#1 (permalink) |
What harm do dune tires to do a bike.. i heard something bad about them but its very vague in my memory. I was actually looking at gettin duners for my quad and was planning to ride on looser dirt with them. Anyone with dune tires suggest NOT riding like that? I know SAND DUNE tires means for SAND DUNES.. but i was thinkin they would either gimme some kickin traction or none at all. I might use them on grass too.. Any help? I also heard that Turf Tamers and Holeshot tires wear really fast.. is that true?
Click here if you want to see my quad. Kick rocks if you don't! ![]() <span style="font-family:Trebuchet MS">2004 450Riot <span style="color:#000000">170 Keihin Main, 3rd Clip HRC Needle, 52 Pilot, A/F 1.5 Out, HRC Airbox Lid, Moose Racing Black Exhaust Wrap - Dasa Intake/Full Classic Pipe - Barnett Fibers/Steels/Springs - ITP Baja Rears - Kenda Klaw XCR's<span style="color:#FFFF00"> - Pro Taper Gold Pastrana FMX's - 3.5" Powermadd Riser - Motion Pro +6" Cables - Streamline +6 Brakeline - One Ind. Masacre Kit - Moose Nerfs:( - ODI Lockons - AC Rack - Pro Armor Bumper - DID Gold 520 Chain - Pro Taper 13/40 Gearing |
| Sponsored Links | |
Advertisement |
#2 (permalink) |
man your rear end bearings wonèt last a minute riding on dirt and grass, get a set of irazrs or holeshot gncc tires if you want awesome traction and long wear time. i have used both on my 450Rs and if you want great traction in all conditions you canèt go wrong
2007 TRX 450ER HRC kit White Bros carbon pro exhaust K and N air filter/ with mod lid Tag T2 handlebars Polisport race hood Jannsen + 2.5 LT a arms Fox evol x floats dsc shocks Streamline steelbraided brake lines Powermadd hand guards Maxxis i razrs up front razr 2s out back |
#3 (permalink) | |
ya i ran my paddles for too long on hard pack because i didnt have the cash on hand at the time for new knobbies and i ended up putting a new bearing carrier in it. I wont ever ride paddles unless im in sand again.
06 VENOM trx470er Venom 14:1 98 mm piston Venom Port and polish Yoshimura RS-7 Titanium full exhaust Airbox lid cut in half Green Wire mod Hot Cams Stage II 170 main jet 55 leak jet sunline fuel screw woodward specialties twinrow bearing carrier Pro taper bars ITP holeshot HD's on ITP pro9 rims on back |
#4 (permalink) |
what jebus said^^^^^^ i have maxxis razr 2's and luv em but i wish i would of bought itp gncc's because they are more my style.
i ride on hard pack and sometimes cement and my razrs have hardl any wear.
-----Chad----- 2004 drag quad TBD 2005 play quad 50/33 My noodle is cockadoodle, my clocks cookoo, i got screws loose, yeah the whole kit n' kaboodle....
#5 (permalink) |
Super Moderator
moved to the TIRE section......lol
**06 450ER**... #3 (Dale lives on) 86TRX250R (mostly stock 66mm bore x 72mm stroke) 86TRX250R (ESR310 72.5mm bore x 72mm stroke '298cc' fully modded) **for sale** 88TRX250R (ESR330 77mm bore x 74mm stroker '345cc' fully modded) HRC kit (all but gone) Hot Cams stage III Okie porting w/ATP CV4 springs (36mm Ti/31mm) Venom/KBR N2O Porting w/KW springs (37mm/31mm) Venom/KBR 487 100mm 14.25:1 piston Cold Fusion Nitrous** Venom 'QP' pipe ESR Pro Series pipe ESR modded intake w/RAT stack 42mm Taper-Bored FCR Direct Drive clutch lockout, CR500 springs GT Thunder-Link w/Durablue Lowering Link Durablue Anti-Sway Bar Modded shock mounts Rage Modded Tranny Jetting/Carb: #168, #45slow, NGPR needle 3rd clip, #55 Leakjet, Pilot 2 turns out. Jetting/N2O: 22N/21F (22hp) *STU Comp Cut 21x12x8 (6) paddle 'Padla Brats' on Douglas Blue label 8x8..... Thanx to: Venom/KBR (Mixxer/Kam), Rage ATV (Dee), Sredum (Chris), and many ORG members |
#6 (permalink) |
If you want some awesome traction on dirt and want to use some tires that get traction up to the standards of sand get some Pro Wedges.....AMS Zippers....or Maxxis 4-snows. Pretty much all the same tire. Awesome traction on dirt and good traction on sand. They dont wear fast either cause the paddle is small.
05 Drag Bike
#7 (permalink) |
450R Racer
Cant go wrong with Kenda, great company and even better coustomer service.
If you're in Northern Arizona or Southern Nevada check out http://www.advantureshuttles.com/ for shuttles and tours. |
#8 (permalink) | |
| Thread Tools | |
