Old 02-11-2007, 06:57 PM   #1 (permalink)
Chuck's 06 450's Avatar
Default
Well, since I had a hard time getting all the info I was looking for in one place, I want to put together a paddle tire weight list. This is what I have so far from other members posts - as well as my own measurements.
21x12x8 Padla Brats Comp cut on 8x8 .125 rims = 9.5 lbs
20X10X8 6 paddle std buff Haulers on 8X7 .125 rims = 10.25 lbs - Old style Haulers
21X12X8 6 paddle std buff Haulers on 8X8 .125 = 11.5 lbs - Old Style Haulers
20x10x8 btb 8 paddle Gliders on .125's = 12 lbs
21x12x8 btb 8 paddle Gliders on .125's = 12 lbs
21x12x8 8 Pad Gliders std. buff (significant wear), 8x8 .125 = 12 lbs 2 oz
22x11x8 7 paddle glider standard buff on douglas 8x8 .160 wheels = 12 lbs 3 oz
21x8x10 Dune Tracker front, 10x6 2+4 DWT Black .160 = 12 lbs 12 oz
21x12x8 7 paddle std buff Extremes on 8x9 .125 rims = 13.0 lbs
20x10x8 6 paddle std buff Extremes on 8x8 .125 rims = 13.0 lbs
21x12x8 8 paddle Gliders on .160's = 13.50 lbs
21x12x8 8 paddle Hauler/Glider mix on .160's = 13.50 lbs
20x11x8 8 paddle Sand Devils on .160's = 13.75 lbs
22x11x8 8 paddle Haulers std buff on 8x8 Douglas .125's = 14 lbs
20x10x8 6 Pad Haulers std buff , 8x8 DWT Red .190 = 14 lbs 13 oz
20x11x10 Sand Skate II's on 10x8 .125 rims = 14.5 lbs
20-11-8 Sand Sharks on .160 rims = 14.75 lbs
20x11x10 8 Pad STU Sand Skate II, , 10x9 3+6 .125 = 15 lbs 7 oz
21x12x8 8 paddle Desert Storms on .190's = 16 lbs
20x11x10 Sand Sharks on 10x9 .125 rims = 16.75 lbs
20x10x10 8 Pad Hauler Extreme std. buff , 10x9 3+6 DWT Red .190 = 16 lbs 14 oz
21x12x8 Cheng Shin Dune Slider, 8x8 .125 = 17 lbs 10 oz
20x11x10 8 Pad Sand Sharks , 10x9 3+6 DWT Black .160 = 17 lbs 11 oz
20x11x8 GBC Sand Devils on .160 = 18 lbs
20x10x10 Geckos on .125 rims = 19.25 lbs
20/11/10 7 paddle Extremes on Douglas RED label with OMF beadlocks = 19.50 lbs
If you can add more to this list, please do. I will add it to the top as info is added...
For all the std buff entries, it seems that an Ultra-light buff will drop the weight by 2 - 3 lbs...
07 HD FLHT - sorry, but let's face it, riding a hog gets you laid more than riding a trx ;-)
06 TRX511ER - SOLD
Venom Porting and Head Mods with +1 KW Valves all around
Venom 100mm 14.25:1 Piston
Venom Modded ESR Intake
Venom Modded 43mm FCR with Rat Stack
Venom Exhaust
Hot Rods +3 Stroker
MaxPower Ice Cube Cylinder
Early HRC Cam
Chuck's 06 450 is offline   Reply With Quote
Old 02-11-2007, 08:43 PM   #2 (permalink)
Raistlin 12's Avatar
Default
20x10x10 geckos on douglas .125 rims are 19.25 lbs each. Just sold mine, so i know.
My new 20x10x8 standard buff 6 paddle extremes are 13 lbs each, on douglas .125 8x8 rims.
