Old 08-22-2006, 02:43 PM   #1 (permalink)
PITTMANSPOWERSPORTS's Avatar
Send a message via AIM to PITTMANSPOWERSPORTS
Default
on the 450r, the nuts are glued or pressed or something into the gas tank and some moisture got in there and stripped them out so they were just spinning and i couldnt tighten the fenders back down, luckily thanks to my extended warranty, i got a new tank and bolts for free and thats the second case of that happening and the dealership i work at anyway, anyone else run into this problem or know of any possible solutions to prevent it?
2005 TRX450R
FMF FACTORY 4 COMPLETE EXHAUST, FMF JET KIT, NOS MACHINE CARB ADAPTER, FCR CARB, BOYESEN QUICK SHOT, MSR FUEL MIXTURE SCREW, LONESTAR RACING BLOCK OFF PLATE, TWIN AIR FILTER POWER FLOW KIT, REV MAX +1750 C.D.I., HONDA HRC KIT, WORKS PERFORMANCE FRONT AND REAR SHOCK KITS, MOOSE RACING NERF BARS, MOOSE RACING FRONT BUMPER, AC RACING REAR GRAB BAR, ITP GNCC TIRES, DENTON STEERING STABILIZER, 2007 GRAPHICS, ASR STAINLESS BRAKE LINES, DG LASERPLATE SKID PLATES, FLEXX HANDLEBARS, BOYESEN SHOCKOUT GRIP SYSTEM, REKLUSE CLUTCH
PITTMANSPOWERSPORTS is offline   Reply With Quote
Old 08-22-2006, 03:23 PM   #2 (permalink)
TRX450R_Racer's Avatar
Default
Use anti-seize on the bolts and don't over tighten them.
***Frank***
Click here to see my 450R
Life's too short, wear a helmet
Dress for the crash, not for the ride
TRX450R_Racer is offline   Reply With Quote
Old 08-22-2006, 10:45 PM   #3 (permalink)
HRE
HRE's Avatar
Default
[snapback]273134[/snapback]
Yeah, I just bought my 06 used from someone and I was going to take the tank off and the **** left side tank bolt will not come off. I had to take the tank and front fender off in one piece! WTF!
HRE is offline   Reply With Quote
Old 08-23-2006, 01:01 AM   #4 (permalink)
neptali's Avatar
Default
Notorious problem for 450r's!!!! Same thing happened to me not too long ago I bought a "spare" tank off a member but decided to go with the IMS oversized tank anyway.I feel your pain brotha!!!! IMS all the way
karma is alive and well.......
neptali is offline   Reply With Quote
Old 08-23-2006, 01:34 AM   #5 (permalink)
BackSpace's Avatar
Default
they are molded around the brass inserts just drill of the head and use anti seize and do not over tighten
BackSpace is offline   Reply With Quote
Old 08-23-2006, 08:32 AM   #6 (permalink)
Default
Originally posted by chino886+Aug 22 2006, 10:45 PM-->
<!--QuoteBegin-PITTMANSPOWERSPORTS
[snapback]273368[/snapback]
Chino I would try to get it warrantied. It is a well know problem from day one.
***Frank***
Life&#39;s too short, wear a helmet
Old 08-23-2006, 11:14 AM   #7 (permalink)
Default
I just had the same thing happen to me.
Anybody got another gas tank?
06 450ER - PAID FOR!!!
DG Front Bumper
DG Nerf Bars w/Heel Guards
Hotcams Stage II
Pro Design K&N w/Outerwears
Open air box w/Outerwears cover
HMF Adjustable Needle - 3rd Clip
Aftermarket endcap
165MJ - A/F - 2 turns out
Truthiness - the quality of stating concepts or facts one wishes or believes to be true, rather than concepts or facts known to be true.
remmy is offline   Reply With Quote
Old 08-23-2006, 11:36 AM   #8 (permalink)
Bako450R's Avatar
Default
well guy i feel your pain. this happened to me a long time ago. i have a fix that has worked for me.
so this is what i did. i managed to take the plastics off the tanks carefully by prying. then i grabbed a set of needle nose pliers and a 8mm socket and install the socket on my impact gun. i spun the brass insert nut with the 8mm bolt until it heated up the plastic while prying the bolt out with the needle nose pliers. so i finally took it out. i took a exacto knife to clean the hole where the insert just came out of. i cleaned the brass insert from melted plastic. i then made sure the insert would go back in the hole without much pressure. once i accomplished this i mixed a small batch of quick jbweld. i filled the hole about half way. then inserted the brass nut back in. wipe excess jb weld that comes out of hole. and just wait for it to dry and this works just good as new or better.
if anyone has questions just ask me. i'll help you.
