Best Paddle Tire - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 13 (permalink) Old 04-03-2017, 09:35 PM Thread Starter
Best Paddle Tire
I currently have worn out GBC sand sharks (20 X 11.00 X 8) and they worked pretty good. Im thinking of haulers or sand stars next, what would be the pros and cons of both? And what size would be best for my bike? I ran 14/38 gearing last time i went and that was too tall im thinking of going to a 13 or 12, suggestions on that? Do a little bit of dragging but the strip isnt that long where i ride (Little Sahara, OK) with the current setup i dont go into fifth, when i did it just bogged down bad. Typically run a 50/50 60/40 mix of av gas and 91 octane. Full list of mods is
Wiseco 12 to 1, stock bore
HRC Cam
Full Curtis Sparks Exhaust
K&N Without Lid
Jetting:
Pilot 55
Main 175
Mid 75
Peter450er is offline
post #2 of 13 (permalink) Old 04-03-2017, 11:38 PM
Sheerider11's Avatar
Padla brats. You'll thank me
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sheerider11 is offline
post #3 of 13 (permalink) Old 04-04-2017, 02:14 PM
socksandammo's Avatar
Imo you will benefit a lot from a 13t. Some people say run a 12t but it will eat up your chain slider faster. May I ask why you are mixing your fuel with a 12:1?
04' Black/Red
HRC Kit
12.5:1 JE Piston
Rossier Full System
K&N w/Outerwears
BARE Gusseted Frame
+2.25 Houser Slicast Arms
Tusk Adjustable Width Axle
socksandammo is offline
post #4 of 13 (permalink) Old 04-12-2017, 06:53 PM
22x12x8 triple buffed extremes W/ 7 paddles.
White 08
+2Alba/Elka Stage 4
Dasa
K&N moded Air Box
HRC Cam
Green Wire Mod
168 main
Black fiber 06
+2 Hydro Dynamics
Yoshi RS7 system
Esr intake
Hotcam stage 2
Rocket Factory port and polish
Green Wire Mod
175 main
stupidhurts450 is offline
post #5 of 13 (permalink) Old 04-28-2017, 03:05 PM Thread Starter
Just as a little boost i guess, i dont even know if it does anything though. When im just driving around i just use 91, the last dune trip i mixed av into it, the next time i think im just going to run race gas since its out of the pump at waynoka. My chain slider is basically non existent anyway lol ill just go with 13t.
post #6 of 13 (permalink) Old 04-28-2017, 03:10 PM Thread Starter
Also how are the brats and triple buffed on durability? i wont be strictly riding on soft sand, asphalt to the entrance and if i need gas asphalt to there too. i dont want something fragile
post #7 of 13 (permalink) Old 04-29-2017, 01:08 PM
D-Rock's Avatar
I was worried about durability of triple buff too because I ride in areas with some sticks and rocks on the trails once in a while so I decided to go with a bead to bead buff instead, not quite as light but I have better peace of mind.
06 OCP TRX500ER
06 Z400
06 YFZ450
D-Rock is offline
post #8 of 13 (permalink) Old 05-05-2017, 09:47 AM Thread Starter
Ok im just gonna go with haulers from rockymountain, what size and paddle count should i go with? im thinking 21x12x8 8 paddle
post #9 of 13 (permalink) Old 05-09-2017, 09:44 PM Thread Starter
post #10 of 13 (permalink) Old 05-09-2017, 10:12 PM Thread Starter
21x12x8 or 20x10x8 haulers??? going to do a little bit of everything
post #11 of 13 (permalink) Old 05-10-2017, 12:18 PM
I've had my paddles for about 5 years and they have held up good. I've driven them on the asphalt coming in and out of camp at Coos Bay, Or. and have had to drive through some rocky areas at Sand Mountain,NV. The 21x12x8 will be better for climbing hills, but can be a little more challenging side hilling. I have always been a fan of the 7 paddles whether you go with the 21x12x8 or 20x10x8 haulers.
White 08
+2Alba/Elka Stage 4
Dasa
K&N moded Air Box
HRC Cam
Green Wire Mod
168 main
Black fiber 06
+2 Hydro Dynamics
Yoshi RS7 system
Esr intake
Hotcam stage 2
Green Wire Mod
175 main
post #12 of 13 (permalink) Old 05-10-2017, 12:52 PM Thread Starter
im ordering from rockymountain so 7 paddle isnt an option in those sizes, only 8 paddle. im just afraid that the 21s will be too much tire for my power
2006 TRX450ER
HRC Cam
K&N Without Lid
Jetting:
Pilot 55
Main 175
Mid 75
post #13 of 13 (permalink) Old 05-10-2017, 01:07 PM
i know 7 paddle isn't an option online but you may have to call in and order. I personally think the 8 paddle are too much tire for a lightly moded 450 (Haulers, sand stars, etc).
White 08
+2Alba/Elka Stage 4
Dasa
K&N moded Air Box
HRC Cam
Green Wire Mod
168 main
Black fiber 06
+2 Hydro Dynamics
Yoshi RS7 system
Esr intake
Hotcam stage 2
Green Wire Mod
175 main
