Old 03-16-2005, 10:47 AM   #1 (permalink)
Hondo450R's Avatar
Default
I have 20x10x10 haulers and was wondering what everyone is running for tire pressure and how big of a difference it makes?
'05 TRX 450R
HRC kit,,IMS front bumper,Pro Armor race peg nerfs,,GT Thunder mx link and rear revalve,Fasst Flexx atv bend bars w/ Oury grips,Pro Design kill switch,HMF sport full system,UNI air filter w/outerwears airbox cover,Moose parking brake block off plate,Kenda klaw mx tires on beadlocks,Holeshot mxr6's up front,Houser +1 stem,extreme haulers and mohawks,T.M. Designworks case saver,ASV c/5 clutch lever,Woodward Specialties stainless swingarm pivot bolt,Maier scooped hood,JD Performance longtravel arms,Motowoz long travel shocks,Woodward bearing carrier,Precision steering stabilizer,RPM anti fade lock nut,Streamline braided front brake lines,Dominator II axle
Hondo450R is offline   Reply With Quote
Old 03-17-2005, 11:09 AM   #2 (permalink)
Default
Usually between 3-4 pounds MAX. !!! It makes alot of difference because too much air will not allow your tires to gain the traction you need. I'm speaking typically for racing, just riding in general it wont matter as much.
SCOTTS450R is offline   Reply With Quote
Old 03-17-2005, 07:08 PM   #3 (permalink)
Hondo450R's Avatar
Default
I don't race or anything in the sand just recreational with the occasional drag race with buddies.
'05 TRX 450R
Old 03-22-2005, 11:07 AM   #4 (permalink)
hawk-trx's Avatar
Default
it depends on the sand. i usally start with 4 all the way around. if the sand is wet i mad need to run 5-6 in order to get enough wheel spin this will also make your tire slightly taller therefor slightly faster on top end. in really dry or loose sand 3lbs to get more traction.
hawk-trx is offline   Reply With Quote
Old 03-22-2005, 10:12 PM   #5 (permalink)
redrocket08's Avatar
Send a message via AIM to redrocket08
Default
I run three pounds in the rear and 2.5 pounds in the front. I find this setup to work really good at Glamis.
redrocket08 is offline   Reply With Quote
Old 03-23-2005, 09:40 AM   #6 (permalink)
Hondo450R's Avatar
Default
Thanks for the replies
'05 TRX 450R
Old 03-23-2005, 09:57 AM   #7 (permalink)
KBR
KBR's Avatar
Default
I agree with all the above.
Mess with the pressure a bit, depending on if the sand is wet, or not.
Also if you like it to slide a little better, around the corners, add a bit more air (less traction=more slide).
KBR is offline   Reply With Quote
Old 03-30-2005, 01:38 AM   #8 (permalink)
Send a message via AIM to dysfunktinal Send a message via Yahoo to dysfunktinal
Default
3 pounds all around for me :)
04 TRX450R
Hot Cams Stage 2
Full Yosi TRS Tri Oval System
DynoJet Jetkit
Custom K&N Fillter/Outter Wear
Pro Design Pro Flow
Wasatch Manufacturing Air Box
JD Performance +2 Arms. Trans Red
Elka Triple Rate Piggy Backs
Revalved Rear By DAB Racing
KS Racing Rear Link
G Force Axle
Tusk Nerfs
AC Statium Front Bumper
Cascade E Brake Block Off
Maier Vented Racing Hood
UNIVERSAL ENGINEERING Bars
GenX ATV Clutch lever w/hotstart
Pro Design Kill Switch
Xtreme Quad Covers Seat Cover
ASV Brake Lever
Maxxis Pro In Front
Maxxis Razr 2 Out Back
Big thanks to my sponsors: AMSOIL, Universal Engineering, DAB Racing, Wasatch Manufacture and Machine, Utopia Optics, Vortex, ASV, MotoXsupport.com
dysfunktinal is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
