Old 03-12-2007, 08:53 PM   #1 (permalink)
Default
Well, I have my new 07 white plastics installed on my 04. I have posted down lower about what kind of troubles I ran into while making these fit, but I just thought I would share the final results and post up some pics. Take a look!
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1505.jpg
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1507.jpg
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1504.jpg
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1503.jpg
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1506.jpg
http://i152.photobucket.com/albums/s181/gl...0r/DSCN1510.jpg
04 450R
It's a Venom/KBR built 480R now! (53HP,34TQ on Kam's "stingy" Dyno)
Venom 14:1 Piston/Venom Porting
Kibblewhite Valves and Springs
Dyna Non-Programable CDI
HRC Kit
DASA Pipe
Taperbored 42mm FCR w/Rat-Hotstart included
JD + 2 Arms/Klein Racing + 2 Swingarm
Dominator 2 Axle
Trail Tech Clamp(no-logo)/X-Bars/spider grips
TCS fronts/Derisi link rear
13 tooth front
KBR/ESR modified intake
20x10x10 Scat Haulers 7 Paddle
21x12x8 Scat Gliders 9 Paddle
STM Clear Clutch Cover
Pro Armor Bighorn Bumper
OEM White Plastics
IMS powdered black pegs
gloveman is offline   Reply With Quote
Old 03-13-2007, 12:39 AM   #2 (permalink)
Default
Looks great! Too bad it was such a pain in the a$$.
2007 TRX450ER
Motown450R is offline   Reply With Quote
Old 03-13-2007, 10:36 AM   #3 (permalink)
Super Moderator
gumby46's Avatar
Send a message via AIM to gumby46 Send a message via MSN to gumby46 Send a message via Yahoo to gumby46
Default
Thanks for the pictures, been thinking about doing it myself. Where did you post the problems you had with it?
<span style="font-family:Arial Black">k
2005 TRX450R - Red
HRC Kit (What is left)
12.25:1 Venom Piston
Venom Porting
HotCams Stage 2
DASA Exhaust System
ESR Intake (Ported by Bob McKray)
JD Performance +2 STD Travel Race Arms
2007 OEM Swingarm w/ GT Thunder Rear Re-Valve and MX Link
RPM Dominator II & Anti-Fade
...More pics and specs...
Online Reference Material for the TRX450R
gumby46 is offline   Reply With Quote
Old 03-13-2007, 05:16 PM   #4 (permalink)
Default
Thanks for the pictures, been thinking about doing it myself. Where did you post the problems you had with it?[/b]
Thanks for the comments. The white just makes it look so much cleaner, IMHO. I posted some of the installation info in a thread a bit farther down. I was under the assumption that this was going to be a direct bolt up process, but it is not a perfect match. Modifications were minor, but necessary.
04 450R
It&#39;s a Venom/KBR built 480R now! (53HP,34TQ on Kam&#39;s "stingy" Dyno)
HRC Kit
DASA Pipe
Dominator 2 Axle
13 tooth front
OEM White Plastics
Old 03-13-2007, 05:35 PM   #5 (permalink)
Super Moderator
gumby46's Avatar
Default
<div class='quotemain'>Thanks for the pictures, been thinking about doing it myself. Where did you post the problems you had with it?[/b]
[/b][/quote]
Any idea which thread?
Just trying to get an idea of what to expect.
2005 TRX450R - Red
Venom Porting
HotCams Stage 2
DASA Exhaust System
Old 03-13-2007, 07:56 PM   #6 (permalink)
Default
<div class='quotemain'><div class='quotemain'>Thanks for the pictures, been thinking about doing it myself. Where did you post the problems you had with it?[/b]
[/b][/quote]
[/b][/quote]
In this same section of forum topics, about 6 topics down from this one. I posted a couple times in reference to what I had to do to make these OEM plastics bolt up. It's under "07 white plastics on an 04".... Hope this helps.
04 450R
HRC Kit
DASA Pipe
Dominator 2 Axle
13 tooth front
OEM White Plastics
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
