450r,400ex sterring stem question - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 6 (permalink) Old 07-29-2007, 08:56 PM Thread Starter
kersey527's Avatar
i am wandering if a 400ex stem will fit a 450r? thanks for any info
2009 setup...06 Trx 450er
Engine:
Hot Rod HD crank
CP 13.5.1 piston
RC motorsports head
Kibblewhite valves
Hotcam stage II
Dasa pipe
Uni filter
Tusk hd clutchs
green wire mod
Suspension:
JHracing lt arms
Elka lt shocks done by JHracing
GT thunder rear w/ link
G force axle
Precision stabilizer
Body & controls:
Pro Taper bars
ASV levers
PD killswitch
Twist throttle
Gen X metallic blue hood
Gen X mastercylinder cover
Brm.numberplates
Team RC custom graphics made by BRM
ProArmour fat peg nerfs
AC Stadium bumper
Blingstar grabbar
Douglas beadlocks Mxr6 rears, Maxxis Razr front
2008 Haspin acres Open Quad Champion... 2009 Haspin acres 450 Quad champion
Thanks to..... RCmotorsports..... JH racing.....and the wife !! Looking for sponsers for the 2010 season!!
kersey527 is offline
post #2 of 6 (permalink) Old 07-29-2007, 10:18 PM
Vitamin R's Avatar
A 400ex stem will work. I have one on my 05 450R. All you need is the 400ex upper steering stem clamp and bushing. The bottoms are the same and I didn't even have to adjust my tie rods. Let me know if you want to see pics.
88 XC TRX250R in pieces.
Vitamin R is offline
post #3 of 6 (permalink) Old 07-31-2007, 09:27 PM
sandshots's Avatar
post a picture anyways, i'll check it out.
R.I.P TRX450r
sandshots is offline
post #4 of 6 (permalink) Old 07-31-2007, 10:16 PM
Jim
post a picture anyways, i'll check it out.[/b]
ya pics are always cool
"Integrity is like Virginity, once its Gone, its Gone!"
cleatus is offline
post #5 of 6 (permalink) Old 08-01-2007, 08:59 PM
sandshots's Avatar
A 400ex stem will work. I have one on my 05 450R. All you need is the 400ex upper steering stem clamp and bushing. The bottoms are the same and I didn't even have to adjust my tie rods. Let me know if you want to see pics.[/b]
are both of these stems the same lenght?
R.I.P TRX450r
post #6 of 6 (permalink) Old 08-05-2007, 12:01 PM
Vitamin R's Avatar
I'm using a Roll Design 400ex +1 stem and it's about 2" taller than my stock stem (measuring just the stem and not the clamps all the way down to where the fat part of the stem ends and the shaft for the bearings begins right below the tie rod tabs / steering stops). I believe the 450R stem is 1 1/8" and the 400ex is 1" diameter (the stem is chromoly so I could care less about the 1/8"). I talked to OMI and they said they can make me a greasable 450R upper clamp with the 400ex diameter next time they make a run of their clamps and will send me an email before they do. Anyways, here's a few pics of everything...