Bako450R is offline   Reply With Quote
Old 08-24-2006, 12:49 AM   #9 (permalink)
smprider112's Avatar
Default
[snapback]273545[/snapback]
Just wanted to let ya know...you saved my @$$!! I just happened to come across this thread....I stripped mine out last week, and just repaired it tonight after reading this post...so far so good, the J-B is almost dried and it seems to be holding well. If not for this thread I would have just left it like that and taken the whole front plastics off if I needed the tank off.
Im just glad this is a common problem, I was pissed at first when Mine did this to me, and my bike is less then a year old with not many rides on it.
05 TRX450R- Houser +2 std travel, GT Thunder suspension, DR.D exhaust, IMS bumper, DG nerfs, G-force adj. axle, Tag X5 bars, Quadtech Carbon fiber hood, Hiper 8x8&#39;s and Maxxis Razr&#39;s Hiper 10x5&#39;s 4+1 offset stock tires, Hiper 10x10&#39;s with ITP Sandstars, Keihin 40mm FCR, NOSS adapter, Boyeson quickshot, HRC needle 3rd clip up, 162 main, 45 pilot, 55 leak jet A/F screw 1 7/8 out, Hot Cams Stage II, Vortex X10 CDI.
There are 2 types of quad riders...those that ride Banshees.....and those that ACTUALLY ride!!!
smprider112 is offline   Reply With Quote
Old 08-24-2006, 11:18 AM   #10 (permalink)
HRE
HRE's Avatar
Default
Originally posted by smprider112+Aug 23 2006, 11:49 PM-->
<!--QuoteBegin-Bako450R
[snapback]273812[/snapback]
I am going to jack with mine tonight! You think gorilla glue will hold it?
Old 08-24-2006, 12:07 PM   #11 (permalink)
Bako450R's Avatar
Default
[snapback]273923[/snapback]
gorilla glue may work but i'm not sure it will fill the hole in tightly like jb weld will.
Old 08-24-2006, 12:10 PM   #12 (permalink)
Bako450R's Avatar
Default
glad someone took advantage of my fix. hope it works as good for you as it did for me.
Old 08-27-2006, 09:49 PM   #13 (permalink)
Default
gotta love jb weld i actually got my tank warranteed and got to keep my old tank and ended up fixing it with jb weld anyway, so now i have a spare tank!
2005 TRX450R
Old 09-07-2006, 07:22 PM   #14 (permalink)
Default
I had the same problem on my TRX450 05 ,i went with a IMS oversized tank :)
Porta is offline   Reply With Quote
Old 09-07-2006, 10:08 PM   #15 (permalink)
Chuck's 06 450's Avatar
Default
These might be great fixes, but it's not the cure. I think the bolts threading into the brass and getting a piece of the brass threads "welded" to the steel threads of the bolt and then screwing up the brass threads of the insert on the way back in is the real culprit.
I've had both sides do this and I took my dremel out and removed the brass that was stuck to the bolts threads and voila - no more tight threads and it screws in with no problem.
I don't know a better cure than to be REALLY careful when screwing these bolts in. If it feels tight, there's probably a fubar'd thread - just clean it before you screw it back in. I fine wire brush on the bolt might work well too...
07 HD FLHT - sorry, but let&#39;s face it, riding a hog gets you laid more than riding a trx ;-)
06 TRX511ER - SOLD
Venom Porting and Head Mods with +1 KW Valves all around
Venom 100mm 14.25:1 Piston
Venom Modded ESR Intake
Venom Modded 43mm FCR with Rat Stack
Venom Exhaust
Hot Rods +3 Stroker
MaxPower Ice Cube Cylinder
Early HRC Cam
Chuck's 06 450 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
