Old 08-11-2005, 03:08 AM   #1 (permalink)
Send a message via MSN to 450steeler
Default
Can someone explain to a beginner what different tire sizes do to a quad's performance. I still can't decide what size rear paddle to get for a little drag racing and messing around. Also, a tire size for trails. I am getting holeshots and haulers.
[FONT=Optima][ac racing pro nerfs, power madd hand guards, HRC power kit, Yoshimura trs carbon fiber exhaust, fasst flexx bars[SIZE=1][COLOR=red]
450steeler is offline   Reply With Quote
Old 08-11-2005, 02:23 PM   #2 (permalink)
kilabanshee's Avatar
Send a message via AIM to kilabanshee Send a message via MSN to kilabanshee Send a message via Yahoo to kilabanshee
Default
A good sized tire for is 20". For every 2" you go up or down in tire size thats like droping or adding one tooth in the front spocket. For example, The stock tires on a 450r are 20" if I droped the rear tires down to 18" for mx thats equall to dropping on tooth in the front spocket.
D-5 and D-6 MX Pro-B
#151 Red MX 450R
2008 MX motor
DRG 15.1 piston, web 493, DRG SSAR porting, Ferrea valves, Dynatek ignition, 43mm taper bored fcr, UM airbox with 250r filter
kilabanshee is offline   Reply With Quote
Old 08-11-2005, 02:26 PM   #3 (permalink)
Default
Good info. Thanks Kila.
06 450ER - PAID FOR!!!
DG Front Bumper
DG Nerf Bars w/Heel Guards
Hotcams Stage II
Pro Design K&N w/Outerwears
Open air box w/Outerwears cover
HMF Adjustable Needle - 3rd Clip
Aftermarket endcap
165MJ - A/F - 2 turns out
Truthiness - the quality of stating concepts or facts one wishes or believes to be true, rather than concepts or facts known to be true.
remmy is offline   Reply With Quote
Old 08-12-2005, 01:25 PM   #4 (permalink)
Default
The size of tire will tell you the roll out, its better to have more roll out. Depending on where you ride and if you hillshoot or flat drag, you want less paddles going up the hill and more flat dragging. I would 8 paddle if you hillshoot, flat drag and play around, will be a all around tire.
mtxracer36 is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