ESR intake w/ outerwears
DASA exhaust
Racers Edge Headwork +1 Valves
533 KBR
Web 208/921
43.5 Taperbore FCR carb
KW Dual rate Valve Spring Kit
Custom Ferrea Valves
Clutch Mod
JJ&A Drag axle
Dynatek Non-Programmable Ignition
Raistlin 12 is offline   Reply With Quote
Old 02-11-2007, 10:06 PM   #3 (permalink)
Super Moderator
450RRR's Avatar
Default
all I could add is that my 20/11/10 7 paddle Extremes on Douglas RED label with OMF beadlocks were 19.50 #'s.... EACH...
and my comp cut Brats...21/12/8 on 8x8 Douglas .125 were only 9.5#......you mentioned 10.5#... what wheels were you using? just curious....
Greg
86TRX250R (mostly stock 66mm bore x 72mm stroke)
86TRX250R (ESR310 72.5mm bore x 72mm stroke '298cc' fully modded) **for sale**
88TRX250R (ESR330 77mm bore x 74mm stroker '345cc' fully modded)
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline   Reply With Quote
Old 02-11-2007, 11:17 PM   #4 (permalink)
Default
I am correcting my numbers to reflect the above posts. Greg, I thought yours were 10.5? That's what Sand Tires Unltd says the weight is.... comp cut on 8x8x .125's.... are you sure?
06 TRX511ER - SOLD
Venom Exhaust
Hot Rods +3 Stroker
Early HRC Cam
Old 02-13-2007, 01:42 PM   #5 (permalink)
jasmoore3's Avatar
Default
sand sharks: 20-11-8 on .160 rims = 14.75lbs
'05 trx 450r (batteries are for old ladies)
the usual mods
banged up knuckles along with a few choice words
too much ca$h
Polaris RZR
N2O
Web cam
H/C pistons
bored t.b. and intake
clutch work
ported
jasmoore3 is offline   Reply With Quote
Old 02-13-2007, 02:42 PM   #6 (permalink)
badinblack's Avatar
Default
info is gladly appriciated here.
Ordinary people, simply doing their jobs, and without any particular hostility on their part, can become agents in a terribly destructive process. Moreover, even when the destructive effects of their work become patently clear, and they are asked to carry out actions incompatible with fundamental standards of morality, relatively few people have the resources needed to resists. -Milgram
R.I.P. Jesse aka Jay Dash you were a great friend for sure! and always will be
badinblack is offline   Reply With Quote
Old 02-16-2007, 07:21 PM   #7 (permalink)
Super Moderator
450RRR's Avatar
Default
I am correcting my numbers to reflect the above posts. Greg, I thought yours were 10.5? That's what Sand Tires Unltd says the weight is.... comp cut on 8x8x .125's.... are you sure?[/b]
Chuck.....I just weighed my Brats again.....
9.6 and 9.7# each after adding Slime...... on a digital 10# scale...so it should be accurate.....
on 21/12/8 comp cuts mounted on Douglas .125 (blue label) 8x8 wheels using metal valve stems.....
p.s...thanx for starting this thread.....great info......Greg
Hot Cams stage III
Venom 'QP' pipe
ESR Pro Series pipe
Modded shock mounts
Rage Modded Tranny
Old 02-16-2007, 09:33 PM   #8 (permalink)
Fast1's Avatar
Default
Chuck
the weight you have for the 21X12X8 6 paddle haulers, which I believe are mine, are not available anymore from Skat in the type of tire carcass I have. New haulers in this size and paddle configuration may weigh ~ 1 lb more
Fast1 is offline   Reply With Quote
Old 02-16-2007, 11:32 PM   #9 (permalink)
sredish's Avatar
Default
Chuck, keep your first post updated with the info as people give it to you and I'll sticky this at the top for a reference.
Edit: oh, it already is, thanks Greg. Anyways, guess my job's done here...
<span style="color:#FF0000">450R Valve Shim Calculator. Thanks to CRFs Only.
