TRX450ER Pro Design Kill Switch Install? - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 10 (permalink) Old 02-17-2011, 11:00 AM Thread Starter
Send a message via AIM to Ride_Red626
I have searched and searched, it seems everyone has a different opinion or way to install this. Can someone explain exactly how this is supposed to be wired on an ER quad (a picture to the 2 mounting points would be awesome)? I have read stories about tapping into the wrong wire (it will kill the engine though), but will blow the main fuse everytime it closes the circuit (tether switch comes out...). I would like to keep my key, and I have read the sticky from Luke at the top of the page, but I dont think that is how it should be done on an ER?
I have never owned anything with an electric start, so all these wires/battery/switches is frusterating me to work on.
Thanks
Dave
Ride_Red626 is offline
post #2 of 10 (permalink) Old 02-17-2011, 11:27 AM
and watching this, since I'm getting ready to install mine on a ER
07 TRX450R hotcam, rossler exhaust, k & n filter, and a lot of other bolt ons.
moose is offline
post #3 of 10 (permalink) Old 02-17-2011, 02:32 PM
skipnation's Avatar
Thanks
Dave
What does the paperwork with that say? Is it the same as Pro Armor?
If it says " ..between stator and coil" it is the black wire with yellow stripe in the CDI cluster. I showed a picture in another post yesterday. The other is a ground to the frame.
Four wheeels are better than two
skipnation is offline
post #4 of 10 (permalink) Old 02-17-2011, 02:40 PM
skipnation's Avatar
tether kill switch
click here
post #5 of 10 (permalink) Old 02-17-2011, 02:56 PM
You take the ground wire and ground it on the frame. Take the other wire and wire it to the key switch or to the positive side of the coil. That should do it. OR buy a cheap test light and find out what wire kills the light when the key turns off but the wire you test has to be the one for the starting and killing of the motor
james500mag is offline
post #6 of 10 (permalink) Old 02-17-2011, 03:43 PM Thread Starter
Well... that is part of the problem. I bought it new, from a shop (it is a pro design, similiar to the Pro Armor I think), however there was no reference materials in the brand new sealed package. And Pro Design's web site is useless.
Dave
post #7 of 10 (permalink) Old 02-17-2011, 04:41 PM
skipnation's Avatar
Dave
click here
tether kill switch
If it is the two wire like Pro Armor which sends a ground , Wire it like my link shows you and you will be perfect. Doing it this way , will let you do what ever you want with the key or kill switch in the future and will not change your tether kill switch. I have relocated the key under the hood and removed the kill switch and light control from the handle bars while the tether is still the same. I used the manual to choose the right wire at the CDI which has no chance of being high voltage. Follow my instructions in that link ( with photo) and if you have any questions, PM me.
post #8 of 10 (permalink) Old 02-17-2011, 04:56 PM Thread Starter
Yep, got it! Black and yellow wire works great, and thanks for the help guys.
Dave
post #9 of 10 (permalink) Old 06-23-2014, 08:04 PM
Trask77's Avatar
does this also work on a kickstart model? i have an 05 kickstart and am installing a pro design. from the paper work it says that there is a difference between installing on a battery machine compared to a kickstart
05 kicker
full hmf pipe
stage 2 hotcam
port and polish
$1000 dollar machine
just needs some tlc
Trask77 is offline
post #10 of 10 (permalink) Old 06-23-2014, 08:29 PM
tylerb33's Avatar
I just wired mine to the black wire with the white stripe and the green wire going to the key on my 04. I have heard that if you hook them up to the coil that sometimes if you are really revving the engine sometimes they wont work for some reason.
04 MX -JB, PEP, JH, Rath, RPM, CP, Maxxis, DWT, Renthal, SSI, ASV
tylerb33 is offline
