Old 12-23-2009, 05:46 PM   #1 (permalink)
ralph brunt's Avatar
Default
so where do you guys put the ignition switch when you upgrade your bars?
ralph brunt is offline   Reply With Quote
Old 12-23-2009, 05:52 PM   #2 (permalink)
Default
so where do you guys put the ignition switch when you upgrade your bars?[/b]
do a search...there are bunch of suggestions on here
thehonda450r is offline   Reply With Quote
Old 12-23-2009, 05:53 PM   #3 (permalink)
hoser's Avatar
Default
Exactly.
This was just posted a couple days ago.
http://www.trx450r.org/forum/index.php?showtopic=83050
Look at post number 8 by Trixed450r. It looks pretty nice.
2005 450R
Black everything and lots of parts
2005 450R
Less black and less parts
hoser is offline   Reply With Quote
Old 12-23-2009, 05:55 PM   #4 (permalink)
mikeybez715's Avatar
Thumbs down
You can do a search for this- example- Warning light relocation, key relocation- or dash board removal. etc.
Here is what I did- Mounted them on my hood- Clean Look, out of the way- Still visible- Took about 20 mins- and the best part it was FREE!!
I used a 5/8 drill bit for the lights, and drilled another hole for the key and reamed it out to make the key fit-
-2007 Trx 450R- Herrmann Plus 2 A Arms- Driven plus 3" Rear Spacers- Itp Baja Polished All Around- Pro Taper Fat Bars- Dg Pipe-Head Pipe Wrapped- HRC Jetted- Paddles- Pro Armor Bull Bumper, Pro Armor Fat Peg Nerfs with Heel Guards- 8k Hid Upgrade- Ams Northstar Graphic Kit- Mier Carbon Fiber Look Hood-
mikeybez715 is offline   Reply With Quote
Old 12-23-2009, 06:00 PM   #5 (permalink)
Default
Exactly.
Thanks for the props Hoser-
Old 12-23-2009, 06:02 PM   #6 (permalink)
Default
thanks guys i will search it out
and yes it looks clean in the hood
Old 12-23-2009, 06:16 PM   #7 (permalink)
hoser's Avatar
Default
Thanks for the props Hoser-[/b]
No problem, it's a nice looking setup!
2005 450R
2005 450R
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
