Old 02-04-2005, 06:23 PM   #1 (permalink)
Thumbs up
I just got my hauser stem and clamp what do you do with the ignition switch and red overheat light that comes on an 04 trx450r?????
thanks
Big John
hoverman is offline   Reply With Quote
Old 02-04-2005, 06:45 PM   #2 (permalink)
hook's Avatar
Default
Originally posted by hoverman@Feb 4 2005, 07:23 PM
I just got my hauser stem and clamp what do you do with the ignition switch and red overheat light* that comes on an 04 trx450r?????
thanks
Big John
<div align="right">
[/quote]
I just unplugged mine under the hood. I drilled a new hole for the light in the side panel.pop out the red lens poke rubber grommet through hole and replace lens.
2005 450R Black
AC Nerfs
AC bumper
TAG2
PRM Skids
Full HMF
Stage 2
JE 13:1
Razr 2&#39;s on Hi Pers
hook is offline   Reply With Quote
Old 03-04-2005, 10:40 AM   #3 (permalink)
borrasavagetrx450r's Avatar
Default
I have not taken any pictures of mine yet but what I did was I made a plate real neat and installed the ignition and coolent light. On my stering stem set up there is four threaded holes for a kill switch so I just used two of those and drilled holes in the plate I made and bolted it all up together. Looks good and neat.
2006 e-start
ported head with web cam
RPM dominator +2 +1 rear axel
Gibson steering stem +3
Gibson front A arms +2
Elka extra travel front and rear shock
Elka steering damper 5
pro taper handle bar
spider handle grips
general lee graphix kit
ASV clutch lever
green wire cut off
curtis sparks full exshaust
XFR nerf bars
twist grip
cut front fenders
37 tooth sear sprocket
2004 kick start
HRC cam kit
480 athena kit
ported head
elka shocks extra travel and extra length front and back
JD performance fron A arms extra length +2" +1"
JD performance rear swing arm extra length +2"
RPM rear axil +2" +1"
Braided hose&#39;s front and back
2 X Gibson steering dampers
Gibson steering stem +2"
Pro taper handle bars
twist grip with spider grips
elsenor grafix kit
XFR nerf bars
DG front bull bar
Full curtis sparks exhaust
cut front fender
borrasavagetrx450r is offline   Reply With Quote
Old 03-04-2005, 03:17 PM   #4 (permalink)
Default
I have a Houser also, I'm just going to drill holes in the plastic and mount them there. I really haven't figured out a spot yet though. Probably on the hood.
Smoker is offline   Reply With Quote
Old 03-04-2005, 03:19 PM   #5 (permalink)
Banned
Default
The Lone Star Racing stem comes with a nifty plate to remount the key switsh and light .
8
#8trx450r is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
