will an 8 inch tire fit a 9 inch rim? (haulers)!!! - Honda TRX Forums: Honda TRX 450R Forum
post #1 of 10 (permalink) Old 06-13-2006, 09:24 PM Thread Starter
Banned
Location: Monterey, California. no where near a good place to ride...
Send a message via AIM to quadking450r Send a message via MSN to quadking450r Send a message via Yahoo to quadking450r
will an 8 inch hauler fit on an 9 inch rim? steel or aluminum VERY IMPORTANT!!! please i'm in a rush for this, if you know please let me know alright?
thanks
-Grady
quadking450r is offline
post #2 of 10 (permalink) Old 06-13-2006, 09:33 PM Thread Starter
Banned
anyone??? come on????
post #3 of 10 (permalink) Old 06-13-2006, 09:42 PM
ABrocket's Avatar
8 in wide tire "will" fit on a 9" wide rim. why you would do this is beyond me.
tire made for a 8" tall rim will not fit on a 9" tall wheel. It might if you get a tire press large enough and the beads don't snap.
ABrocket is offline
post #4 of 10 (permalink) Old 06-13-2006, 09:46 PM
Send a message via MSN to skelly te3
8" tires for 8" rims, 9" tires for 9" rims...
skelly te3 is offline
post #5 of 10 (permalink) Old 06-13-2006, 09:57 PM Thread Starter
Banned
yeah my thinking was, if the tires smaller then the rim... theoretically, the tire will fit on the rim... then it beceomes... well can you stretch it an inch? thanks guys.
being messed over by a well known . org member sucks :(
-Grady
thanks guys, looks like its back to teh ol check book for new rims....
(.org members name with held) no reason to "beat a ead horse as desert says ) sorry.
post #6 of 10 (permalink) Old 06-13-2006, 11:19 PM
450RRR's Avatar
sorry dude...
width you can play with..
diameter you CANNOT....
greg
HRC kit (all but gone)
Hot Cams stage III
Cold Fusion Nitrous**
Venom 'QP' pipe
ESR Pro Series pipe
ESR modded intake w/RAT stack
42mm Taper-Bored FCR
Durablue Anti-Sway Bar
Modded shock mounts
Rage Modded Tranny
Jetting/N2O: 22N/21F (22hp)
450RRR is offline
post #7 of 10 (permalink) Old 06-13-2006, 11:26 PM
KyKult47's Avatar
Originally posted by 450RRR@Jun 14 2006, 02:19 AM
sorry dude...
greg
[snapback]250068[/snapback]
Now wait a minute a 9" wheel dia will go on (maybe over) a 8" rim. The 64 dollar question is does he want it to hold air?????????
KyKult47 is offline
post #8 of 10 (permalink) Old 06-14-2006, 01:00 AM
Chuck's 06 450's Avatar
Why am I picturing somebody trying to pound a square peg in a round hole???
Grady, are you insinuating that Sloverado told you that an 8" dia tire would fit on a 9" dia rim, or did you assume that it would?
07 HD FLHT - sorry, but let's face it, riding a hog gets you laid more than riding a trx ;-)
06 TRX511ER - SOLD
Venom Porting and Head Mods with +1 KW Valves all around
Venom 100mm 14.25:1 Piston
Venom Modded ESR Intake
Venom Modded 43mm FCR with Rat Stack
Venom Exhaust
Hot Rods +3 Stroker
MaxPower Ice Cube Cylinder
Early HRC Cam
Chuck's 06 450 is offline
post #9 of 10 (permalink) Old 06-14-2006, 01:03 AM
sorry, there is no chance of fitting a 8" hauler on a 9" rim.
the last number is the size of the rim (eg. 20x11x9).
20 is the height
11 is the width and
9 is the rim diameter
hope this cleared it up for ya
2004 TRX450r:
11.5:1 JE
Custom Porting
Hotcams Stage 2
Bills Exhaust - Full System
K&N + outerwear
170 main
48 pilot
Durablue Eliminator 2+2
Renthal Bars
Custom Chromoly Stem
Kenda Knarlys 20x11x9
15/39 gearing
D.I.D X-RING
97' TRX300
5450 hours on the meter
Been to **** and back!!
Becker_450r is offline
post #10 of 10 (permalink) Old 06-14-2006, 03:59 AM
Banned
Send a message via AIM to BATCH450r Send a message via MSN to BATCH450r Send a message via Yahoo to BATCH450r
Originally posted by Chuck's 06 450@Jun 13 2006, 08:00 PM
Why am I picturing somebody trying to pound a square peg in a round hole???* *
Grady, are you insinuating that Sloverado told you that an 8" dia tire would fit on a 9" dia rim, or did you assume that it would?*
[snapback]250144[/snapback]
omg you had me really cracking up there. i also saw someone trying to put a 8 inch tire on a 9 inch rim and the rubber ripping and the threads like coming apart. LOL nice one
BATCH450r is offline
