#1 (permalink) |
how do i get oil to flow through these things? cant seem to get it through...is there a certain way to set these things up
![]() port and polish 13:1 CP piston +1 fierra valves all around Kibble White Springs DynaTek Programmable HC Stage 3 13t front 39t rear Fcr 42mm stock intake boot with dasa filter and sleeve Full Dasa exhaust system AC Black-line Front Bumper ASV Clutch Lever with Hot start Motowoz Triple Rate LT Comp/Rebound Adj(front) Motowoz Dual Rate LT Comp/Rebound Adj (rear) Elka Dual Link RPM Dom #2 JD Performance +2 LT Black 21x12x8 8 Paddle Haulers on black baja t-9 21x11x10 Front sand stars on black baja t-9 Special thanks to: Dave at JD performance, jim and suzi at motowoz, and Morgan and john at Racers Edge....... |
| Sponsored Links | |
Advertisement |
#2 (permalink) |
450R Racer
did you put the copper washers on the inside and outside of the banjo bolt? If so, keep the master cylinder fullopen up the bleeders and let gravity do the work. Watch it though, you dont want all the brake fluid to flow out or else you have to start all over again.
Do you know how to bleed your brakes?
If you're in Northern Arizona or Southern Nevada check out http://www.advantureshuttles.com/ for shuttles and tours. |
#4 (permalink) |
iv never had to bleed a brake....i tried pumping it then holding in lever and unscrew the bleeder then tighten it back up but it doesnt seem to be working
| Thread Tools | |
