Wrap - Dasa Intake/Full Classic Pipe - Barnett Fibers/Steels/Springs - ITP Baja Rears - Kenda Klaw XCR&#39;s<span style="color:#FFFF00"> - Pro Taper Gold Pastrana FMX&#39;s - 3.5" Powermadd Riser - Motion Pro +6" Cables - Streamline +6 Brakeline - One Ind. Masacre Kit - Moose Nerfs:( - ODI Lockons - AC Rack - Pro Armor Bumper - DID Gold 520 Chain - Pro Taper 13/40 Gearing
derek_thompson24 is offline   Reply With Quote
Old 10-20-2009, 12:03 PM   #6 (permalink)
rallysoob's Avatar
Send a message via AIM to rallysoob
Default
... Now he has put on a standard exhaust and filter box....[/b]
I assume you are saying that before you bought it the bike had a aftermarket exhaust/filter and the bike was jetted for it. So, Either jet back down to accomodate your stock exhaust/filter or buy and exhaust and filter kit to accomodate your jetting/needle setting. Dont waste your money on a slip-on. just get the used full exhaust if your looking to save money. I picked up a nice looking yoshimua full alum race exhaust for 100bux on cl, i got lucky maybe but those deals are out there everyday, just gotta look.
rallysoob is offline   Reply With Quote
Old 11-27-2009, 01:29 PM   #7 (permalink)
Default
Your cam, jetting, carb, Exhaust, and values should all be checked and fixed at the same time. You will have to do some looking at exhaust if you do plan on keeping the noise down but get the biggest power gains. It dose sound like the bike just has to many mixed match parts and there not all work right at the same times. If you do have a cam and a stock exhaust this maybe your main problem. With the cam, exhaust and high comp piston the stock pipe will not hold up to the extra air flow that is needed for the engines needs.
Sponsors:
RAT-A-TAT ROOFING
JH RACING
HINSON RACING
SPARKS
HOTCAM
ASV
SPY
TAG METALS
TWIN AIR
PRO GRIP
PRO ARMOR
[/i][/b]
Rat-A-Tat Racing is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