RedishConstruction.com
sredish is offline   Reply With Quote
Old 02-17-2007, 01:18 AM   #10 (permalink)
quadwanter's Avatar
Default
GBC sand devil 20x11x8 on .190 @ 18lbs
er forgot my scale was off by 5lbs....i was like how are they only 13lbs lol...so they are in the 18-18.5lbs range
2005 471r
Stage III Hotcam|| Hotrods +3 stroker||+1 KW valves||Precision Powersports MX port and polish|| 12:1 wiseco piston|| WB MX4 exhuast|| WB nerfs|| <strike>K&N</strike> UNI|| Kenda Knarly&#39;s/XC klaws (on front)|| AC Blackline bumper|| GT Thunder rebuilds all around + XC link|| PRM Swing arm Skid|| FLY bars + OURY&#39;s|| GBC Sand Devils on Douglas .190&#39;s|| Moose Grab Bar||
quadwanter is offline   Reply With Quote
Old 02-17-2007, 06:07 PM   #11 (permalink)
Default
updated above and listed in order of weights
07 HD FLHT - sorry, but let&#39;s face it, riding a hog gets you laid more than riding a trx ;-)
06 TRX511ER - SOLD
Venom Exhaust
Hot Rods +3 Stroker
Early HRC Cam
Old 02-27-2007, 12:29 PM   #12 (permalink)
hawk-trx's Avatar
Default
10.25# doesnt sound right for the 20-11-8 6pad reg buff haulers even the old style. if they were UL or triple buffs i would belive it. but std. buff?
hawk-trx is offline   Reply With Quote
Old 03-16-2007, 06:03 PM   #13 (permalink)
screwyfits's Avatar
Default
I'll be gett'n some ITP sand stars on monday Mar. 19th and I'll get ya the tru #s...... but shipping weights (from UPS tracking) on two fronts (22-8-10) mounted on cast alum. rims 25lbs (for the pair) and the rears (20-11-10) mounted on the cast also @ 30lbs for the pair....... I'm unsure of the rim manufacture and model........ they were $388 on my front door step,for the full set......"NICE"
[i]<sup>06 YFZ450
Pulse Charger Exaust "Bad A$$"
(Venom Head Job and Piston) Soon I Hope
ESR Modded Intake W/K&N & Outerwear
Edelbrock Carb "Bad A$$"
Twist Throttle
Cam Mod
ITP GNCC Rears
ITP Sand Stars Fronts 22-8-10 Rears 20-11-10
Tag Stearing Stem
Elka System 5 steering damper "Bad A$$"
Pro Taper Handle Bars
UMI Nurf Bars
Pro Armor MX Front Bumper
Pro Armor Swing Arm Skid Plate
Billit Gas Cap "BLING BLING"
screwyfits is offline   Reply With Quote
Old 05-10-2007, 11:24 PM   #14 (permalink)
Default
20x10x8 btb 8 paddle Gliders on .125's 12lbs ea
21x12x8 btb 8 paddle Gliders on .125's 12lbs ea
21x12x8 8 paddle Gliders on .160's 13.50 ea
21x12x8 8 paddle Hauler/Glider mix on .160's 13.50lbs ea
21x12x8 8 paddle Desert Storms on .190's 16lbs ea
20x11x8 8 paddle Sand Devils on .160's 13.75lbs ea
Douglas Ultimate 9x9's 4lb ea
LTR 8" rears 3.5lbs ea
8x9 Hipers dual beadlocks integrated hubs 6.5 ea
Sandstorm is offline   Reply With Quote
Old 05-11-2007, 11:29 AM   #15 (permalink)
00chevy's Avatar
Default
Yeah, My 21x12x8 7 paddle extremes(bead to bead buff) on 8x7 .125's weigh alot less than 13 pounds.
00chevy is offline   Reply With Quote
You may not post new threads
You may not post replies
SEO by vBSEO 3.3.2
