#1 (permalink) |
Well, i took the cheap road to widen my front end by buying billet wheel spacers. they seem solid, however, after the install, i noticed that the offset of the stock rims would even make the front WIDER if i flipped them around. all in all, i got 7 and a half inches total by setting it up like this.. has anyone ever ran their wheels like this? if so, is there any steering problems i might run into? thanks.
05 TRX450R Sparks Jetting Sparks Air Filter w/o Lid Fully gutted stock pipe Pro Taper SE bars ITP Holeshot XCR 03 Shoes Durablue billet spacers front and rear Pro Armor Front Bumper Pro Armor Fat Pegs w/ Heel Guards Pro Armor Graphics Kit Renthal 13T Front Sprocket Maier Carbon Fiber hood *All mods in "Uncorking Your 'R' on budget" complete* |
| Sponsored Links | |
Advertisement |
#2 (permalink) |
I bet your bumpsteer will be magnified by 20 times.....also it is hard on ball joints ......
Make sure the valve stem clears the brake caliper on the inside of the wheel or you will end up with a couple flat tires.
= Kansas City Missouri = 04 TRX450r 86 310R (250r) 03 Suzuki Z400 (my sons) 06 Yamoto 150 (my sons) 02 KX65 ( my sons) 03 CRF450r 05 Nissan Titan 91 Yamaha FZR600 |
#3 (permalink) | |
Why is it that slim and fat chance mean the same thing? ----------------- 07 CRF250R 05 450r- Venom Piston- Mixxer Magic- Kibble White- Dynatek- HC2- Pulse Charger- GT Thunder
#4 (permalink) |
I have +2 arms and flipped my wheels also. I only ride sand and don't notice any "bumpsteer" or feedback. I drilled another hole on the inside of the wheel and put a stem in backwards in the original hole so it would not hit the calipers.
I also run '86 TRX250R arms on the front of my golf cart with the wheels flipped and we beat the crap outta the cart and I have had no problems with the ball joints yet. The cart gets more ride time than the bikes because everybody in camp rides it. here is a pic of my cart. [attachmentid=15053] |
#6 (permalink) |
what kind of motor in that cart? i have a 250r motor that would be sick in it but a 500r motor would be better suited.
........................................... <span style="color:#FF0000">450R Valve Shim Calculator. Thanks to CRFs Only. RedishConstruction.com |
#7 (permalink) |
Banned
if you do a SEARCH.. like some people forget to do... *angel* you will find a thread on this, its ok to do this, but it exposes your brakes and brake callipers to the sand... and all the other junk you do not want hitting those brakes... the offset of the wheel on the stock offset is so the brakes stay hidden from rocks and trees and sand and such... but if you dont care about your front brakes then go for it
#8 (permalink) | |
| Thread Tools | |
