Installing Brake Pads - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 12 (permalink) Old 05-18-2011, 09:29 PM Thread Starter
Exclamation Installing Brake Pads
I am in the process of installing new pads and I have not gotten very far...
I started on the rear, i got the caliper off and the old pads out, now i am pressing the piston back in to make room for the pads, and it wont press back in flush with the caliper. This is making it impossible to install the new pads as there isnt enough clearance between the piston and the other side of the caliper.
I have tried to remove the emergency break from the caliper, and back the adjustment all the way out. I'm starting to think that the piston isn't going to go back in all the way.
Any thoughts, tips, tricks, or pictures to help me out would be great.
Thanks!
2006 TRX 450ER
steveo413 is offline
post #2 of 12 (permalink) Old 05-18-2011, 10:14 PM
joeylowthers450R's Avatar
if your sure the parking brake is not the issue, then remove cap on fluid and check to see there is enough air space for the fluid to be pushed back in
joeylowthers450R is offline
post #3 of 12 (permalink) Old 05-18-2011, 10:17 PM Thread Starter
yep, i did that also. I did get the piston to move a little bit but not enough to clear the new pads or go back flush with the caliper.
Any other ideas?
2006 TRX 450ER
post #4 of 12 (permalink) Old 05-18-2011, 10:25 PM
only other thought would be to pump the pedal lightly and work the piston out and in afew times, i always spray piston with brake cleaner then fluid film to lube the o-ring on the piston when installing new pads.
if that doesn't free it up to push in all the way, then loosen bleader screw and try to push in piston
post #5 of 12 (permalink) Old 05-18-2011, 10:28 PM Thread Starter
Thats a good idea. I will try to work the piston in and out a bit from where I have it now and see if i can get it to break free....I am trying to avoid opening the bleeder as i dont want to have to deal with bleeding the brakes if i dont have to.
2006 TRX 450ER
post #6 of 12 (permalink) Old 05-18-2011, 10:32 PM
Send a message via Yahoo to 1Badass07
If its possible try gettin a small C clamp on the piston and trying to push it back in that way.
2007 TRX 450er
-Moose front bumper
-Moose rear grab bar
-Moose Nerf bars
-Full skid plates
-Uni air filter
-Two Brothers exhaust
-front shock covers
1Badass07 is offline
post #7 of 12 (permalink) Old 05-18-2011, 10:34 PM Thread Starter
I am using an actual caliper tool...kinda looks like a caulk gun but has a wide plate to press the piston back in. If i can't do it with this tool, a c clamp isn't gonna have a chance.
2006 TRX 450ER
post #8 of 12 (permalink) Old 05-18-2011, 10:40 PM
i use c-clamp vise grips with the old pad on the piston
post #9 of 12 (permalink) Old 05-19-2011, 06:43 PM Thread Starter
Any other ideas? I haven't had a chance to go back out and work the piston in and out a few times to see if it will break free the rest of the way, but just thought i would try for a few more suggestions.
2006 TRX 450ER
post #10 of 12 (permalink) Old 05-19-2011, 11:15 PM Thread Starter
Good News. I got the piston pushed all the way in..I tried the advice from Joey. I pumped the piston in and out a few times, cleaned around the pistion, and then i opened the bleeder and it finally popped and gave way.
Thanks for all the help!
2006 TRX 450ER
post #11 of 12 (permalink) Old 03-10-2012, 08:52 PM
Send a message via AIM to adam2562
thanks for the tips guys, i'm having the same issue at the moment.. and even drove off with it tight thinking oh it'll loosen up down the road.. nope.. got home and the rotor was bright red hahaha.. so yea i'll lube it up n work it back n forth.
07 TRX450ER
-Lonestar carrier, Vesrah clutch, Wiseco Basket, MSR clutch lever, Renthal Chain, K&N filter, FMF slip-on, HID headlights.
adam2562 is offline
post #12 of 12 (permalink) Old 03-11-2012, 04:35 PM
mcoughlin's Avatar
Make sure your caliper bracket is free too and that it slides like it should
Black 05 R...........Red 05 R
SOLD..................Winter Build
Black & Blue.........Black & Yellow
mcoughlin is offline
